Question about Sewing Machines
SINGER 449 NEEDLE THREAD TENSION REGULATOR ASSEMBLY IN BITS
DIAGRAM PLEASE
  • 69 Answers
SOURCE: How do you adjust the bobbin tension on a Singer
With your slide plate open, you will see 2 screws on the bobbin case. You need to adjust the one on the inside (not the one that sits at the edge of the metal strip). Do so very slightly. If you can't seem to get it adjusted, take a look and make sure there isn't any thread or lint in between the two pieces of metal that the thread feeds through. This can cause a loose tension.
Posted on Mar 01, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
Zenqi
  • 208 Answers
SOURCE: Singer Featherweight tension assembly
Putting this back together is a thirty second job if you have done it a hundred times. If you have never done it but have mechanical aptitude, it may be a challenge.
Whatever you do, don't bend the check spring out of shape!
Below is a link to the Singer site with the schematic for reassembly. When placing the check spring back in place, place it in about the 6 o'clock position with no tension so that it has a fair amount of check before pulling it up in place..
When setting the tension, at a setting of "1" the tension disks should just be slightly compressing the beehive spring. "0" is almost no tension at all. Normal sewing is 5.
Get all of the parts together and push in the cup with the numbers while screwing on the knurled nut taking care to get the pin in one of the holes.
http://www.parts.singerco.com/CPpartCharts/2_2999/221-1_221K1_221K4_221K5.pdf
Posted on Jun 19, 2009
Australian S
  • 46 Answers
SOURCE: Replace the needle thread tension dial
If the entire assembly has fallen out you will find if you remove the top left hand cover that there is a small screw in the casting where the tension assembly goes, replace the tension body to the correct position and tighten the little screw.
Posted on Jul 02, 2009
SOURCE: Just bought machine, new needle, thread, Needle
try sewusa loads of manuals and sewing diagrams. Since its a older machine.I would clean and oil it also.Lint can cause all kinds of issues.
Posted on Dec 29, 2009
Parts Diagram For Needle Shaft.
send ur exact model and brand name ..will get ur schematic diagram soon
Sep 20, 2008 | New Home L-373 Mechanical Sewing Machine
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
It either wads up or breaks
Dear Sir / Madam,
If the needle thread becomes all tangled underneath when you begin to sew there are only a few things that can be wrong.
It is not only Singer machines but most domestics as people only use them occasionally and forget how to thread them correctly.
1) Get out your threading diagram and follow it carefully.
2) Make sure that the needle thread is in between the main tension discs, if it is only running around the edge of the discs the machine will do exactly what you say.
3) Lift the presser foot up with the lever at the back of the machine, this should part the main needle thread tension discs, DO NOT TRY and dismantle the tension assembly if you are not sure what to do.
I suggest you get a bit of fabric or similar and remove any lint that is trapped between the tension disks.
I hope I have helped you, but please contact me if you need more help.
Jul 17, 2009 | Singer Sewing Machines
Jun 30, 2009 | Singer Tiny Tailor TT700
How do you thread a singer merritt 4530 sewing machine
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Jul 14, 2008 | Singer 7462 Mechanical Sewing Machine
I dont know how to thread the singer 2517c sewing machine
sewman7
Jun 30, 2008 | Singer 2517 Mechanical Sewing Machine
I am having trouble threading my singer industrial sewing machine I can't remember how
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.Your Industrial machine has a long groove on one side of the needle. This long groove must be on the left side of the needle when it is inserted properly.
sewman7
Jun 25, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
65 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
