Question about Logitech Harmony 890 Universal Remote
Logitech 890 remote quit working
Yesterday I turned off television, Direct TV, and receiver using the remote. One hour later nothing responded to the remote. When you lift the remote, it still lights, but the button to turn on TV does nothing. When I then manually turned on all components, the Logitech remote will not turn anything off. Nothing responds to it.
System installed October 10, 2008 by the Geek Squad. Worked great until yesterday. Logitech always kept on recharging station. Never dropped or treated any way bad - always treated with kid gloves.
TV is Panasonic 50 inch 1080 Plasma. Receiver is Yamaha RX-V663BL. Thanks. Mark Osborn
  • nghtwng Apr 03, 2009
    Our Logitech 890 universal remote worked great last night, operated all of our devices just fine. Now all of a sudden, all it will do is turn the TV off and on. Volume, menu and channel buttons won't work, and the remote won't control the satellite or PS3. We tried removing the battery and reinserting it. Nothing! Any suggestions?
It just started working again. Maybe it took the day off.
Posted on Jan 12, 2009
Harmony 890 remote quit working. Screen is normal, fully charged battery, but it just quit
reset the code download from www.fitness.manualsonline.com or www.remotecodelist.com
open the remote control. clean the keypads switch, for dirty, oxide, bad contacts switch, or open use the VOM, see the block diagram, if these switch are NOT o.k they will not send infrared signal to the microcontroller from the receiver.
If this doesnot resolve the problem go to the repair shop TV for fix it.
God bless you
Jul 20, 2012 | Logitech Harmony 890 LCD Remote Control
I have a harmony 890. it turns all the equipment on/off properly except the TV (a Vizio). this works intermittently. suggestions?
Hi. Try learning the power commands for your Vizio TV from the original remote. The power commands that the Harmony remote is using may not be correct. The following tutorial by Logitech will assist you with this.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9605
Regards,
D
Aug 26, 2011 | Logitech Harmony 890 LCD Remote Control
It just started not responding to commands. Only tv will come on.
you may need to select the device you wish to control first. if unsucessful, then try reloading codes into remote
Mar 19, 2010 | Logitech Harmony 890 LCD Remote Control
I have a logitech Harmony 890 remote. The battery
To check to see if your device is controlled by a RF (radio frequency) or IR (infrared) remote:
Power the device on manually
Cover the front of the original remote that came with the device with your hand
Press any button on the remote that you know the device would respond to normally
If the device responds even when your hand is covering the front of the remote, the remote is RF and the device cannot be controlled by the Harmony remote
Another test that can be performed is using digital camera:
Using any digital camera, even one on a cell phone, camcorder or webcam, look through the screen of the camera at the front of the remote
Press a few buttons on the original remote
If you see flashes of light as illustrated, the remote is IR and the Harmony can control it. If the remote does not flash, this original remote is an RF remote and the device cannot be controlled by the Harmony remote
For comparison, try the same steps with a remote control that you know is working correctly, such as the original remote for the TV, or DVD player. You should see the IR emitters flashing when performing this test.
Feb 08, 2010 | Logitech Harmony 890 LCD Remote Control
Remote stopped working
Hey!
I have found when you are not able to control devices, a firmware update will sometimes fix the issue. If you do not know how to do a firmware update, please look at the following link:
http://logitech-en-emea.custhelp.com/cgi-bin/logitech_en_emea.cfg/php/enduser/std_adp.php?p_faqid=10747
If the firmware update does not work, you may have to learn the power commands from the original remotes. The following link shows how this is done:
http://logitech-en-emea.custhelp.com/cgi-bin/logitech_en_emea.cfg/php/enduser/std_adp.php?p_faqid=9603
I hope this helps!!!
-Kennedy
Jan 01, 2010 | Logitech Harmony 890 LCD Remote Control
I have a logitech 890. The remote only turns the tv on and off but nothing else.
this remote has a help button to resolve setup issues. you should see a message on the screen ask ing if you need help. If not this function can be activated using the setup software. Try using the remote to watch TV. Then press the help button(be sure to have the remote pointed at the TV). The remote will attempt to fix itself. the screen will then ask if that fixed the problem-choose yes or no. Continue to follow the prompts until everything is the way you want it.
This should get everything working for you. I assume you did connect the remote to your computer and went through the setup software.
I use this remote and I love it. Just be sure when using it to give time for it to send commands to all the devices.
Nov 06, 2009 | Logitech Harmony 890 LCD Remote Control
The power flickered on and off last night and since then I cannot get my Harmony 890 remote to change channels. We have Direct TV. It will control the volumn and turn the tv on and off, but will not...
You DirecTV device may have been reset ack to RF. You'll have to make sure the device is set to accept IR commands in order for the Harmony remote to work on it.
This link will help you.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=12985
-D
Oct 31, 2009 | Logitech Harmony 890 LCD Remote Control
what are the other devices that you have
are you trying this in device mode or are you trying this within activities
have you checked the power settings for the other devices that you have like leave the device on all the time
have you checked if the other devices you have can be controlled in device mode
Jun 04, 2009 | Logitech Harmony 890 LCD Remote Control
Everything But The TV
This FAQ on the Logitech website gives you detailed solutions. Please read all points!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=2367
Hope that helps! Dont forget to rate this a Fixya if my solution helped you.
Cheers!
ID
Nov 06, 2008 | Logitech Harmony 890 LCD Remote Control
Logitech Harmony 890 Universal Remote Logo
466 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
