Question about Garden
Cleanforce 1800 pressure washer motor not working
2 Suggested Answers
  • 104 Answers
SOURCE: pressure washer leaks
I had a Karcher water sprayer that did the same thing , the repair man told me it could be repaired IF he could get parts , guess what, he COULDNT get parts so i had to buy another one , the answer to your question is yes they can be fixed provided you take it somewhere that can get parts . hope this helps
ps i could have fixed it myself with the right part, its not a hard job to strip it and rebuild it
Posted on May 26, 2009
Where would I go to get our pressure washer serviced? I live in the Saskatoon, Sask. surrounding area.
Does the electric motor keep running? If it does continue to run with the trigger in the spraying position, then your pressure switch and motor are OK. If the motor is running and the water is not coming out with pressure, then either your check valves are not closing properly or the pumping mechanism is in need of repair. I think those little electrics have a simple wobble plate design. Basically not worth the effort to fix them
Oct 09, 2014 | Karcher 16017720 K3.690 X Series 1800 PSI...
Switch power on and it works and then it switches off and will not switch back on until you leave it for period of time and then it powers up again
This is an indication that it is overheating in the motor. When this happens, very carefully check the temp of the motor and see if it is too hot.
Mar 02, 2014 | Karcher 16017720 K3.690 X Series 1800 PSI...
I have a karcher g3200xh .the motor works ,but the pressure water won"t pressure up.
low pressure usually caused by cracked head but more commonly by dirty or broken valve (two per cylinder) remove and inspect each valve for debris or missing orings etc then replace before opening the next, a short cut sometimes is to blow compressed air through the inlet,
Aug 20, 2013 | Campbell Hausfeld 1800 PSI Electric...
Hookup
For the Campbell Hausfeld 1800 PSI model (PW182500AV), the garden hose connects to the pump inlet on the lower back of the pressure washer. The high pressure hose connects to the high pressure outlet on the lower front of the pressure washer. Here is the operator's manual that will show both connections. http://www.mowersatjacks.com/images/campbell-hausfeld/manuals/pw1825.pdf
May 18, 2013 | Campbell Hausfeld 1800 PSI Electric...
How much oil and gas mixture to use in 1800 psi 2.2 gpm washer where do i put in the oil
it is a 4 stroke motor so it just runs on neat unleaded fuel.
oil is in the engine and this should be 30w oil
Jun 18, 2011 | Campbell Hausfeld PW2102 Gas Pressure...
1800 power washer will not run - power is getting to on/off switch
Maybe just the pressure switch is stuck or you have trapped pressure in the lance. Try without the high pressure hose and then activate the pressure switch on the side of the pump as this may not be letting the machine to statr if its stuck.
Nov 12, 2009 | Campbell Hausfeld 1800 PSI Electric...
I have a Craftsmen 1800 PSI Electric Pressure Washer, Model 580.752020 and it keeps tripping.
Without more information than you have provided, I would think that yoour motor has been damaged by over use or by using too small an electric cord or too long a cord. The overload which is most likely a thermal overload is getting too hot.
Sep 14, 2009 | Garden
Motor runs fine but not pressure other that from garden hose.
you have a unloader or bypass valve on the machine & it sounds like that is sticking.
take out and lubricate
Jun 17, 2009 | RTO 1800 PSI Pressure Washer
Pressure washer leaks
May 25, 2009 | McCulloch MCCFH180B Electric Pressure...
Garden Logo
1,115 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
