Question about Motorola Mobility HS850 Consumer Headset
I need a charging cord for an hs810 that connects to a msb port
    Problem Solver:
  • 4 Answers
Try going to a store and find a multi- Moto universal charger.
Posted on Jan 23, 2009
My phone won't charge - goes up to 35% then rather than charging, starts discharging. Shuts off and comes back on. Heats up real hot to the touch. Took off protective covering still doesn't help.
Sounds like a bad charge cord. They heat up because of bad connection . Try blowing in charge ports,charger and phone, to clear any dust out ...if that doesn't work ,need new cord.
May 12, 2016 | Cell Phones
My phone will not take a charge or power up
Confirm that the charging port is working (it may have cable connection issue, and have to be place in a certain position to charge), If the port is fine, then figure if battery is bad.. If charging port is bad, its a relatively easy and cheap fix.
May 29, 2014 | HTC Vivid
My sky caddie sg5 won't charge thru the usb or power cord...any ideas???
Hello there,
Since you have tried charging the device using the usb and the power cord. It is quite clear to know that the problem is from the device connection port. It is bad and need to be replaced.
But you need to Try to test the battery in other devices then try to charge it there to see if it will hold a charge. If the battery holds a charge there, then it means the battery is okay and if it does not charge. Then it means the problem is from the battery. It need to be replaced if so.
Then test the charger/ power cord on another device if it is not bad, then you test the usb cable also. After running these test. You will be clear to know if it is the connection port. Then replace the connection port once confirmed to be the problem. Hope this helped. Goodluck Elect_Comp
Sep 02, 2011 | SkyGolf SkyCaddie SG5 Car GPS Receiver
I need a DC power cord for a margarator. item #MSB-580
Hi pillzy,
The power cord you need can be purchased by contacting the manufacturer at this site Website
they have other retailers who can provide the part you just need to contact them first to know where and possibly how much.
I hope this helps.
Thank you for choosing Fixya,
mvincentc
Jul 04, 2011 | Helman Group Nostalgia Electrics MMA-600...
THE CHARGING CORD IS LOOSE ON THE GARMIN CONNECTOR PORT--IS THIS REPAIRABLE
Yes it is repairable. What need to be done is that you get the connector port replaced. It is quite technical, so with a technical hand, you will be able to do the job effectively. You get a replacement charging port, then you open up the device and replace the charging port.
Before you do that, try to use another charging cord to see if it will be loose, if it is not loose, try to replace your charging cord instead, but if it is loose, then you have to change the connection port of the gps.
Jan 05, 2011 | Garmin GPS
My gateway netbook wont charge, they sent me a new battery but again it will not charge, what could be wrong?
The problem might be either from the charger or from the laptop.
To confirm and repair if it is the charger, all you have to do is to plug the charger on another laptop to see if it will charge, if it does not charge, then you know the fault is from the charger, and the solution is for you to replace it with a new one, before you replace it, try to connect another power cord to the charger, because sometimes the power cord might have been burnt, that have happened to me twice and replacing the power cord solved the problem. But if replacing the power cord does not help, then you need to change the power cord.
To confirm and repair if it is the laptop, plug in a new charger to the laptop, if it does not charge, then you need to understand that the charging port of the laptop is faulty and needs to be replaced, have a repairman replace the charging port for you.
Take care and good luck
Oct 31, 2010 | Gateway LT2021u Netbook
Charging port is not connecting loose receiver , must push down on cord to connect
Hello
The problem is from your charging as you have rightly said.
What you should is to open your phone,try adjusting the charging port to its position because it might have shifted
If the problem persists,then you will have to replace the charging port with a new one and your problem is solved.
Thank you for visiting fixya.
Feb 22, 2010 | Cell Phones
Motorola Mobility HS850 Consumer Headset Logo
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
