Question about GE Profile PDW8400J Built-in Dishwasher
My GE Profile Dishwasher is not retaining water and leaking from the bottom.
    Sniper:
  • 73 Answers
Could be coming from the fitting, take the fitting off and wrap it with teflon tape
Posted on Feb 06, 2009
    New Friend:
  • 88 Answers
Take off the bottom panel get a flash light and try to see where its coming from its probably from the plastic pump.
Posted on Jan 11, 2009
Leaking at the bottom in the middle of the door
you need to determine if it's coming from inside the door or under the front of the dishwasher, if the door latch needs adjusting it can get water through the latch slot, the dispenser can work it's way loose and water can leak through it, or the seal on the bottom of the door can get dirt stuck on it which can cause water to leak out.
Otherwise it could be in the bottom of the dishwasher, it is a matter of closer investigation.
Mar 10, 2012 | GE 24 in. Profile PDW7800 Built-in...
Water is coming from the bottom
Take off the panel at the bottem of dishwasher and find leak. If leaking from water supply connection try to tighten it first. If that does not work turn off water under sink and replace warter supply line. You can get a easy to handle braded line at you local hardware store. Replace other leaking parts at www.repairclinic.com.
Mar 24, 2011 | GE Profile PDW8480JSS Built-in Dishwasher
My doshwasher is not draining all the water it
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Jan 12, 2010 | GE Profile PDW8400J Built-in Dishwasher
Dish washer is leaking soap suds from bottom of door and doesnt seem to want to drain
heatman101
Jan 09, 2010 | GE 24 in. Profile PDW7800 Built-in...
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
GE Dishwasher leaking water in the bottom water pump
If it seems to be the water pump, it may be the hose, unless the pump cracked. You will have to pull the machine out, run a cycle and observe to see where the water is leaking from. If the pump housing is cracked you will need a new pump, but if it is only the hose, go to the hardware store and get an appropriate repalcement hose and a new clamp, if you do it yourself, otherwise call the repairman.
Mar 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE dishwaher leaks with standing water in bottom
Check to make sure regular dish soap did not end up getting inside the dishwasher. This will create a lot of suds that will overflow onto the kitchen floor. Standing water from not draining can mean the drain hose is clogged somewhere or the check valve has something caught in it. If you remove the front kick plate, you will be able to check those.
http://tclaundryrepair.com/
Feb 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
Water not draining in dishwasher leaking out bottom
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
ppp
Dec 11, 2008 | GE 24 in. GSD4320Z Built-in Dishwasher
GE Profile PDW8400J Built-in Dishwasher Logo
243 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
