Question about Sewing Machines
Value of sears Kenmore sewing machine model 158.904
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
SOURCE: Kenmore sewing machine manual for model # 148 12080. (older)
i have a older kenmore sewing machine model #148.19370
Posted on Sep 17, 2008
SewTechWayne
  • 186 Answers
SOURCE: Kenmore Sewing Machine Model #158.18032
You probably have a bind in the feed dog mechanism. If you can remove the covers and manually force them down you will see the hinge points that need to be oiled.
Unplug first!
Good luck.
Posted on Jan 30, 2009
SOURCE: 1964 sears suburban 725 riding tractor model # 917.60634 manual. Sears Kenmore vintage sewing machine manual model# 148.12071.
go to www.sears.pammar.net for a few bucks he will send you the manual in a pdf. format
newbeginning1983@yahoo.com
Posted on Apr 04, 2009
  • 980 Answers
SOURCE: I need a manual for a Sears Kenmore sewing machine model 148.231
Try www.sewing-machine-manuals.com and click on relics and don't be put off by the word relics
Posted on Oct 24, 2009
Tip
Good Sewing Machine
Looking for a good, used, sewing machine? The Sears Kenmores from the 1970s are a good value. Even if you have to take it in to be serviced, you have an all metal machine that will last another 40 years. In addition to being solid, the Kenmore models had stronger motors, making quick work out of a project.
on Mar 05, 2015 | Singer Sewing Machines
Looking for a manual for sears kenmore portable sewing machine model 158.13200
Search the internet for:
Manufacturer + Model + the word "Manual"
Nov 22, 2015 | Kenmore Sewing Machines
Sears/kenmore sewing machine 158.17033 i ned a manual for it?
i am also looking for a manual for the sears kenmore sewing machine model number 158.17033, I just got one for $7.99
Nov 20, 2011 | Sewing Machines
E1, E2 error messages after needle breaks. Cleaned everything as good as possible, still getting message. I have a Kenmore Model 385.19233
Theirs a problem with the fuse on those machines. The e1 indicates that a fuse has been blown. check out the link for more details.
http://www.sewingmachineryrepair.com/forums/index.php?topic=79.0
Aug 31, 2009 | Kenmore 19233 Computerized Sewing Machine
Kenmore sewing maching model 158.904
I bought mine at Walmrt. They are a Singer product and says it will fit most machines. There are 2 belts in the package and the small one is for bobbin winders. I have a Kenmore 158,904 and it fits perfect.
Nov 10, 2008 | Kenmore Sewing Machines
Sewing Machines Logo
236 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
