Question about Video Cameras
Panasonic rx ed77 keeps eating tape.
Both cassette players have same problem, plays cassette for 10 sec reverses direction then eats the tape. It appears the spindles don't move but rollers do.
bmwrider
  • 215 Answers
SOURCE: Eating the tape
It sounds as if the takeup spool isn't doing it's job. It could be caused by a slipping belt or slipping clutch assembly. Unless you know your way around the unit (internally) I'd advise a repair shop have a look at it. BMW
Posted on Jun 07, 2006
philipp
  • 217 Answers
SOURCE: samsung camcorder
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Posted on Sep 14, 2007
  • 64 Answers
SOURCE: Remove Cassette Error
I repair gl2s for canon and when you get a remove cassette message 9 times out of 10 it is 2 gears on the m-chassis that have failed they spit oil all over the inside and then the gear comes in contact with the m-chassis and binds up they are both white and in the middle you can see one when you open it and the other is on the inside that you cant see unless you take take the cover off and thats why you get that message but the ribbon part is something else that needs to be looked at you should send it in to a qualified canon repair facility. tell them the chassis is defective its actually code D106, E52, send those codes in with canon and make sure they see them.
Posted on Nov 16, 2007
  • 73 Answers
SOURCE: Samsung sc-d353 Eats Tapes
THIS NEEDS A NEW CASSETTE COMPARTMENT. SAMSUNG IS REALLY EXPENSIVE. YOU MIGHT TRY TO PURCHASE A USED ONE OR I MIGHT BE ABLE TO HELP YOU WITH PARTS
Posted on Feb 23, 2008
  • 4234 Answers
SOURCE: cassettes tapes not moving in my Panasonic RX-ED77
If you can her the motor turning, there is a good chance that the belt(s) have broken and need to be replaced. If you hear nothing, then there could be a control issue. I'm leaning toward the belts though. Figure on $5-$15 for the belts,
Dan
Posted on Mar 18, 2009
Cassette tap in my vcr get eating
The unit has a bad transport mechanism--it among other things moves the tape in play etc and when ejected winds the tape back into the cassette.
Could be bad belt/s or a bad idler made of rubber that does this type of function.
If a old unit may be better to replace if you can find one new.
Apr 16, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
The auto stop mechanism seems to have completely stopped working. When play a cassette, it eats it. When you put the deck into play mode without a cassette and push on the pinch roller with your finger, it...
When's the last time it was cleaned? It surely needs it now.
Never touch the any part of the transport that directly contacts the tape with bear fingers.
This sounds like a failure of the take-up (left) reel to take up slack as it's fed in by the capstan.
You can probably trust the machine to fast forward or rewind a tape to test the ability of the reels to manage slack since either action only requires one reel to pull while the other just coasts. Failure would look like stationary tape that eventually would time out and reset the command.
If it won't do fast transport motions that eliminates the capstan/pinch roller.
If it CAN FF and REW then the capstan, pinch roller, heads or something is probably glommed up with sticky tape oxide, which brings us back to the first question.
Jun 30, 2011 | Panasonic RX-FS470 Cassette Boombox
The machine is damaging the pressure pad and or eating cassette tapes.
These units are just like cassette players and have rubber parts inside. This unit should be overhauled. A good cleaning along with replacement rubber parts should resolve the problem. Figure on $10-$20 for parts.
Dan
Aug 24, 2010 | Panasonic RR-930 Desktop Cassette...
Why does the cassette player eat tapes?
Because the tape doesn't roll smoothly, causing the tape to be eatin by the cassette player.
Jun 05, 2010 | Panasonic RQ-SX67V Personal Cassette...
Will not eject cassett
try this unplug and then keep finger on eject and plug back in keeping hold of eject if not work then
UNPLUG and take top off video and you will see were the tape is stuck THERE WILL BE A RUBBER BELT ON ONE SIDE OF MECHANISM TURN COGS THAT BELT ARE ON ( USELY ANT-CLOCK ) takes time you will see parts move towards front of video ( IF NOT CHANGE THE DIRECTION TURNING ) the tape will come out when finished
THEN PLUG IN SO VIDEO CAN RESET MECHANISM
Nov 08, 2009 | Cell Phones
Cassette player is eating tapes
Hey there.
Cassette head cleaners generally only improve the sound quality on playback. This problem sounds more like something mechanical; I would open the player and check out the capstan and rollers. If they are dirty, clean them with a mild soap and water solution, (carefull to not get it too wet). Also, as for the tape deck in your vehicle, OEM systems are notorious for eating and destroying cassette tapes.
Let me know how this goes over,
HortonA!
Mar 22, 2009 | Audio Players & Recorders
Cassettes tapes not moving in my Panasonic RX-ED77
Dan
Mar 18, 2009 | Panasonic SA-XR55 Receiver
IT PLAYS TAPES SLOW
can i buy your panasonic rx-dt75. i have that model almost 15 yrs to me made in japan. but this past few months cd and tape do not work... contact me here +639392859269
Jan 06, 2009 | Panasonic Portable Radio/Cassette Player
Video Cameras Logo
43 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
