Question about Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher not completing the programed wash, Now won't restart.
The dishwasher was started late in the evening and in the morning, found to not have completed the wash. Detergent still in the cup. Multiple attemps to srat again have failed. It is not responding to anything. I don't have a book to troubleshoot. Is there a reset button or do we need professional help?
  • David Parenti May 11, 2010
    There is no reset on that unit you will have to get a service call on this one. but do you know if the d/w is washing or draining water?
    dmparenti
  • Randy Hough
    Randy Hough May 11, 2010
    Have you checked the breaker in the panel box?
  • 54 Answers
There is not a reset button, but you can try by holding both drain and one of the wash cycle.. hold it for a few seconds.. keeping trying drain and another, and another.... you will hear drain motor draining water out... if there is standing water at the bottom... if the cycle stopped after wash cycle, its usually your control... hope this help...
Posted on Jan 21, 2009
Electrolux dishwasher not completing wash cycle and all lights flashing on door control panel and the 'wash pump' error light behind the lower kick space panel was flashing.
Good Morning friend, thanks for your post!
After researching the issue you are having with your Electrolux dishwasher it is possible that resetting your appliance may help. I would disconnect power from your dishwasher by unplugging it or flipping the household breaker for roughly ten minutes. If this does not resolve your issue I would recommend seeking assistance from a professional to properly diagnose and repair your dishwasher. -T
Jan 23, 2014 | Electrolux Dishwashers
Dishwasher restarts a new programme after finishing previous
try to reset program..... hold off button for 2 seconds or so..... until it turns completely off....
it this won't help, try to disconnect it from outlet..... wait few minutes,... connect it back to wall and try again
Jan 13, 2014 | AEG Dishwashers
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
Good morning, I have a GE dishwasher and lately
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jun 29, 2011 | GE 24-7/8" Convertible Portable Dishwasher...
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
LG dishwasher doesn't heat water
I had the same issue with my LDF7811 about 2 years into its life. I replaced the heating element and that took care of it. Not a terribly difficult job, but it will require removal of the dishwasher and dismantling it from the underneath.
Dec 18, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Hi,i have a SMS6032GB dishwasher,it keeps sticking during the wash cycle & go on for ages.
I think I had the same problem on the same model of dishwasher.
It would stop part way through the cycle and finally would not even begin to fill at the start of a wash.
Turned out to be the Water Inlet Solenoid Valve. I proved this by using a jug to fill the dishwasher up to the level of the heating element - it then completed that part of the cycle successfully.
The valve wasn't too hard to change. It is under the 'kick plate' at the front of the machine. Bought a spare from ebay for £35.
I know this is a late reply, but I came across it when I was searching for a solution - but there wasn't an answer.
Sep 03, 2008 | Bosch Washing Machines
Dishwasher tablet seems to be released too late in cycle
I would check that the sump screens are cleared and wash arm holes arent obstructed.Also during a cycle check the water level of the dishwasher.Let me know if you have any other questions.HAPPY HOLIDAYS!!
Dec 03, 2007 | AEG 23 in. Favorit 86070Vi Built-In...
Machine won`t fill
the water-inlet solenoid valve is inoperative-replace it
May 30, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
257 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
