Question about Hampton Bay 24002 Ceiling Fan
How do I change the bulbs for this fan?
I don't know how to get access to the bulbs to change them there is no obvious access for changing the bulbs. Can anyone help?
  • Anonymous Jan 16, 2009
    How do I remove the globe to replace the lights in my Hampton Bay Ceiling Fan.
  • Anonymous Feb 22, 2009
    I have tried to twitst globe, can't I take the fan down, but how
Twist the glass on the bottom counter clockwise
Posted on Feb 08, 2009
I have a Concord ceiling fan, and cannot access the light bulbs to change them? Please help?
Try spraying some WD-40 around the ring of the glass & push up & back & forth until the glass loosens up (hopefully).
Aug 18, 2014 | Dryers
52" Vaxcel Fresco II Oil Burnished Bronze Finish Ceiling Fan cant change downlight
why not, cant you figure out how to change a light bulb? Look carefully at the way it is made, look for screws to remove a plastic or glass cover to get access to the downlight ,which i assume is a light that points down.
worst case senario is you have to read the owners manual under how to change the light bulb
or call up customer service and ask them how or at least how to call techinical service.
In all fairness , a down light may not be a light bulb that points down , but some kind of compact flouresent light bulb.
check if vaxcel has a web site. they might have instructions on how to change a down light bulb.
Feb 23, 2013 | Hampton Bay 24002 Ceiling Fan
I have a 16 year old intelitouch fan from Casablanca. I was trying to change the light bulb, but after turning off the power to change the bulb, the power would not return to the fan. I have two wall...
I have a casablanca intellitouch ceiling fan and if you change a bulb while the unit is powered on you ruin the control board. The control boards are expensive but easily replaced by a diy-er. I think I have encountered this problem twice. These fans are very well made and in the past I decided it was worth repairing. However with the new fan technology out there it would be wise to shop around and weigh your options.
Jul 10, 2012 | Casablanca Fan Dryers
I can't reach to change the rear brake light. I don't know how i disassamble to reach it
Okay start at the inside top (now we are refering to the third eye) you should be able to squeeze the side toghether and pull out and access the bulb
Feb 24, 2012 | Hyundai Accent Cars & Trucks
Bottom bulbs don't work
Sounds light the 2- 60 watt small base, chandelier bulbs need changing. To access the bulbs and change them does require some dismantling of the base of the insert.
In case you have misplaced your Owners Manual, I have included a link to it that you can download and print for future reference. Pay particular attention to Page # 5 - Maintenance - Changing Light Bulbs.
http://partner.dimplex.com/files/domain4103/7205650100r04.pdf
Hope this helps you solve the problem. Please let me know. Thanks
May 07, 2011 | Dimplex DFI2309 Electric MidSize Heater
Can not get to cover to change light buld battery in the way
You will obviously have to disconnect, and remove the battery,to gain
access to the bulb. I'll warn you straight off, that it is not something a
novice will want to mess with,since messing with the bulb spring will
try the patience of the best. I own an 04' Focus,and it's a complete
nightmare to change the bulbs. Good luck.
Mar 31, 2010 | 2001 Ford Focus
Need to know how to change the bulb in fan oven
You just need to unscrew the clear lamp cover in the oven chamber the bulb will then be accessable
Dec 27, 2009 | New World Ellingwood 100 (Gas) Kitchen...
How to change a instrument panels lightbulb ?
Unfortunately you must remove the cluster to gain access to these bulbs. Remove radio, heater fan knobs, temp slider knobs,and temp control faceplate (carefully remove bulb in faceplate), then remove the Phillips screws inside the holes where these came out that hold the cluster . unscrew or unclip and remove the speedo cable from the back of the cluster. you may have to disconnect some electrical jacks (remember where and how they go back in!) to gain complete access. Then it's just a matter of pulling out the little bulbs and replacing them. Because this is so involved I would replace ALL of them at once. Hope this helps...;-)
Apr 09, 2009 | 1993 Volkswagen Golf
Changing light bulb in microwave oven
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Oct 11, 2008 | Magic Chef MCD1311ST Microwave Oven
Where is the light bulb located?
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar.
You can find helpful exploded view diagrams and for many brands by entering your full model number here: http://tinyurl.com/gv383
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once your over the range type is out of the wall, or if yours is a counter top model, the outer cover (wrapper) will need to be removed.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
We're happy to help and we appreciate your thoughtful rating of our answer.
TO BIGDEEL
Do you mean your internal cooling fan or the hood / vent / exhaust fan?
If it's ther internal cooling fan, do not use the microwave or the magnetron will overheat and be damaged or destroyed.
Jun 23, 2008 | GE JES1288SH Convection/Microwave Oven
Hampton Bay 24002 Ceiling Fan Logo
323 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
