Question about Dishwashers
Dishwasher door does a free fall when opened. The tensioning device has broken.
Door spring? broke on a KitchenAid Superba Model# KUDS01FLSS5. How do I fix it? The door on my dishwasher does a free fall when opened. The tensioning device has broken. Anybody know what broke and how to fix it? Thank you.
2 Suggested Answers
SOURCE: Where can I buy the cable repair kit for my Kitchenaid dishwasher
OK, pretty easy fix. Look at diagram 10 here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164885
The link (#24) probably broke and the spring (#18) probably shot off and is lying somewhere behind the dishwasher. Just pull out the dishwasher (careful not to disconnect or crimp any of the hoses) and check to see if both springs (one on each side) can be located. Just replace the old links and re-hook the springs and all should be well.
You can order the link replacement (part #8194001) from kitchenaid at 1-800-422-1230.
Posted on Feb 20, 2009
Falls open when? This unit wom't operate unless the door is secure so I assume you mean the door assist springs are disconnected or broken and the door just falls heavily to the open position after you unlatch it from the closed position. Try these, part 18 here
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDI01FLSS3/0593/0130000/W0503111/00007
should attach to frame in an easy to distinguish hole or slot and to door hinges, number 2 here
http://c.searspartsdirect.com/lis_png/PLDM/W0503111-00001.png
Aug 27, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
Apparently the springs on my door are either not connected or they need to be adjusted. If I were to open the door and not hold it with my hands, it would immedaitely fall wide open. No tension exists on...
I had the same problem on my Dishwasher . There should be 2 screws underneath the top front part of the dishwasher. They hold the unit in place. Easy to get to. Open the door and look up. Pull out the 2 screws that are screwed into the underneath of the front cabinet.
This should allow you to pull (slide) out the unit just enough to see the springs ( aprox 1 ft ) on both sides on the bottom of unit. Inspect the springs. Mine had broke on one side where it clips into the holder.
I just inserted the spring in the proper tension hole to match the other side . I spun it around 1 turn as to hold it in place and then connected the top of spring it its proper place. This gave equal tension on both springs and the door works fine now.
Eventually I will buy a new spring and replace it but at least it works fine for now.
If even one spring has been disconnected the door will fall with out any tension what so ever. I'm guessing maybe just one spring has either come out or broke where it clips into the hole.
Aug 30, 2010 | Frigidaire FDB520RHS Full Console...
Door spring seems to have broken
Yep! What happens is a "T" shaped metal piece that is "screwed" into the spring and serves as an adjustment of tension tears or bends and falls out of the spring(s). Usually one at a time.
If you are clever you can rebend and strengthen this piece and adjust the tension to normal.
Access this by removing the panel below the door where the toe kick is.
The cause of the problem will be obvious and one side will probably still be intact so you can see how they are supposed to be.
May 02, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Superba KEBS277 broken door spring
go to appliancerepairpros.com or repair clinic .com..good luck...
Apr 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
The door spring is broken and the door falls open
there is springs on left and right side held by string and spring. one is broken.letme know how it turned out.
Feb 26, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Mar 26, 2009 | KitchenAid Microwave Ovens
Jan 19, 2009 | KitchenAid 24 in. KUDP01DLBS Free-standing...
Dishwashers Logo
Top Dishwashers Experts
