Question about Maytag MSD2756G Side by Side Refrigerator
Maytag PSD2350DR. Water in bottom of frezer even thought the water connection is turned off.
3 Suggested Answers
aasc
  • 1606 Answers
SOURCE: Freezer leaks water even after water supply turned off
Remove the food from the lower portion of the freezer and remove the 2 screws which hold the rear freezer panel on . Remove the panel and use a hair dryer to defrost the ice built up over the drain . Once you see the black drain hole , concentrate on defrosting the hole . Once defrosted , the ice water will drain into the hole . I would use a small hose inserted into the drain and blow thru , to remove any debris built up inside the drain . Reinstall the panel and food .
Posted on Aug 09, 2009
  • 180 Answers
SOURCE: water leaking from the bottom of frig
Your  deforst drain is clogged.  Every 12 hours or so your fridge does a deforst cycle.  It melts all of the ice built up on the evap coils.  There is a drain at the back of the fridge that goes to a pan by the compressor where the heat from the compressor and the condensor coils evaporates it.  Take the back panel off of the freezer compartment and plunge out that hole.  You will most likely have a build up of ice over the top of the drain.
Posted on May 31, 2010
Fridge/frezer not cold,only at the bottom,act like fan that blows across coils is not working,how do I fix
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 04, 2011 | Maytag 25.6 cu. ft. Wide-By-Side...
My refrigerator expelled water tonight. Whe I woke, this morning, I found the floor with water. Can you tell me what could be happening?
if the drain is blocked in the freezer water can leak out onto the floor if it's leaking out of the frezer door.open the door and check the bottom rack,if it's frozen in or ice is on the floor of the freezer then it's the drain.also if you have a water line going to the machine one of the water lines could have cracked.let me know what you find and we can go from there
Jan 08, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
Water leaking into bottom of frezer,water frezing on bottom then leaking onto floor
defrost drain bottom rear of freezer is blocked . Defrost and clean drain tube.Poor water in trough at back under rear panel. If it drains out quickly then it is clear.
Oct 29, 2010 | Frigidaire Kitchen Ranges
I just purchased a Used Maytag Side by side Refridgerator as i thought Maytag was reputable but as i reseacrh looks like many complaints..? :( I just plumbed in the water supply line and I get 1. No...
Actually Maytag is the cheap brand of Whirlpool so don't expect high quality even as new.
1 - the water doesn't come because either one of the valves is stuck shut or the lines are clogged/strangled somewhere (or even a clogged water filter). The only way to fix that is to check the entire water circuit, from the pipe that connect to the house line to the spout on the door.
2 - replace the water filter and try to reset it again.
Remember, you bought it used because somebody returned it for a reason. Never do that again with white goods.
Aug 19, 2010 | Maytag 22.7 Cu. Ft. Side-by-Side...
Ice in bottom of frezer
make sure your doorgasket is sealing correctly. if the water runs out it shows that the defrost heater is working.
Aug 07, 2009 | Frigidaire FRU17G4JW Refrigerator
My maytag wide by side keeps frosting up .
You might have a bad thermostat or defrost timer has gone bad.
Jun 28, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Cannot get cold water to flow into my maytag washer
The most common cause is a bad Fill-Valve, It has two selenoid valves that control the hot or cold water entering the unit depending on the temp slection switch. The water hoses usually connect directly to it on the rear of the machine..
May 04, 2009 | Maytag Washing Machines
Water leaks out of freezer once or twice per day
is there water frozen on the frezer floor.if yes your defrost drain is froze over.it only happens a few times a day because happening when its going into defrost,the water melts on the frezer evaporater then should go in the drain.if blocked it then runs on floor.you could turn of your refer for 8 hours or so.or get to the bottom of frezer behind back frezer panel[remove]and use a hair dryer to thaw drain use a weed eater line with a knott on an end to push thru and pull out the other side.the knott would clean any stuff in the drain line.ps watch out for water and electricty.i hope this helps God bless,tom
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag Washer overflowwing
I had the same problem. My whole basement flooded. Inside the back (you can see it thru a small hole 1/2 way up on right) a small white hose connects to the water shut off collection area. This hose carries the water from the tub to the collection area and tells the machine to cut off for the size of load selected. Mine had come undone and so the machine could not sense it was full and the water poured all out the bottom. I simply removed the small gray panel at the bottom on the back and reached up inside to reconnect.
Jan 26, 2008 | Maytag Performa PAV2200
Maytag MSD2756G Side by Side Refrigerator Logo
70 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
