Question about Hitachi Televison & Video
Hitachi Rc1050 remote control not working
Remote fails to switch on tv from standby
spare_head_2
  • 47 Answers
SOURCE: tv on standby
Hi Kjunse,
The Television may be faulty, but without reading the manual I can't say for sure. If you want to risk spend some money to find out, here is a link to a website selling the remote control you require for the GF70-600 TV. I've not had any dealings with the company but you could always contact them to check your buying an original (OEM*) Grundig remote before you buy one.
*OEM means, Original Equipment Manufacturer.
Hope this is helpful.
Regards,
Spare head 2.
Posted on Jan 04, 2008
SOURCE: Remote Control for Denon AVR-5800
Phillips Pronto TS-3000 Better than the original !
Posted on Jan 17, 2008
alocenar
  • 293 Answers
SOURCE: Unitron TV
buy a universal remote control it is available anywhere
Posted on Apr 01, 2008
SOURCE: hitachi tv
I have the same problem. I got mine from a friend and my comcast universal remote does not work with it at all. For some reason it does not acknowlege it.
Posted on Jun 10, 2008
keemo68
  • 1263 Answers
SOURCE: Hitachi LCD Television
it appears that your power supply module is malfunctioning this seems to be a common problem. you need to replace it have a local tech replace it for you
Posted on Sep 01, 2008
Codes for chunghop E-H918
0168 0171 0178 0182 0186 0203 0213 0218 0219 0231 0233 0238 0309 0379 0456 0475 0611 0613 0622. Check these codes. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. Do a search by type in the brand name of your device at its search box.
http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/
Jun 09, 2014 | Televison & Video
Looking for a sky remote control code for beko.
Hello
The three digit Sky remote code for Beco TV are:
514 398 065
Four digit code is:
0125
1* Turn your TV and SkyHD box on and press tv on your remote control.
2* Hold down select and the red button together until the red light on your remote
control blinks twice (this is after about two seconds).
3* Press tv again.
4* Key in your TV's brand code. The light on your remote control blinks twice.
5* Press standby on your remote control.
If your TV switches off, press select.
The light on your remote control should blink twice.
If your TV does not switch off, press tv, then press standby.
Repeat the sequence of pressing tv then standby until the TV switches off,
then press select.
If the light blinks three times, your remote control has checked all the possible
settings for the code you used. Check you have the right code and start again
at step 1.
*6 Turn your TV back on and press the tv guide button on your remote control.
The TV Guide screen appears, meaning the remote control settings have
been reset.
Aug 12, 2011 | Televison & Video
I have a hitachi 50 "plasma that was given to me
First do you see a light indicating that the TV has power? There are two power buttons on the TV (the main power and the regular power button). The red standby light will light up when the main power switch is on. This indicator is just to the left of the remote I/R sensor. You can find the main switch on the bottom front of the tv (it is under the tv forward of the stand). Turn on the Main power if it is not on. Then try the power button on the control panel of the TV again.
Does the standby light change color or blink? (Red is standby, orange is power savings (no signal), blue is on.) If the main switch is on and the standby light doesn't come on, the TV has a problem at the power supply. Try unplugging the unit for a bit (at least 30 seconds) and then plugging it back in. This will reset the internal circuitry. If you see a blinking light, then the TV is reporting a self-test failure. I do not know the codes for this model Hitachi Plasma TV.
The manual for the Hitachi P50H401 TV is available from Retrevo: http://www.retrevo.com/support/Hitachi-P50H401-TVs-manual/id/1233ci869/t/2/ . You will need to enter a code to access the pdf.
I'm assuming you don't have one of the special versions that were intended for large audiences that were only controlled by remote (no control keys on the front of the TV). Remotes.com has the original remote or a substitute remote if you need it. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13104063628240&smodel=P50H401&brand_pn=HITACHI_P50H401 .
I hope this helps.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
What is the code for LG 37LE4500 TO WORK WITH SKY REMOTE CONTROL
I also have an LG TV. I used this 4 digit code: 0742.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Mar 12, 2011 | LG Televison & Video
TV will not come on via the remote control and remains in standby
Try switching it off at the main switch on the TV. Then switch it back on from the same main switch on the TV. If the TV then comes on & works normally, then check the batteries in your remote control, they may need replacing.
Mar 28, 2009 | Samsung LE32A41B 32 in. HD-Ready LCD...
Hitachi CLE984
The code you need is 0145
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Jul 01, 2008 | Hitachi CLU-5713TSI Remote Control
Remote code
You won't be able to use it for your dvd player unfortunately.
The code for sky is 0145.
Gaz
Jan 14, 2008 | Hitachi CLU-4324UG Remote Control
Televison & Video Logo
26 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
