Question about Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine
Loading the bobbin
Kenmore is an old sewing machine which uses metal bobbins in a metal chamber. I'm not experienced with sewing machines, and for whatever reason it will and will not work.
Does anyone have any diagrams that can be used? Maybe can forward them to me? Kenmore Ultra-Stitch 6.
Thanks so much!
  • lkaiser680 Feb 02, 2009
    Can't load thread onto my bobbins anymore.
  • Jyackle5
    Jyackle5 May 11, 2010
    Do you have a model #
  • 8,197 Answers
Posted on Jan 11, 2009
I just recieved an older kenmore 24 stitch sewing machine and it has no manual with it , my problem is why wont the machine pick up the bobbin thread ?
You can probably find a manual from Sears. They carry a ton of Kenmore user manuals.
First thing to always try--insert a brand new needle!
Bobbins do usually have a specific way of being loaded. Most machines require the bobbin to be inserted into the bobbin case so when you pull on the thread tail, the bobbin turns clockwise (this is when you are looking at the backside of the bobbin case - at the bobbin). Also, be sure to thread the bobbin thread through the bobbin tension mechanism.
Tip how to put bobbin into the bobbin driver on sewing machine
If the upper thread is not picking up the bobbin thread, it is usually because there is a timing issue (means the needle is arriving at the bobbin at the wrong time to connect with the bobbin thread).
Sewing machine won pick up bobbin thread hook timing fix
P.S.--if your Kenmore is non-computerized (ie, mechanical) be sure to oil using fresh, good quality sewing machine oil or Tri-Flow Synthetic Oil (NOT cooking oil, 3-in-1, WD-40, or old stinky brown stuff that may be in the accessory box). Apply a couple of drops every place metal rubs on metal (while hand-rotating the handwheel). Do NOT oil nylon, rubber, or belts!
Jul 11, 2016 | Kenmore Sewing Machines
Kenmore sewing machine model 158.12260 Manuel
Sears carries many manuals for Kenmore. That's probably the best place to check--unfortunately, they generally are not free.
The sewing machine could probably use a good cleaning and oiling. These old (but great!) mechanicals need 1-2 drops of fresh, good quality sewing machine oil (Tri-Flow Synthetic Oil works great!) every place that metal rubs against metal. NO oil on plastic, nylon, rubber, or belts!!! Simply open the machine's top, left side, and free arm cover (if not a free arm, you'll need to access the underneath of the machine). Gently hand rotate the handwheel toward you and apply a couple drops every place metal rubs metal. Don't forget the lever & dial mechanisms too. Probably, in your case, the bobbin winder mechanism (do NOT oil the rubber tire!). Then you can apply hot air from a handheld hairdryer into the mechanism to help free it up.
Jun 23, 2016 | Kenmore Sewing Machines
How to fill a bobbin on a Rivera 1681?
fill-bobbin-rivera-1681-d05l30nuhtdrvd3uj4vejdej-1-0.jpg These videos may help. Not the same as your machine, but the way older sewing machines wind bobbins are pretty similar.
1 How to wind bobbin on the Brother XL2600i sewing machine
Loading thread on the bobbin old Kenmore sewing machine
Jan 04, 2016 | Sewing Machines
How do I refill the thread bobbin on a Kenmore sewing maching,,model 148-19371
You can try a couple of YouTube videos:
(do not wind the bobbin as fast as he does as it tends to stretch the thread and also could cause the spool to fly off the machine!)
How to wind Bobbin Winder Sears Kenmore Sewing Machine 158 12270 158
or order an Owner's Manual for your machine:
... Sewing Parts Online Search
Sep 04, 2015 | Kenmore Sewing Machines
I cannot wind the bobbin on my old Sears Kenmore 1802 Sewing machine. Help!
put bobbin place and loosen the hand wheel .on the right end of machine
Apr 09, 2015 | Kenmore Sewing Machines
Husqvarna viking sewing machine bobbin
Could the part number be 4011770? I've found the Viking 7 bobbins here: http://www.mysewingmachineparts.com/top-quality-metal-sewing-machine-bobbins-4011770-husqvarna-viking/ . Another site with them is http://www.sewingpartsonline.com/bobbin-viking-4011770.aspx . This bobbin is compatible with the Husqvarna Viking 7, 49, 51, 52, 21 & 21E . It probably will work for other machines. Sears also has them listed as 11770: http://www.sears.com/generic-viking-sewing-machine-bobbins-sewing-machine/p-SPM6124767105?prdNo=1&blockNo=1&blockType=G1 .
I also found these bobbins: http://www.amazon.com/Viking-Metal-Bobbins-5-pkg/dp/B000YZ5QSC . The part number appears to be 1702.
I hope this helps.
(googling Husqvarna Viking metal bobbins found a number of hits.)
Mar 05, 2013 | Husqvarna Viking 1
How to "tune-up" mechanical Kenmore sewing machine
Sure! Jenny at http://blog.sew-classic.com/categories/Sewing%20Machine%20Repair.aspx has several very good, in-depth articles about servicing your own machine, but here are the basic steps:
1. Take out the bobbin case and bobbin holder.
2. Take the needle plate off.
3. Brush out all the old lint in the bobbin area and under the needle plate. Remove any loose bit of thread.
4. Open the head of the machine (should swing open). Clean any lint or thread that's caught in there.
5. Locate your machine's oil ports and put one drop of sewing machine oil (only use sewing machine oil) in each of them. One drop is sufficient. General rule of thumb: Put one drop of oil wherever metal moves against metal.
6. Using unwaxed dental floss, floss the tension disks.
7. Put everything back together.
If you need a manual, I found one at http://pages.sewing-machine-manuals.com/173/InventoryPage/1834489/1.html.
Hope this is useful!
Robbie
Jul 24, 2010 | Kenmore Sewing Machines
Sewing club member starting sewing with a metal bobbin.
Can't say for sure but besides prefrance, I have never seen a differance between metal or plastic in Janome or Elna.
Mar 06, 2008 | Janome Memory Craft 4800QD
Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine Logo
218 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
