Whirlpool washer sm8525492 noise when spin cycle brakes
robocop
  • 90 Answers
SOURCE: whirlpool washer wont spin during high spin cycle
Try www.Repairclinic.com.
Posted on Jan 19, 2009
  • 39 Answers
SOURCE: Whirlpool washer grinding noise when draining
there could be something in your pump.....remove the pump and see if there is not something inside...
Posted on Jul 04, 2009
cjrepairs
  • 60 Answers
SOURCE: My whirlpool washer, model #sm8525492-a doesn't
check that there is a rise on the outlet pipe as if this drops onto a low level it may cause the problem you describe.
Posted on Aug 16, 2009
  • 353 Answers
SOURCE: Whirlpool Duet GHW9150P Front Load Washer is
BEARINGS
Posted on Dec 15, 2009
  • 57 Answers
SOURCE: whirlpool cabrio loud noise during spin cycle
The inner bearing will be faulty kindly replace the inner bearings as well as water seal before that kindly check whether the drum is freely moving with out any shaking If you find any shaking means you are suppose to change the drum only
Posted on May 18, 2010
Know when clutch going bad
Needs agitator dogs in agitator.
Mar 13, 2014 | Whirlpool Washing Machines
My whirlpool washer sm8525492 will not spin or agitate
your lid safety switch is bad,remove the control panel,set it back,then remove 2 brass colored spring clips from top cover behind the lid,tilt entire cabinet toward you and remove,lid switch can now be replaced from under the cabinet that you removed
Dec 22, 2010 | Washing Machines
Kenmore 90 series , Brake doesn't engage basket after spin
This assumes that you have a basic Sears / Kenmore / Whirlpool top load, direct drive washer.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the Sears diagram or the following Whirlpool Service manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The washer uses a brake system to stop the basket at the end of the spin cycle.
Just like a brake on a car, it's designed to slip a bit so that the basket / car doesn't come to an abrupt halt.
Over time, the brake shoes can jam against the brake drum and bring the basket to a halt too quickly with a lot of noise.
It sounds as if your brake shoes are worn / damaged.
Following is a description of how to remove the cabinet, pump, motor, transmission and basket drive tube on Whirlpool / Kenmore / Roper direct drive washers.
As an aside, you don't need a special spanner wrench to remove the spanner nut. I've found that a short (10") pipe wrench hooked over one of the spanner nut tabs and tapped with a hammer will usually loosen the nut. Also, rather than hitting the Drive block directly with a hammer, put a short piece of wood under it first to protect it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Following are the Whirlpool Service manual for this type of washer and the Whirlpool parts list for their commercial washers although the consumer models are basically the same.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
I'd pull the drive tube and check the springs, shoes and plastic cam that hooks onto the clutch spring.
Although Sears sells a complete drive tube assembly, you can probably get only the parts you need (shoes) from Whirlpool.
Mar 04, 2010 | Kenmore Washing Machines
Series 70 makes noise at the end of spin cycle when the brake sets it makes aloud rumbling noise.
KENMORE top load, direct drive, neutral drain washers are made by Whirlpool.
A way to solve this (that I tried and it works) is to pull the basket tube / brake assembly and if the brake shoes look OK, spray a small amount of silicone spray on the inside of the brake drum.
Nov 16, 2009 | Kenmore Washing Machines
Kenmore Model 925 75 110 washing machine makes loud noises when the spinning cycle ends (as it stops spinning). Any ideas? Ease of repair ?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
There is also an excellent PDF document from Whirlpool describing how Direct Drive washers work.
We has the same basic problem with a Kenmore direct drive washer. At the end of the spin cycle we heard a loud noise as the brake stopped the drum from spinning.
Sometimes, what can happen is that the brake will grab the brake drum, like a brake on a car suddenly locking a wheel.
The brake is supposed to slow down and stop the drum without locking.
We were able to spray a small amount of silicone spray inside the brake drum, which allowed the shoes to more gently grab the drum.
See GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Remove the cabinet and look at the drum directly above the silver colored clutch assembly.
Using an spray can of silicone spray, and a directional tube, spray a very small amount into the brake drum.
Sep 25, 2009 | Kenmore 22422 Top Load Washer
Washer makes noises
You said, when the washer is going into spin cycle it makes a loud clunking noise. You are wondering if this could be the brakes or possibly the pump?
Sounds like this!
Faulty direct drive Coupling (Whirlpool / Kenmore / Roper / Estate)
The direct drive (motor) Coupling may be broken. Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
it can also be a broken spring or strut dependping on your washes make and type
Please remember to leave a rating
Nov 16, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool washer problem
run the waher in a high spin and lift the lid repeat this three or four times and your brakes will free up and begin working again
Feb 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ8220HQ0
You have to start eliminating them one by one a common reason is the spin tub mounting block if the motor comes on and clutch is driving basket drive and brake assembly than this is the problem.
Oct 04, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
