Question about Interactive Health Refurbished Htt 10crp / Ht 120 Robotic Human Touch Massage Chair with Human Touch Technology
HTT-10i crp My dog bit the controller cord of my chair, is it possible tu buy a new controller?? or is there a way to fix it? PLEASE HELP!!
New batteries wont charge???.
Possibly the charger is faulty.
Apr 15, 2014 | Jet 3 Ultra Power Chair
Bought a Collins power recliner by home meridian from samsclub that has only half of the power supply. (It was on clearance) Where can I find a replacement power supply for it? I have searched everywh
try liftchair.com I bought a new motor and button from them. They have parts for many makes and models. I took old assy apart and found it was a defect in the wire between motor and push button. I drew a schematic of mine here is the drawing.
Apr 17, 2013 | Home Meridian Fletcher Power Recliner
I want to buy a high chair cover / pad for my grandaughter's new high chair but I want something a bit different. I don't mind paying more for it. Where should I look?
Have you tried the Etsy site? They have some really nice stuff - not the cheapest that's for sure, but definitely a bit different. This link shows a pink paisley design that I thought was gorgeous.
Aug 29, 2012 | Chicco Baby Gear
Can I get a wooden rocking chair that is not wood color? I want something a bit more funky for my new house.
You can definitely find places to buy colored rocking chairs. Try the rockingchaircompany website http://www.therockingchaircompany.com/Classic-Rocking-Chairs-s/113.htm or you could always strip and paint a basic wooden rocking chair, and pick whatever color you want.
Aug 21, 2012 | Furniture
Help I stupidly got my dog lead caught around the left drive wheel of my M61 Pronto yesterday. A kind person got it unwound but needed to tip the chair on its side to do it. Now the far left single green...
The M61 has an elevating seat. There is a speed limit switch which consists of 2 magnets that make contact under the seat on the seat post. If the 2 magnets are together then the chair thinks the seat is all the way down. If the magnets aren't touching it activates a safety feature in the controls which cuts power to the chair by 50% hence drives real slow. Try lowering the elevating seat down through the joystick controls. If that doesn't fix it then either the magnet switches on the seat post came unplugged or broke.
Sep 16, 2011 | Invacare Supply Group Pronto M61 Standard...
Missing a charger cord....can anyone help please??
The power cords is almost dead on to the power cords that plug into the back of your computer,Check around at your local Radio Shack or Best Buy..
That should do it,hpoe I was helpful
Jan 21, 2011 | Jet 3 Ultra Power Chair
I bought the new style batteries for my mother-in-laws older modle mini jazzy that have a 1 year guarantee and are expected to last 2 to 3 years. It's been 3 months now and I'm already having issues that...
Deborah,
The most common problem for this power chair involves the connections at the rear of the chair for the VSI controller (joystick). Unplug the large and small electrical connectors at the rear of the chair and inspect for discolored and corroded pins on the plugs. You can clean the flat pins on the large connector with a green synthetic scour pad and WD40. Spray contact electrical contact cleaner on the other pins and plugs.
Check the voltmeter on the back to make sure it is indicating charging. If not, remove the the rear cover and look for a black boot over a fuse holder. Inspect the fuse (7.5 amp ATO) to see if it is good. The on-board chargers on these chairs have a history of going bad, but are easy to replace. That being said, if you have good battery connections, good charger fuse, good cord connections, good voltage meter, then your most likely culprit is your on-board charger. The least expensive and easiest fix is to buy an off board charger and plug it in the front of the VSI (leave the old on-board one in the chair and don't plug in the AC cord).
Check the battery connections to make sure they are tight. Check the charger cord and make sure it is plugged all the way in.
If you have access to a voltmeter you can make electrical checks on all components. For now, I would check the obvious visually and mechanically. The connectors on the rear of the chair coming from the VSI are usually the source of most problems. Hope this helps.
Dec 18, 2010 | Pride Jazzy 1103 Ultra Indoor Power...
My dog ate the cord for the volume control. How can I buy a new one?
type in Logitech Z-2300 speakers volume cord that may help or check from where you bought them
Jan 29, 2010 | Logitech Z-2300 Computer Speakers
Human touch HTT 800 just beeping from back, not remote
Just had this problem with our HTT 800. Discovered it was the curled phone-like cord attached to the remote that had been chewed through by one of our dogs. Some electric tape fixed it right up. Still looking for a replacement. Anyone know where I can find one? A standard-size phone cord does not work with this, as it is too large.
Feb 27, 2009 | Interactive Health Ht 135 Massage Chair
Help! Dog Bit Through Electrical cord on Lakewood 2727. How to replace cord???
another option for you would be to use crimp on terminal connectors(**** connectors) you may purchase these from most hardware stores. Even using these I would still tape around the outside to ensure a good insulating surface.
Apr 28, 2008 | Lakewood 2727 Heater
Interactive Health Refurbished Htt 10crp / Ht 120 Robotic Human Touch Massage Chair with Human Touch Technology Logo
81 people viewed this question
Top Interactive Health Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Interactive Health Health and Beauty Expert? Answer questions, earn points and help others
