Question about Viking DDBB363 Bottom Freezer Refrigerator
Door alarm i think my dooor sensor is broken. how do i change this part My door alarm goes off several times a day, replaced door switch, door seal, and still the alarm goes off. Any help would be appreciated. Thank you.
  • 2 more comments
  • kandmsigns Jan 12, 2009
    Hello
    I have an Amana bottom freezer refrigerator model number B136CAR1. I was told this was made by Viking. The door alarm sounds at different times of the day.I have replaced the upper door switch, and the door seal. The alarm still goes off. Please help!
    Thank you
    Hello
    I have an Amana bottom freezer refrigerator model number B136CAR1. I was told this was made by Viking. The door alarm keeps sounding. I made sure upper and lower seals were tight, and replaced the upper door light switch. Still, the alarm sounds.
    Please Help!
    Thank you
  • kandmsigns Jan 13, 2009
    Hello
    My Amana/Viking bottom freezer, model number B136CAR1 door alarm is still going off at night.
    It seems that others with this refrigerator are having the same problem. I made sure the door seals were okay, upper door switch was replaced.
    Can anyone out there help?
    thank you.
  • kandmsigns Jan 14, 2009
    Where is the door alarm sensor located on a Amana/Viking bottom freezer refrigerator? How do you replace it?
    Thank you
  • 470 Answers
Many remotes use a button-press sequence to arm or disarm the audible or visual alarm arming indication. Your owner's guide should contain the sequence needed if the remote is capable of change. I have set my Subaru's signal to flash the lights only; the horn-honking seems superfluous and is kind of annoying.
If your alarm is arming at all, the system fuse in the car is probably not blown. You can check the alarm pretty easy by thumping on the car or rocking it hard a few seconds after arming the system with the remote. Either the sound sensor or the motion detecting feature should respond to one of those disturbances.
Posted on Jan 14, 2009
  • Antonio Buenafe Jr.
    Antonio Buenafe Jr. Jan 14, 2009
    the sensor is located at the below on the wall on the door and the remote sensor,, check if it is blocked!!
    Antonio Buenafe Jr. Jan 18, 2009
    you cannot replace it by yourself my dear,, because this mechanism is complicated and sensitive,, i suggest to buy a new alarm and take the job by the technician in order for the unit are going to be safety
  • 151 Answers
Some of these types of sensors have a battery in them and when they get low it is a sign the battery needs changing. Open the sensor up and check to see if it has a bettery. If so, change it.
  • Viking Master
  • 19,396 Answers
Cut the power for ten minutes, if the alarm does not go off, then you have either a faulty door sensor, or a contact on wirings.
Posted on Jan 13, 2009
  • Ginko
    Ginko Jan 14, 2009
    Hi there, the the door alarm sensor is located on the door latch.
    If you replaced already the door latch, then the problem is either the door gasket, the wiring harness (contact) , or the control assembly.
    Inspect door gasket, and ensure it is closing properly (GASKET-DOOR)
    Double check that door latch is installed correctly.
    Here you find all parts and diagrams for your appliance.
    Sniper:
  • 88 Answers
Hello. All you need to do is change the actual door switch (that activates the light). IF this does not do the trick then your main baord is detecting an open door even thought the switch is good. I would definitely try the door switch first.
Posted on Jan 12, 2009
    Genius:
  • 1,239 Answers
Door alarm - duet_boot-2005.09.29-17.46.10.jpgRefer it
  • ABHISHEK.C
    ABHISHEK.C Jan 13, 2009
    sorry the last picture not came properly
    i think the exact problem is the timer why i said this is you said replaced door switch, door seal,
    and the last left out is the sensor as the sensors ,controlpanel all controlled by timer,,,,,,,,,a faulty timer would be the accurate solution,,,,,,,,i think u should check the timer if a need replace it,,,
    thank you
    Sergeant:
    Novelist:
  • 326 Answers
Http://www.expertappliance.com/viking-refrigerator.html this is the link for the required parts just click it. Call 1-352-321-2675 for direct online parts ordering.
thanks. rate the solution accordingly.
    Genius:
  • 1,011 Answers
Dear,
check this link, it will guide your throughout and having more detailed manuals.
http://www.ajmadison.com/cgi-bin/ajmadison/DDBB363.html?brand_store=1
regards,
dont rate it until  u satisfies with the solution
  • 45 Answers
This sounds like the alarm switch or sensor is malfunctioning.
Do you have a refrigerator thermometer? You can buy one in the hardware store pretty cheap.
If so put it into the fridge and make sure the temperature is steady and not fluctuating.
If it fluctuating this may set off the alarm if it is a sensor that triggers the alarm due to temperature drop..
Rather than a mercury switch will only signal the false door opening if it is faulted, rather than a warm temperature!
How old is the fridge?
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Let me know what you decide!
Please do not for get to give a rating before you sign off!
Thank You, amber
  • 818 Answers
Http://www.repairclinic.com they have schematics diagrams and parts catalogs
    Genius:
  • 2,920 Answers
The door alarm chimes when the temp changes inside the freezer make sure that the bottom inside the freezer is staying as cold as it should and make sure the seal is clean and tight...use soapy water on the seal as it will help it to seal the best
Posted on Jan 11, 2009
  • Ronnie Houston Jan 12, 2009
    have you tried unplugging it for about 15 minutes or so and then plug it back in to see if that dosent help?
    President:
  • 2,110 Answers
Door open sensor trips and alarm sounds
It's either the sensor itself or the wiring from the sensor to wherever it goes. I would start by swapping the two rear sensors and see if the fault moves to the other side. If not it's the wiring which you will need to trace and check all connectors involved.
May 08, 2014 | Ford Escape Cars & Trucks
Door ajar sensor
Its a thick pin surrounded by a rubber ring/bellows that is in the doorframe of each door. Each pin operates a switch. When the door closes it presses the pin in and when it opens the pin slides out so it protrudes into the door frame. Open each door one at a time and press in the pin with something strong like a shoe heel, this simulates that door being closed. Do it several times, till you find which switch is not working all the time. Change that switch by removing the rubber surround and unscrewing its fasteners.
Dec 14, 2013 | Dodge Cars & Trucks
Hi my 2006 x5 4.4l , recently the alarm the flasher lights goes off while its parking, sometimes it happans twice a day or sometimes once every three to four days, can anyone help please?
hi bayan,
There are numerous inputs that are monitored for BMW anti theft deterrent system. All the door locks, interior sensor, hood switch, and inclination sensor can cause the alarm to set off. I would recommend making sure all your door locks are working correctly. Next I would check under the hood and make sure the hood switch is not broken or out of adjustment. I think usually the switch can be located on the plastic cowling in the vicinity near the driver side strut tower. When you find the hood switch, you can just unplug it for testing purposes. Leave it unplugged for a while and see if you still have a problem. If nothing seems apparent you can always have the system scanned to see what faults are stored in the control unit's memory.
Jun 30, 2011 | BMW X5 Series Cars & Trucks
My alarm goes of intermitantly do i need anew door
I just did this to my 02' last night.
Put key in ignition and turn to run. Open and close each door, make sure the interior lights and dinger go off each door. If one doesn't that is the door to focus on and do this......
Open door.
With a screwdriver trip the latch on the door 2 clicks, you'll see
In the void just below the latch finger get a can of Brakecleen and firehose the hell out of it. As fast as it evaporates I still had it running out of the door drain.
Pull the handle to re-set the latch and open and close the door several times to work the switch. Might have to do it several dozen times.
Repeat as necessary.
Finish up by giving it a blast of PB Blaster, WD 40, or some light lubricant.
Repeat for the other doors.
If this didn't do the trick, give it a few days to maybe work itself free, ohterwise you may have to replace the $170 lock assembly.
Dec 28, 2009 | 2000 Volkswagen Beetle
Car alarm goes off for no reasoln
Check all ground connections (black wires) from alarm module,may be loose.Also pin switches in door jams,under hood and trunk.While alarm is going off have a friend push and wiggle pin switches to see if alarm resets.Common problem
Sep 11, 2009 | 2004 Volkswagen Jetta
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
'95 Nissan Maxima-Alarm goes off-then windows & doors won't work
Open the drivers door panel and locate the inside lock cylinder, there is an alarm switch that wrap around it with an electrical wire came out, it might also have another one on the passenger side in some other model . What it does is arm and disarm the alarm when you use the mechanical key and in some other model, it also lower the window when you disarm. The switch might pop out of place or deteriorated due to age. Good luck all.
Mar 22, 2017 | 1995 Nissan Maxima
1999 JEEP GRAND CHEROKEE LAREDO
i have a 95 jeep grand cherokee lerado from time to time my alarm goes off i dont have a remote 4 my alarm but i found out that if you put the key in the driver door and unlock it. it will reset the alarm!!!!!
Nov 19, 2008 | 1995 Jeep Grand Cherokee
Manufacturerscar alarm
My alarm is triggered when I leave the windows down a bit. There's a motion sensor for the interior of the car (I think it's thermal), so when a breeze blows cool outside air through the car's hot interior, it triggers. The interior sensor can be turned off by pressing the button just behind the driver's door and in front of the rear door. Try turning that off and see if it makes a difference. Post a comment with the results.
Jul 01, 2008 | 1999 Audi A4
Door alarm
http://www.repairclinic.com they have schematics diagrams and parts catalogs
Dec 30, 2007 | Viking DDBB363 Bottom Freezer Refrigerator
Viking DDBB363 Bottom Freezer Refrigerator Logo
150 people viewed this question
Top Viking Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Iron
Iron
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
