Question about Philips Audio Players & Recorders
Audio pc400 connector broken
The 8 pin connector is damaged and I need to buy a replacement
3 Suggested Answers
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
  • 5603 Answers
SOURCE: broken pins on orange 9 pin din
Try this site:
http://www.action-electronics.com/ppdin.htm
Posted on Sep 05, 2009
After buying the motherboard i assembled it with an amd athlon IIx3 processor and 4gb 1333mhz ddr3 ram. i startup the system and there is no bios display or POST or beeping. the fan on the motherboard is...
Quadcore or multiple processors need this type of Power inputs . ok just buy adapter like below picture "4 pin to 8 pin adapter
You can also make your own cable. for pinout connections see below picture
Do it with your own risk
If you have any Old broken Power supply then you can make it yourself by cutting the 24 pin connector like below picture and modify
for this you must have the knowledge of litle electronics, volt meater etc
for easyar side buy new Power supply
best of luck
Jan 26, 2011 | Gigabyte GA880GMUD2H AM3 AMD 880G HDMI...
Audio out connector broken need help
The only way out if to get to the Motherboard and replace the connector pin. For this you will need to open the sides, remove the mother board. Only if you have good soldering experience with the desolderring tool this can be done.Other wise you may have to loop the connectiion from the motherboard to a inline connector pin. The work on the board must be undertaken only if you are experienced to do the replacement without damaging the board or else loop as suggested above. Hope you try this out. Good day
Aug 10, 2010 | HP Compaq Presario SR1115CL PC Desktop
Broken pins in the USB connector. Need
just find another similar device with broken screen, buy it steal whatever and replace the screen with yours, should work
Apr 19, 2010 | Magellan RoadMate 1400 Car GPS Receiver
HOW TO CONNECT FRONT AUDIO PINS
the connector is marked F_audio and it is located directly behind the rear facing audio jacks. should be only one plug either marked "hd audio" OR "ac97 audio". some cases are setup for either, but you only need one of them depending on what your motherboard supports.
11) F_AUDIO (Front Audio Connector)
This connector supports either HD (High Definition) or AC97 front panel audio module. If you wish
to use the front audio function, connect the front panel audio module to this connector. Check the pin
assignments carefully while you connect the front panel audio module. Incorrect connection
between the module and connector will make the audio device unable to work or even damage it.
For optional front panel audio module, please contact your chassis manufacturer.
By default, the audio driver is configured to support HD Audio. To connect an AC97 front panel
audio module to this connector, please refer to the instructions on page 72 about the software
settings.
Pin No. Definition
1 MIC
2 GND
3 MIC Power
4 NC
5 Line Out (R)
6 NC
7 NC
8 No Pin
9 Line Out (L)
10 NC
AC'97 Audio:
Pin No. Definition
1 MIC2_L
2 GND
3 MIC2_R
4 -ACZ_DET
5 LINE2_R
6 FSENSE1
7 FAUDIO_JD
8 No Pin
9 LINE2_L
10 FSENSE2
Mar 27, 2010 | Gigabyte GA-945GM-S2 (0818313003065)...
ACS295 speaker cable to subwoofer, one of the pins of the connector is broken, how can I fix it or get a new connector?
if connector is broken, you need to buy a new connector, but it takes a little handwork and some tools a screw driver some electric iron and solder.
u need to open subwoofer case and check for the connector is soldered in a board is 2 jack 3,5mm female connector and one red mini-DIN connector. replace the connector take a attention on soldering the connector, dont damage the board wires and pins, if the iron above 300ºC.
take a special attention on electrostatic discharge, normaly burns sensitive boards.
Jan 30, 2010 | Altec Lansing ACS 295 Computer Speakers
Zoom 9030 works well after all these years there is a memory battery that needs to be changed every 5 years or so. The only problem is when I plug in the 8050 foot controller it won't change any patches...
It is LIKELY that one or more pins and or wires in the remote cable are broken.
These MINI DIN connectors are "tender" and are easily broken and wires flex at the back of the connector and are broken.
FIRST check that all pins are present at BOTH ENDS of the cable.
NEXT use an ohmmeter to check continuity of each and every pin end-to-end. I suspect you will find one or more broken.
Be aware that repairing this cable requires patience and steady hand as the pins are so close together it is easy to have solder bridges, etc. Sometimes just opening the connectors are a problem to access the pins. Sometimes the cables are MOLDED and those are UNREPAIRABLE other than cutting off the bad conector and replacing it. You can usually buy replacement connectors at DIGIKEY.com and or Mouser.com. You have to CAREFULLY select the apporpriate pin configuration from the catalog page. One needs a small soldering iron and magnifying glass to work on the cable.
USUALLY the wires go from pin to pin. Also a shield on the cable has to be dressed and connected usually. You may find the shell of the connector tied to a pin or just the sheild of the cable.
Jan 08, 2010 | Zoom Music
VGA PIN
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Jul 17, 2009 | LG Studioworks 700S 17" CRT Monitor
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
4&5 Not connected
9&10 NC
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
P4vmm2 motherboard
you can add up to 2 gb RAM using either 2 x 184 Pin DIMMs or 2 x 168 Pin SDRAM DIMMs. However that MB does support pc400. The supported RAM speeds are 100, 133, 200, and 266 MHz
You can buy a pair of Kingston 256 MB DDR SDRAM PC2100 (266 MHz) from the kingston website for under $50
part no: KVR266X64C25/256
Kingston is a well known and respected manufacturer of memory.
Dec 15, 2007 | EliteGroup P4VMM2 Motherboard
190 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
