Question about HP Compaq 6910p Notebook PC PC Notebook
How do i download a recovery disc for hp compaq 6910p
I get bootmgr missing erro after formatting the hard drive. i need a recovery disc so how do i downlod it, please?
    Master:
  • 340 Answers
You don't. You should have created a recovery disc thru the control panel before you formatted the hard drive. Now you will have to purchase and reload the windows operating system.
Posted on Aug 20, 2016
    Top Expert:
  • HP Master
  • 26,256 Answers
You may be able to purchase one through ebay.
SOURCE: How to replace the Keyboard?
i have a hp 6910p laptop and need to know what screws to remove.
Posted on Nov 17, 2008
  • 20 Answers
SOURCE: HP Compaq nx6310 Notebook PC recovery disc
You can try pressing the F8 key at bootup to get the boot screen, and select the option " use last known good configuation" and press enter. if that dosn't work, you can do the same thing only select SAFE MODE and press enter, an that should get you into windows. then you an go t Start/accessories/systemtools/system restore, and restore th system back to a date before your problem started.
Posted on Jan 19, 2009
  • 165 Answers
SOURCE: touchsmart tx2-1025dx bootmgr missin
Please go to the link below to know how to run destructive recovery. PLEASE NOTE THAT YOU WILL LOOSE ALL DATA IF YOU RUN THIS.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00809678&lc=en&dlc=en&cc=us&product=3860702&rule=27693&lang=en#RecoverOS
If you do not want to loose data, You will need a Vista installation DVD to resolve this issue. You may borrow it from someone.
Following are the steps:
Method 1:
Repair the BCD store by using the Startup Repair option
You can use the Startup Repair option in the Windows Recovery Environment to repair the BCD store. To do this, follow these steps:
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
2. Press a key when you are prompted.
3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next.
4. Click Repair your computer.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Startup Repair.
7. Restart the computer.
Method 2:
Rebuild the BCD store by using the Bootrec.exe tool
If the previous method does not resolve the problem, you can rebuild the BCD store by using the Bootrec.exe tool in the Windows Recovery Environment. To do this, follow these steps:
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type Bootrec /RebuildBcd, and then press ENTER.� If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type Yes. A confirmation message appears that indicates the entry was added successfully.
� If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command.
Bcdedit /export C:\BCD_Backup
ren c:\boot\bcd bcd.old
Bootrec /rebuildbcd
8. Restart the computer.
Method 3:
Rebuild the BCD store manually by using the Bcdedit.exe tool
If the previous method does not resolve the problem, you can rebuild the BCD store manually by using the Bcdedit.exe tool in the Windows Recovery Environment. To do this, follow these steps:
7. Type the following command, and then press ENTER:
cd /d Partition:\Windows\System32
Note Partition represents the letter of the partition on which Windows Vista is installed. Typically, this is partition C.
8. Type the following command, and then press ENTER:
bcdedit /enum all
In the Windows Boot Loader section of the output from this command, note the GUID that is listed for resumeobject. You will use this GUID later.
9. Type the following command, and then press ENTER:
bcdedit -create {bootmgr} -d 'Description'
Note Description represents the description for the new entry.
10. Type the following command, and then press ENTER:
bcdedit -set {bootmgr} device partition=Partition:
Note Partition represents the letter of the partition. Typically, the letter is C.
11. Type the following command, and then press ENTER:
bcdedit /displayorder {GUID}
Note GUID represents the GUID that you obtained in step 8.
12. Type the following command, and then press ENTER:
bcdedit /default {GUID}
13. Type the following command, and then press ENTER:
bcdedit /timeout Value
Note Value represents the time in seconds before the Windows Boot Manager selects the default entry that you created in step 12.
14. Restart the computer.
**Please rate the solution**
Posted on Mar 24, 2009
  • 909 Answers
SOURCE: Compaq Presario CQ60 recovery disc how to use
insert the disc into the drive, restart the computer.If it doesn't boot from disc, restart again.
As it restarts, press and hold F8(may be F2 or F12 depending on the settings)until the boot options screen appears. Using the arrow up/down keys select drive "d" or what ever drive letter represents the drive you put the disc into.
It will now(or should) continue to boot from the disc, follow the onscreen instructions to restore.
Posted on Aug 27, 2009
SOURCE: HP Compaq 6910p New hard drive installed, XP os
Method 1 :  Go to BIOS and set anything with SATA disable (usually find uns=der advance setting in IDE configuration setting).
Save the setting.
Windows Xp will detect your hard drive now.
Method 2 : This days BIOS comes with only few thing to configure.if that's is the case.
Download SATA driver,here is the link
http://download.cnet.com/SATA-Driver-Intel-Ver-7-0-0-1020-zip/3000-2122_4-162224.html
you need one more software called "nlite" in order to integrate the SATA driver in Windows XP CD so that it recognize SATA drives.
Here is the link for nlite download
http://home.midmaine.com/~nlite/nlite/nLite-1.4.9.1.installer.exe
On how to intergrate SATA driver with windows XP
Go to this page :
http://www.nliteos.com/guide/part1.html
Rate this answer.
Posted on Dec 28, 2009
Testimonial: "Dear mr Singh. Thank you for your verry prompt reply, your first method fixed the problem I had, you are a true Expert. Yours Steve Smith"
My presario cq57 wont boot to windows and there are no recovery discs, how can i reformat the hard drive?
the only way to format is using the CD,before formatting download the network drive from HP so the you can download other softwares after formatting
Jan 27, 2013 | Compaq Presario Cq57 Notebook Pc
Smart failure.. bootmgr is missing..I have recovery discs but dvd player is not working
Yes, you can make USB boot drive. However main problem is the Smart... error. It is your hard drive. You need to fix that first! Try reseating the drive. Next go into BIOS by pressing F key during boot. Might be F2? Make sure BIOS recognizes the hard drive.
Once you get the drive going again, you can start the install / repair again. USB drive tool.
http://www.microsoftstore.com/store/msstore/html/pbPage.Help_Win7_usbdvd_dwnTool
Oct 11, 2012 | Computers & Internet
I can't install any OS. it says BOOTMGR is
You will need an operating System Disk or Repair disk because you need to get to a Dos Command Prompt (black screen with white lettering) and type the commands below. Press ENTER after each command.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not, run the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 01, 2012 | HP Computers & Internet
Bootmgr missing on hp pavilion slimline s5503w
This document pertains to HP and Compaq desktop PCs that came with Windows 7.The following error opens when attempting to start the PC:BOOTMGR is missingPress CTRL+ALT+DEL to restart the PCIf you recently installed an additional hard drive, turn off the computer and remove the drive before using the following steps:
  1. Open HP System Recovery:caution.pngCAUTION:Do not perform a system recovery! Stop at the first recovery screen.
    • Press the F11 key repeatedly while the computer is starting.
    • If you have a recovery disc, turn on the PC and insert the first recovery disc into the drive. Use the disc to enter the system recovery.
  2. Select Microsoft Startup Repair tool and wait for repair to find and fix errors. When finished, restart the computer; even if the startup repair tool finds errors but cannot fix them.
  3. If the error message persists, open the recovery manager screen as was done in step 1.
  4. At the recovery manager screen, press ALT + D.
  5. Enter the following text at the command prompt: bootrec /rebuildbcd
  6. If bootrec displays "Add installation to boot list?", press y .After bootrec completes successfully, the computer displays "The operation completed successfully".
  7. To close the command prompt, enter the following text: exit
  8. At the Recovery Manager screen, select Microsoft Startup Repair tool (again) and wait for startup repair to find and fix errors. When finished, restart the computer.
  9. The error should no longer open. If it does, perform a system recovery, making sure to backup important files.
If you removed a hard drive before using these steps, replace the drive. If the error occurs again, make sure the additional hard drive is not set as an active drive. Only the main bootable drive should be set as active.
Feb 10, 2012 | HEWLETT-PACKARD Pavilion Slimline s5503w...
Bootmgr is missing
If Office Depot "cleaned" your hard disk, then there is nothing remaining on it. You will need to load the recovery media cd/dvd's you created or purchased in the proper order to have them restore the computer back to its initial configuration when you purchased it. Put the first CD/DVD into the drive and then power off the machine & power it back on. The installation should begin. I'm sad OD wiped out your mothers drive.
Mar 18, 2017 | Samsung (SP1203N) 120 GB Hard Drive
BOOTMGR is missing
This may be due to the reason that your Compaq model is only Vista or Win7 Compatible.I didn't get your question properly but as you're having no windows or DOS in your machine.All you need is a Bootable Windows Disc and a working DVD rom to get this done.Cause commands or anything else will require that and even if you fix it with some tricks. Some Other file missing message may appear. But if you just want to push yourself. Normally are Booting files are in the root folder in my case it's in C:\ like NTLDR BOOT.ini BootSect.dos so try to access your root drive.
Dec 30, 2011 | HP Compaq nc6220 Notebook
Bootmgr is missing after i have formatted my hp pavilion and i cant get it to install vista again
reinstall from disc, with formatting partion C, but keep your files,, i think you have formatted it from recovery partion. maybe recovery partion is not good
Jun 13, 2011 | HP Pavilion dv9500 dv9600 and dv9700 FF...
When i am start my hp pavilion this shows Bootmgr is missing alt+cntr+del to restart again it same cycle
1. Error: BOOTMGR is missing:
??¢ If you recently installed an additional hard drive, turn off the computer and remove the drive before using the following steps:
??¢ Open HP System Recovery:
??¢ CAUTION: Do not perform a system recovery! Stop at the first recovery screen.
- Press the F11 key repeatedly while the computer is starting.
- If you have a recovery disc, turn on the PC and insert the first recovery disc into the drive. Use the disc to enter the system recovery.
??¢ Select Microsoft Startup Repair tool and wait for repair to find and fix errors. When finished, restart the computer; even if the startup repair tool finds errors but cannot fix them.
??¢ If the error message persists, open the recovery manager screen as was done in step 1.
??¢ At the recovery manager screen, press ALT + D.
??¢ Enter the following text at the command prompt: bootrec /rebuildbcd
??¢ If bootrec displays "Add installation to boot list?", press y .
??¢ After bootrec completes successfully, the computer displays "The operation completed successfully".
??¢ To close the command prompt, enter the following text: exit
??¢ At the Recovery Manager screen, select Microsoft Startup Repair tool (again) and wait for startup repair to find and fix errors. When finished, restart the computer.
??¢ The error should no longer open. If it does, perform a system recovery, making sure to backup important files.
??¢ If you removed a hard drive before using these steps, replace the drive. If the error occurs again, make sure the additional hard drive is not set as an active drive. Only the main bootable drive should be set as active.
Dec 12, 2010 | HP Pavilion Ze4900 Notebook
As soon as computer is turned on the message bootmgr is missing press ctrl alt del to restart
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
i strongly suggest formatting your hard disk drive, and reinstalling the recovery CDs
if you dont have them, get Dell to send them to you -- it will cost you money
Oct 16, 2010 | Dell Inspiron 1545 Notebook
Wont boot up
If you have a windows vista disk handy this is how you repair this.
Boot from the Windows Disk
Select your language > Next
In the lower left hand side click
If you do no have a Windows Vista Disk you will need a computer with a working CD burner to download and burn a Windows Vista Recovery disk with. You can find one for your computer here:
http://neosmart.net/blog/2008/download-windows-vista-x64-recovery-disc/
Feb 04, 2010 | HP Compaq 6720s PC Notebook
HP Compaq 6910p Notebook PC PC Notebook Logo
409 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
