Question about JVC Televison & Video
How to remove front panel of JVC HD56FC97
Anyone know how to remove front panel of JVC HD56FC97? I need to clean the dust off mirror. Can't seem to locate the manual for this tv.
Anyone???
4 Suggested Answers
  • 150 Answers
SOURCE: Location of MIrrors in projection tv
wd-52525 This is a DLP, I dont suggest taking it apart to clean anything, this is what we call a MICRO display, the imaging device is about 1" square and blown up 50X to the size of the pix you watch, anytime anyone I know has taken stuff appart where the mirror is at has ended up worse off, you say that there is dust on the mirror, what does it look like in your picture? If the spots are quarter size or so and fuzzy edges the dust is inside the lightengine and you want a factory cleanroom to service the LE, the one thing I think you can safely do is pull the lamp and check for dust on it as it can cause issues in pix, other than that I dunno what to tell you, hope this info helps.
Posted on Jul 09, 2007
  • 1039 Answers
SOURCE: HD-56G787 JVC HD-ILA Help me clean the mirror!
pop the front strip under frnt of screen off. remove screws around back edge off screen and under the frnt of th screen. Usa a micro fiber cloth to clen screen.
Posted on Apr 25, 2009
SOURCE: I have a 56" JVC rear projections HD ILA tv.
Turn tv off and unplug it. Take the access door off either side of the tv. Use a dust cleaning tool like a swiffer with an extension (or make one). Clean off lens (most likely the problem). I have the same thing that happens to my JVC 61". You can use a vacuum with extension if your VERY careful.
Posted on Aug 31, 2009
Need to Clean The lense
If this is a projection TV (DLP or LCD), dust could be on the lens or the mirror assembly. Moving a set can dislodge dust and dirt that's accumulated inside and deposit it onto the lense or mirror. A worst-case scenario would be dust on the LCD chips. Unless you're experienced and/or comfortable opening up the set, I'd recommend contacting a local TV serviceman.
Oct 02, 2012 | JVC Televison & Video
Mitsubishi wd 62527 has very dark picture changed
Clean the small front projection mirror. That mirror can get dust on it and will cause the projected image to appear dull and dim and cleaning that mirror will usually restore the brightness and crisp details in the image.
Oct 20, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Mirror needs cleaning,, how do I get to it? JVC Genessa DILA 52inch projection TV 2004+/-
Problemed solved,,,read on different thread to reach through the access panel and dust of projection lens in the bottom center of TV,,picture looks brand new!
Nov 26, 2009 | JVC AV-56WP74 56" Rear Projection...
May 07, 2009 | JVC Televison & Video
Apr 25, 2009 | JVC HD-56G787 Television
Large dust circle on a Toshiba 50H95 RPTV
No the front panel will only give you access to the CRT circuits. Remove the back panel. UNPLUG your set. You should be able to reach inside (its a stretch for sure) to clean the screen, clean the tubes and if you reach up behind you can actually clean the mirror. This will greatly improve your picture. Do not use windex just a damp soft cloth then dry with a soft cloth. The mirror cleaning is most important to get a nice bright picture. Over the years the mirror tends to get dull. Hope this helps.
Jan 20, 2008 | Televison & Video
Need to disassemble Mitsubishi VS-6041 60 in Rear Projection
Wow, You are asking for a complete disasemmbly. If this is necessary, you have to remove any screws you can find that are connected to the front panel. Usually they are in the top of the set ( you'll find them after removing the mirror panel and mirror ). I wouldn't remove any tubes as the tube convergence would have to be all reset and that would require a cross hair generator. I do hope this has helped in some way, but all I can do is send you my best wishes as I certainaly don't suggest disassembly if there is any other way. Good luck
Ed
NC Electronic
Mills, Wyoming
Nov 24, 2007 | Mitsubishi VS-6041 60" Rear Projection...
Epson livingstation 45" tv
I just fixed the problem on my epson 57" living station. The picture is like new. Yo have to clean the dust off of the the 3 lcd lenses. (I'm not sure if thay are actually called lenses)
You can get to these by entering thru the front of the TV. Yes the front. You must remove the screen. There are A LOT of screws. This screen housing covers the entire front of the tv. and you have to remove the back panel and ALL the screws on the back of the tv to get it off. The only electronics that have to be disconnected are the Speakers and the front control panel. They both have snap connectors. After you remove the entire front panel which houses the screen and expose the inside mirror you will see more screws. You must remove those as well to remove the mirror housing. DO NOT REMOVE THE MIRROR FROM THE HOUSING. Note that there is a peg that is next to a screw in thre front of the mirror housing thst you must pull the plastic housing out in that area to release it.After you remove the mirror housing you will see the 3 LCD panels or lenses. YOU DO NOT HAVE TO REMOVE ANY ELECTRONICS OR SCREWS AT THIS POINT. Use a can of compessed air to spray the dust out of this area. I used a vacume to catch the dust as it flew out in the air. Try to hold the can as upright as possible.Keep hitting it with the air until no more dust comes out. Put the tv back together. As you open up the tv you will see dust everywhere. I took the oppurtunity to clean as much as I could. The Mirror though was clean an I was afraid to touch it.
I am a Construction Salesman yet fairly handy. I have no electricle experience. This took me 2 1/2 hrs. I spent the first 45 min. trying to get to the lcd panels from the back of the tv. Don't waste your time. You can't.
Mar 30, 2007 | Epson Livingstation LS57P2 57" Rear...
Televison & Video Logo
193 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
