Question about Sony KV-36XBR400 36" TV
No red Tv only showing green and blue no red colour
  • kquach797 Jan 25, 2009
    after replace c2027 capacitor it work
    thanks
  • chandras113 Mar 10, 2009
    samsung - super horn model - 21" TV -  12 years old  . only blue & green colour appears ,  red colour  not appear.
    Champion:
  • 240 Answers
Try to resoldier CRT drive Conection on maim board.
also check capasitor c2027 on main board its value is 10uf at 50v
check IC 9001 or tda6111q
this should help a tech out for the repair.
thanks
daniel.
Posted on Jan 12, 2009
Although tv is showing picture the colours only showing background etc are green and blue
Hello
Your TVs red colour output section has the trouble. There is no red output at the red cathode of the picture tube. The red, green, and blue output sections are on the picture tube base board. In some Philips model, these will be consists of transistors, and some has an IC or Tree ICs for three colour output used. You just open your TV, measure the voltages at these three cahodes. There will be markings on the printed circuit board for these cathodes marked as [Rk,Bk and Gk].
In your TVs case the voltage at the Rk marked pin will be higher that the other two cathodes. This can be caused by an open drive transistor or an Ic whichever may ysed there. If it is transistor, just replace it with a same type and number, as in the ace of ICs the related Ic, must be replaced. If only one Ic is uded for red, green and blue outputs, that Ic must be replaced.
If you need any more assistance, feel free to get me through Fixya. Ok.
Dec 01, 2010 | Philips CCB130AT 13 in. Combo
No green and yellow colour
Hello
If you see the picture in yellow colour, means that there is no blue colour output from the video drive section in your tv, Yello is the mixtrure colour of red and green. Green is actualy there. blue colour is absent.
To detect this fault, you must open your tv. Just look in to the video output section, can be located at the picture tube base card, which is plughed into it diretly. See for any loose soldering points there. Check whether transisotors are used for red, green and blue output stages, or an Ic or three seperate Ics are used for this purpose. Anyway, blue catode of your picture tube pin gets a hig voltage, and so the blue emission is absent. You just check the voltages at red,gree and blue catodes, at the respective picture tube pins, which can be taken at picture tube base card. All of these three pin voltages must be somewhat equal to each other. In your case, no voltage at blue cathode will be higher that the other two. Check for the reason. It may be due to an open video output transistor [blue], or an Ic, of one Ic if used for the three colour outputs. Check and replace the same, will rectify your problem. Ok
If you have andy difficulty, get it to me through Fixya. Ok
Gopakumar, India.
Nov 21, 2010 | JVC AV-27230 27" TV
I have seen a problem in my tv is that there is no green colour display in crt. only two colour ( i.e. Red and Blue) or combination may be display. Pl. look into this matter , replay soon
Your problem may related to the green output or driver stage in your tv. Usually green calour is not tranmitted, only blue and red colour informatein are comming from transmitters. Green colour information is regenerated inside the tv by matrix network. If the matrix get damaged no green colour will be displayed. To check first; whether the TV colour picture tube's green gun is right or not. For that you must connect a resistor of value more than 470k 2W, to the green cathode of the picture tube base to earth. The connection should be done causiously, not for a long time. It is advised to do in intermittantly with just touches. When you touch the green cathode with the resistor with one side of it earthed, a green flash must come on the crt. You can do this test for red and blue too. If there is no green flash, or light picture tube may be faulty. It is a very rare case. You must check the volltages of the other two cathodes [red and blue]. The voltage at green cathode must be almost the same as other two.
Just check the green output transistor for open. If it is open, voltage at green cathode will be high. Also check the base voltge of the green output transistor. It should be around 2.5vDC. You can compare the base voltages of the other two transistors with green drive base voltage. If there is no base voltage, the fault should be in the matrix section. It is inside an Ic. Philips usually uses TDA series Ics in chroma section. Check the Ic pin voltages according to service manual and try to rectify the fault. It needs a technical knowledge and skill.
Oct 14, 2010 | Philips Magnavox 27MS343S 27" TV
When using component cables(red, green, blue )
The series of the cable should go green red blue into the back. if you put the green in the red and the red into the green it give the TV a red base to go off of for the picture so everything is red. The reason the green cable won't is because it transmits a black and white picture which allows it a nice base to add the green and red to.
Feb 24, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Picture is OK, but colors are off and there is a blue star background that shows on dark colors.
Hello, With most rear projections there is usually an alignment to do with the set up with your TV. This is so the red, blue and green projectors align together to give the correct colouring. This sounds to me what may be causing the outlining of the blue. This can also make it seem off colour. Look in the set up menu of the tv and see if you can find this alignment feature. Usually a cross will appear and you move a blue, red, and green cross with the arrows on your remote to align over the original white one. If this does not work, it may also mean that one of your projectors, that is the red, blue or green one may be failing causing the off colouring. Hopefully this alignment may fix it for you.
Oct 26, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Problem with a colour display on Hisense tv
If your picures are all purple it means that the green colour is missing. TV colour is made up by mixing Red, Green & Blue. Removing Green leaving Red & Blue makes purple. Study the green colour circuit for a fault and confirm that the green gun inside the tube is working.
Aug 31, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Bush RFT TV
The picture tube of the tv has 3 color in CRT Red, Green, Blue. The red cathodeof tv set has no function, its either the resistor become higt resistance, that why u need a repairman to replace it.
Apr 10, 2008 | Televison & Video
The picture is only producing the basic colours red green and blue
You can start with the make, model and age off the back of
the TV..........................T.
Dec 24, 2007 | Televison & Video
My tv is picture is blue and green
Hi there my t.v has a similar problem, I turned it on and the colours arn't right, there the colours go out in three circles mainly mainly blue, green, red yellow, but depends whats showing on the t.v? Please help.
Apr 17, 2007 | Bush 5693D 24" TV
Sony KV-36XBR400 36" TV Logo
98 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
