Recently purchased hk avr 1700 now spontaneously shuts off after 30 minutes, regardless of setting for sleep timer (on/0ff or any minute setting).
The amp has only analog input sound from my tv, and powers 5 speaker enclosures (front left/right, surround left/right and sub-woofer). There is no HDMI, optical or other cable attached. On initial set-up four nights ago everything seemed to work well enough on 5.1 surround setting. Over the weekend while the tv was on for longer periods of time, we experienced the amp turning itself off. We experimented with setting the off timer (all available settings), and it continues to turn off precisely 30 minutes after it's turned on.
5 Suggested Answers
gopakumarg43
  • 74482 Answers
SOURCE: how do I use the
Hello
Before going to set the timer, you have to set the current time. Set it according to the manual with you. If the timer function work properly, there must be an uninerrupted power supply also. If the power goes off, the set time will also get resetted, and improper function will occur.
After setting the present time, set the "on" time and "Off" time. The TV will switch on at that time you set, and will switch off automatically after the end time. OK.
Posted on Dec 24, 2010
  • 6 Answers
SOURCE: assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Posted on Dec 05, 2008
SOURCE: turn tv on stays on for up to ten minutes then shuts off,
turn off the timer
Posted on Apr 22, 2009
SOURCE: analog white-westinghouse tv has blue screen and no sound. Connected to digital converter. screen does not change and after 5 minutes the tv shuts off
the glitches could have fried part of the tvs main chip
i have had it happen to me a few times and or it was a fuse
Posted on Aug 06, 2012
How do I set sleep timer on the 6400?
Screen Menu > System > Time > Sleep Timer > TIME
This function automatically shuts off the TV after a preconfigured period of time. You can set the timer up to 180 minutes in 30 minute increments.
From: http://downloadcenter.samsung.com/content/UM/201308/20130813132610569/%5BENG_US%5DX12ATSCF-1.119.pdf
May 07, 2014 | Samsung Televison & Video
My Cox HD/DVR controller will turn off but will not turn on my new HKAVR1700 using the AUX button on the Cox supplied URC-8820-Cisco remote.
This is a documented problem with the Harmon/Kardon AVR-1700 and the Cox remote. Here's how I solved it. On the HK1700, go to System Settings and turn on HDMI Link. This will allow your TV (if it has the feature) to put the HK in standby mode when you power down the TV. Go to your setting on your TV and turn on HDMI link, or equivalent. I have a Sony TV and the setting is called "Control For HDMI." Then, use code 0110 for your Cox remote. This code will only turn on the HK, not turn it off. BUT, the HDMI Link should put the HK into standby.
Jan 06, 2013 | Harman Kardon Harman/Kardon AVR 1700
NEW VIZIO 55 INCH SHUTS OFF AFTER 30 MINUTES?
There is a sleep mode on remote and set that only allows set to run for 30 minutes read your owners manual i'm sure it will tell you how to disable sleep mode.
Apr 14, 2012 | Televison & Video
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
Can I use a sleep funtion/
If your set has a SLEEP TIMER function, yes. Simply set the timer (usually in 15 or 30 minute increments) and it will count down and shut the set off when it counts down to zero.
Jan 29, 2011 | Televison & Video
Samsung ht-x50 home theater system keeps shutting off
You have probably set the sleep timer. Here's how to switch it off: To cancel the sleep timer, press the SLEEP button until <OFF> appears on the display.
Jul 07, 2009 | Samsung Electronics - Others
T.sonic MP3 Player 610 - iT ISN GOING OFF AFTER A FEW MINUTES OF
You have probably turned on the sleep timer.This function sets a time delay to automatically power OFF regardless of playback status.In the SETTINGS menu, use <<and>> to select “Sleep Timer” then press Z and then press the play/pause button.Then use the + or - keys to highlight disable and then press the play pause button again. Let me know if it worked.
Sai.
Nov 25, 2008 | Transcend T.sonic 610 MP3 Player
To adjust snooze time - The system is set for a standard 10-minute snooze time (the number
of minutes you can delay the alarm). While the selected alarm is flashing, hold down Sleep⁄Snooze
and press the Time or to adjust the snooze time (from 1 to 30 minutes) for that alarm. The
number of minutes and Sn appear on the display to confirm your selected snooze time. You can
set a different snooze time for each alarm.
Oct 01, 2008 | Homedics SS-4000 Clock Radio
Nextvision n5
check your sleep timer settings. they stay on no matter how much you turn your unit on and off.
Oct 29, 2006 | ViewSonic NextVision N5 (n5-2) Video...
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Electro Med Services...
