My remote is powering up but will not operate. I have changed the batteries
  • 236 Answers
Check your remote control using a camera or cellphone camera as your eyes. Point the remote control transmitter to the camera and "on " the remote control. A light should emit in the remote control. If no light is present then the remote is not transmitting or defective.But if the remote emits light then the indoor receiver is defective. And try also the reset or rst button if available in your remote control, just press it and try the remote.
Posted on Jan 12, 2009
My harbor breeze ceiling wont turn on.
  • Disconnect power at the source, not at the fan
  • Remove battery from remote. Press all buttons, then reinstall battery
  • Restore power. Using ONLY the remote, test operation
  • If the fan still does not work, disconnect power again and try every known combination of remote buttons and switch settings until the fan works or you give up in frustration.
Mar 13, 2017 | Dryers
Electricity went out, when restored remote does not work
One of two options here honey... the battery in the remote is flat and needs replacing or... the remote receiving device in the unit was blown, or now has no power to operate. Change the battery... replace the remote... if the problem remains then the problem lies in the controlled device itself. DO NOT attempt this repair yourself.
Mar 27, 2014 | Universal MX-900 Remote Control
Sky box problems
Power off unit, unplug from wall, reconnect and clean sender unit on end of the remote, use smart phones camera to view the end of the remote when you push a button, you should see a change in color on the remotes eye, if not try new batteries again, retest, still no signal, try the other remote.
Nov 30, 2013 | Televison & Video
Skytech receiver batteries keep going dead
Joe,
The heat from the fireplace can have an adverse effect on the life of the batteries. Sometimes simply re-positioning the receiver to a cooler location under the firebox and/or adding a heat-shield can improve battery performance with the Skytech remote receivers.
As a test, you could even place the receiver outside the fireplace for a period of time to gauge the effect of heat on the unit.
According to the owner's manual for the Skytech 3301 Thermostat Remote:
"For REMOTE RECEIVERS that operate on BATTERY POWER, these heat conditions can cause batteries to discharge when temperatures exceed 115 degrees F. Studies show that alkaline batteries, when exposed to a constant temperature of 120 degrees F, can lose up to 50% of their operating power. When the battery cools down, it will partially recharge itself, but constant heating and cooling will reduce the battery's normal life expectancy."
Hope this helps!
Dec 01, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
Reiker ceiling fan - does not turn on - theres is power to unit - maybe remmote is bad? how do i change code
Before trying to change the code, have you tried changing the batteries? Both in the hand held remote and the one in fan housing? If so, and that didn't help, make sure the batteries are turned in the right direction and fitting tightly.
Will the fan operate without using the remote control?
Feb 19, 2011 | Reiker Room Conditioner Heater
Remote control rmt b101a stopped working, changed batteries, same thing; did reset by pressing power, TV i/o and vol- simultaneously, still not working. Help!
Make sure that the Remote is operating in a range of 3 to 10 feet away from the unit.
Point the Remote directly towards the Remote Sensor of the Device.
Remove any obstacles that may be in the path of Remote and the Sensor.
Make sure that no interference is blocking the Remote to operate normally. Do not expose directly to Sunlight, bright florescent lights etc.
Try resetting the Remote by removing the batteries from the Remote control, press every button twice, and then re-install the batteries after 1 minute.
Make sure that none of the buttons on the Remote control is jammed.
Install fresh alkaline batteries in the Remote, do not use rechargeable batteries.
Make sure that the batteries are inserted by matching the polarity (+ & -).
Try resetting the Blu-ray Disc Player with which you're using the Remote.
If the issue persists, after all the possible troubleshooting steps, service may be required.
Thanks for using FixYa
Dec 03, 2010 | Sony RMT-B101A Remote Control
My 1.5 IR Dish remote has all of a sudden stopped working with our Sanyo tv. I've changed the batteries. When I push the power button it will only light up the VCR button if anything at all. Our other...
sandyannsamp
If the VCR button lights up when you press the Power button, you are not in the correct mode to operate the TV. If the remote is programmed correctly, when you are in SAT mode, you can press the large RED button to turn your receiver off/on. The RED TV button will turn your TV off/on. I have provided links to program your remote to your TV again. I have also provided codes for your Sanyo TV.
Instructions to program your remote to your TV (begin with step 6):
http://www.dishnetwork.com/SupportSection/remote-setup
Here are the TV codes: 590, 683, 589, 542, 652
I hope this helps.
Ray Calo
DISH Network
Nov 18, 2010 | DISH Network IR Remote Control
Viewsonic remote RC00070P
Okay here's the fix.
Remove batteries. Re-install them wrong side in! Don't panic.
Reverse the direction of both the battery cells and install. Press "Power" button a couple of times and a few other buttons a few times. Then remove batteries and re-install the right side in.
Voila.
Jun 10, 2008 | Televison & Video
Remote Control Problem
take the batteries out of the Sharp remote press and hold the POWER button on the top of the remote for 5 seconds. Put batteries back in. Make sure that function is set to TV. Should work - if not call Sharp. If you are inside the original manufacturer warranty they will replace remote
Dec 21, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Heating & Cooling Logo
359 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
