Question about Bosch Water Heaters
Error code 63 on Bosch 32q
No hot water. Error message 63
2 Suggested Answers
SOURCE: Bosch hot water service error code 90
I can help steer you to resources, including Bosch contact numbers and possibly your manual and other helpful information:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Posted on Jun 20, 2011
250sxng
The display should show an error code. Here's a list http://hometips.me/Tls/Bosch-error-codes.pdf
Feb 16, 2014 | Bosch & Tankless LP Hot Water Heater
My bosch tankless water heater is flashing ae
Before calling service technician, open following links for Bosch error codes, and contact information, and possible product manual for your model, etc:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Bosch_EA_error_code_troubleshooting.pdf
http://waterheatertimer.org/pdf/Bosch-GWH2400ES-error-codes.pdf
http://waterheatertimer.org/pdf/Bosch_A4-E4_error_code_troubleshooting.pdf
Error code AE is not shown, but error EA means "burner flame not recognized by control unit when water is flowing"
There is also error A3 and A3 E3: jumper connection is not correct
Sep 26, 2011 | Bosch & Tankless LP Hot Water Heater
No hot water at all when I turn on the hot water faucets nothing nomad I would hear the burner kick on but nothing what so ever
Before calling service tech, open following links for Bosch troubleshoot resources including phone support, error codes, possible manual.
No error code can mean PC board failure, or plumbing problem
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Aug 13, 2011 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
We have to reset daily A-7
Before calling service technician, open following link for troubleshooting resources including error codes, manual, links to bosch, phone number, :
A7 is outlet temperature sensor fault.
Temperature below freezing or above 210 degrees F
1) Check red wire connections at hot water temperature sensor. Clean terminals with an eraser. If badly corroded, replace sensor and wire harness. (See Fig. 63, page 46 in manual).
2) Sensor may trip if water temperature drops below freezing to protect heater from freezing conditions. Any damage due to freezing conditions is not covered under warranty.
3) Clean inlet filter screen and clear any debris out of shower heads, faucet aerators and whole house filters.
4) In areas where water has a high mineral content, periodic descaling may be necessary.
Apr 17, 2011 | Bosch AquaStar 2400ES-NG
Pilot OK main burner does not flare when hot tap turned on
If you are not getting error code, then problem could be plumbing.
Many internal and external factors can also cause tankless problems without error code.
Circuit board failure, sensor failure, incoming air, venting, gas flow, water pressure, water flow, or combination of factors.
Open following link for Bosch troubleshooting resources.
Add a comment with your experience to help others with same-similar problem.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 25, 2011 | Bosch & Tankless LP Hot Water Heater
Getting an A7 error code and no hot water
1) BOSCH error code A7: Outlet temperature sensor fault (Temperature below freezing or above 210?F).
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
a. Check red wire connections at hot water temperature sensor. Clean terminals with an eraser. If badly corroded, replace sensor and wire harness. (See Fig. 63, page 46 in manual).
b. Sensor may trip if water temperature drops below freezing to protect heater from freezing conditions. Any damage due to freezing conditions is not covered under warranty.
c. Clean inlet filter screen and clear any debris out of shower heads, faucet aerators and whole house filters.
d. In areas where water has a high mineral content, periodic descaling (de-liming) may be necessary.
2) Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
3) Bosch problems at Fixya:
http://www.fixya.com/support/p949576-bosch_1600h_lp_liquid_propane_aquastar_a/solutions
4) Read manual cover to cover
and make sure maintenance is scheduled.
For example de-liming is recommended each year.
Utube search de-lime tankless water heater
Add a comment for more free help.
Mar 10, 2011 | Bosch AquaStar 2400ES-NG
Water Heaters Logo
107 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
