Question about Krups Coffee Makers & Espresso Machines
Krupps coffe maker model KP1002 will not pump water through capsule
pgh_pa_guy
  • 2992 Answers
SOURCE: past 2 mornings, coffee maker only brewed 10 out of 12 cups.
It's probably time for a good cleaning. Follow the procedure in the manual, or get some commercially available coffee maker cleaner. When the minerals build up enough, the water flow and heating is reduced enough to keep it all from passing through.
Please take a moment to rate this solution if it's what you needed, and thanks for asking here!
Posted on Feb 24, 2009
EsWorld
  • 1618 Answers
SOURCE: can't get steam from krupps household espresso maker
Using a paperclip or pin try clearing the holes of the nozzle at the end of steam wand.
Posted on Sep 16, 2009
  • 3 Answers
SOURCE: I have a kenmore 12cup coffe maker. The carafe
I had the same thing happen when my carafe broke. Mine is 238.69328 which is the black coffee maker. The simple solution is to head to Walmart and buy the GE replacement carafe. It's the 12 cup capacity one #169164. The box has 169180 on the bottom and it works like the old one and looks just as good no matter what color your coffee pot is.
Posted on Sep 17, 2009
SOURCE: the capsule lock system does not make holes in the capsule
Hi, I'm having the same issue. It punctures one side (the 3 holes) but not the other (where the foil is). The only thing I can think of is that I had made an espresso, then added water since it was low. When I went to make the next one, it wouldn't puncture. It seems crazy, but maybe the water was too cold? I dunno. Did you end up figuring it out? thanks
Posted on Oct 21, 2009
heatman101
  • 43501 Answers
SOURCE: my keurig coffe maker says it id "brewing" but
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 28, 2011
No water getting to the pod area of my coffe maker
Give more details. Do you hear the pump? What are the light doing? Do you hear water boiling? I can help, but I need more info.
Aug 09, 2014 | Philips Senseo HD-7810 Coffee Maker
Nespresso capsule alignment
After the first one you have to remove the old shell before you can make a second cup of coffe .
Oct 29, 2013 | Coffee Makers & Espresso Machines
Doesnt make coffe . i can hear it running but nothing happens no cffee comes ut. aso leas water smetimes.
Your water pump or volumetric counter can be clogged. Or the 3 way valve on the back of the unit is stock on the closed position or bad.
Jan 19, 2011 | Lavazza Espresso Point Capsule Machine
Nespresso essenza problem
It's not supposed to make holes in the capsule until the water comes through. So, basically, when you put the capsule in, it pierces the capsule in three spots, on the top. The aluminum part will not pierce until you press the button and water comes through. If water is not coming through, then you can clear the air bubble by opening the lever on top of the machine, pressing the coffee button, and then closing the lever once the water begins to come through.
Jul 30, 2009 | Nespresso Essenza C100 Espresso...
We lost instuctions on our krups coffee/cappuccino maker dont know how to use
XP4050 Krupps
pumps water through machine into drip tray not through coffee anymore
Apr 26, 2009 | Krups Cappuccino/Espresso Maker -...
Coffee not dripping out of the machine
let it run without coffe tablets, if no water comes out probably the conducts are obstructed, may be calcium in the pipes...do water come out somewere else?...
Jan 08, 2009 | Lavazza Espresso Point Capsule Machine
The machine seems not to be working well
I had very similar problem and found the fix here.
Did you try the reset process? Place an empty cup, insert a coffe pod, press and keep pressing the "Lungo" button until the cup is filled as desired then release it. Next coffee, just press once, it should be now set at the desired level.
Jan 03, 2009 | Nespresso C100B Essenza Single-Serve...
Water pump does not work
Try to open the steam knob and turn on the button to make coffee, when the water flow out off the steam pipe, close the knob and the button.
Jun 06, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Coffee Makers & Espresso Machines Logo
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
