Question about Vicks Ultrasonic V5100 Humidifier
Welbilt Ultrasonic humidifier MW 25 m water in reservoir is bubbleing, mist is not coming out
JohnSc
  • 21 Answers
SOURCE: Odor
First, clean or replace the filter. Next, mix a very weak solution (40:1 ratio) of bleach and water to fill the unit. the bleach will kill any bacteria that could be causing the odor, but NOT harm anyone, The filter will take care of any hard water issues. Just don't make the mistake of thinking "If a weak solution is good, a strong one is better". NOT TRUE. Stay with the 40:1 mix unless you like breathing bleach. (Yuk) Note: It may take a couple of days for the odor to go away.
Posted on Feb 08, 2008
  • 114 Answers
SOURCE: WHY DON'T MIST COME OUT OF MY HUMIDIFIER
with cool mist humidifiers your not suppose to see any mist. if it's a warm mist there should be. but by your model number i'm finding that it's a cool mist. that's why your not seeing any mist.
Posted on Aug 20, 2009
Testimonial: "Thank you for your respond. It was very helpful."
c7121
  • 160 Answers
SOURCE: I have a Cool Mist V3500 humidifier. The fan
TRY POURING IN SOME WHITE DISTILLED VINEGAR AND RUNNING IT. THE VINEGAR LOOSEN UP ANY SCALE AND JUNK. AFTER RUNNING UNIT FOR AWHILE, DRAIN OUT ANY REMAINING LIQUID AND ADD DISTILLED WATER OR FILTERED WATER. RUN UNIT AGAIN. THEN DRAIN OUT ANY LIQUID. NOW THE UNIT SHOULD WORK AS NORMAL. IN THE FUTURE, TRY USING DISTILLED WATER OR FILTERED WATER.
Posted on Dec 13, 2009
SOURCE: Humidifier Leaking over floor, not retaining water, excess bubles
My humidifier is leaking. I is a Vicks V3900 Germ Free Cool Mist Humidifier. How do I solve this problem
Posted on Feb 10, 2010
mpcheeseman1
  • 1400 Answers
SOURCE: do I add salt with the water when using this cool mist humidifier
Hello
Ive been down this road before,sorry your son is sick.
Take a teaspoon of salt and add it to a full tank,it will break up the corrosion on the heating elements,a teasspoon of baking soda will help also.
This will not hurt anyone if it blows into the air with the steam.
Posted on May 12, 2010
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
www.qvc.com/Air-Innovations-Clean-Mist-Ultrasonic-Dual-Tank-H...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
www.qvc.com/Sharper-Image-Dual-Tank-Warm-&Cool-Mist-Ultras...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 | Humidifiers
Motor runs but no mist comes out on EV-HD15
If there is water in it, it sounds like the ultrasonic unit failed.
Dec 05, 2014 | Sharper Image EV-HD15 Cool Mist Ultrasonic...
Why does my humidifier holmes 1700 blows air but no water or mist?
If the water has been sitting in the reservoir for days without use, it may develop a film on the ultrasonic element which inhibits the creation of the mist to come out the top of your humidifier. I would lift off the tank and empty the reservoir. Then VERY GENTLY with a piece of paper towel, wipe the ultrasonic element (looks like a disk the size of a quarter at the bottom of the reservoir) to clean off any film. Then replace the tank and let the reservoir fill up the tank and try it again.
Good luck
thebqe
May 04, 2014 | Holmes Products Humidifiers
Humidifier will produce mist for a min then stop If you look you can see it producing mist within but it will not come out of the top Walgreens cool mist ultrasonic humidifier
I have had times where my Crane humidifier won't produce mist if I haven't turned it on for several days (4+) or more. The water that sits in the reservoir may develop a film on the ultrasonic element which inhibits the creation of the mist to come out the top of your humidifier. I would lift off the tank and empty the reservoir. Then VERY GENTLY with a piece of paper towel, wipe the ultrasonic element (looks like a disk the size of a quarter at the bottom of the reservoir) to clean off any film. Then replace the tank and let the reservoir fill up the tank and try it again.
If your humidifier runs properly for a minute and then makes a whirring noise and goes silent (like the motor stopping), then it's a motor problem. The humidifier motor may have gone out of alignment due to bumping or rough handling of the humidifier when cleaning or emptying it. If that is the case, you will have to empty the humidifier reservoir, unscrew the base, and find the screws holding down the motor and check for misalignment. Loosen them a little and put it back together and try again.
Best of luck
thebqe
Feb 13, 2014 | Humidifiers
Inherited a Welbilt Ultrasonic humidifier and after reading all of the "sensativity" issues want to make sure to clean it properly....no paperwork came with machine.
For mineral deposits use a soak of vinegar
And water overnight. Scrub with a brush, and
Rinse well. To disinfect and get rid of discolorations, soak in a little bleach and water. Rinse well. A little secret from my pediatrician, use 1/4 tsp bleach with a full tank of water in use. It kills germs, bacteria and gives the mist a fresh smell. It makes
Cleanup nonexistent. And such a small amount will do no harm to babies or anyone. Use of bleach is the most common form of water purification. Google it, you'll see. I
Have a Welbilt ultrasonic humidifier. It is 20 years old and works just like new! Welbilt indeed!!!
Jan 25, 2011 | Humidifiers
There is not mist coming out. What should I do??
The moisture released by this (or any ultrasonic) humidifier should not be visible, so it is very possible that it is working correctly. Try filling the reservoir and marking the water level with a small piece of tape. Then run the humidifier for a few hours, and check the water level again. If the water level is below the edge of the tape, then you know it is releasing moisture into the air, and everything is working fine.
The older style of humidifiers created a mist by spinning a disk that was partly dipped into the water reservoir. They had to be refilled often, and the mist could leave water spots or dust on nearby furniture. The water level should change very slowly in your ultrasonic humidIfier compared to a misting humidifier.
Jan 13, 2011 | Vicks Ultrasonic V5100 Humidifier
The water doesn't seem to be passing through the filter, therefore the bottom reservoir isn't filling up enough to create mist
If water won't pass through the filter, then either the filter has an adjuster that needs to be opened up or the filter needs to be replaced.
Nov 11, 2010 | Vicks Ultrasonic V5100 Humidifier
Aug 15, 2009 | Vicks Cool Mist V3500 Humidifier
No mist, but i can see a water droplet fountain on the surface
if it's a cool mist unit it will not produce any mist. now if it's a warm mist unit it should. that's normal. it is possible to replace the transducer if it is damage but you are going to have some leakage from it. but the only way to get the transducer mainly is from the manufacturer
Mar 12, 2009 | Sunbeam Ultrasonic Humidifier
Humidifier mist won't come out of tube
sounds like the small fan that is located in the base isn`t pushing the mist out. unplug it then take all the screws out of the base. there are screws under the black foam stands too. be careful not to touch anything that looks like live wires while you look inside then look inside while it is pluged in. it should turn. check for something blocking it like lint or dirt..you may be able to clean around the shaft with w d 40
Dec 31, 2007 | Sunbeam Ultrasonic 81696 Humidifier
Vicks Ultrasonic V5100 Humidifier Logo
117 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
