Question about Philips Audio Players & Recorders
Audio pc400 connector broken
8 pin connector on a Philips Audio Pc400 speaker is broken. Where can I buy a replacement online?
SOURCE: PCC266 = PC400?
u8668.exe
Posted on Aug 31, 2008
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
SOURCE: HOOKING THE FRONT PANEL CONNECTORS UP ON A PC
look carefully on the mainboard for any connectors. & every connectors have their connection manuals printed onboard.
Posted on May 02, 2009
frankzjm
  • 191 Answers
SOURCE: Sony Vaio VGN 'B series' - broken headphone jack.
Hi there, your question has two way you can fix it:
1) see speaker jack circiut on your motherboard, picture here
there are 5 pins to the jack socket, you may just find out 2 and 3 pin which is stereo audio output lines, and also need a ground 5 pin. then connect 3 wires go outside speaker. this way quite tough for you.
if you cannt do this way go next
2) find a USB audio card instead of onboard one. this is very easy.
reference here:
http://shop.ebay.ca/?_from=R40&_trksid=p3907.m38.l1313&_nkw=usb+audio+card&_sacat=See-All-Categories
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
Posted on May 24, 2009
  • 5603 Answers
SOURCE: broken pins on orange 9 pin din
Try this site:
http://www.action-electronics.com/ppdin.htm
Posted on Sep 05, 2009
Manual for model Pc400
Try Googling (brand)(Pc400)(manual) without parens OR request from the manufacturer/distributor.
Apr 27, 2018 | Computers & Internet
Installing two ram( ddr400 512mb and pc400 512mb )
If you are referring to computer RAM always put the largest ram module closest the CPU central processing unit
try to keep the same brand and type of ram the same ie: ddr ddr3.......
you will be able to read the ram type on the ram already inside
make sure you secure the ram modules by pressing the levers down firmly at both ends of of there sockets
make sure your computer is turned of before you attempt this
be sure to wear an earth strap before touching anything inside your computer
the ram modules sockets are located near your cpu
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope this helps you
Mar 21, 2012 | Computers & Internet
RAM Problem in intel D915GLVG mainboard
Most likely the pc400 hynix is incompatible with the mother board, or with the memory you are leaving in place. Try using just the pc400 sticks, if you still get system beeps then you are using incompatible memory. You should go to centon, or other memory manufactures wesbsite and look up what is compatible with the mother board and get that memory for the system. My bet is going to be pc3200 memory.
Hope this helps
Jan 25, 2012 | Intel D915GLVG Motherboard
Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
Aug 11, 2009 | Intel D845GVSR Motherboard
HOOKING THE FRONT PANEL CONNECTORS UP ON A PC CHIPS, PC400 MOBO, CAN ANYONE HELP ME? THANKS.
May 02, 2009 | Computers & Internet
Asrock K7VM2 Motherboard Memory Upgrade
Some MOBO support different type of memory modules like ddr 400, 333,533 and other, if your computer is working fine with that PC400 it only means that your MOBO is compatible with it. Since you're planning to upgrade the memory just get another PC400 because the memory should be the same to work fine.
Jun 06, 2008 | Asrock K7VM2 Motherboard
Motherboard upgrade
dont mix your pc400 to the pc266.
Feb 16, 2008 | EliteGroup P4VMM2 V8.1 Motherboard
P4vmm2 motherboard
you can add up to 2 gb RAM using either 2 x 184 Pin DIMMs or 2 x 168 Pin SDRAM DIMMs. However that MB does support pc400. The supported RAM speeds are 100, 133, 200, and 266 MHz
You can buy a pair of Kingston 256 MB DDR SDRAM PC2100 (266 MHz) from the kingston website for under $50
part no: KVR266X64C25/256
Kingston is a well known and respected manufacturer of memory.
Dec 15, 2007 | EliteGroup P4VMM2 Motherboard
94 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
