Question about Epson TM-T88III Thermal Printer
Epson tm-p2.01 driver for windows 7 32 bit - Epson TM-T88III Thermal Printer
SOURCE: Epson printer TM U220 (User Intervention Required)
I spent a good week trying to find an answer to this problem... and finally I HAVE THE SOLUTION!!
it's to do with the Port settings.
go to BIOS and change the port settings on your computer.
there are a number of different options that can be selected, just try them one by one, the one that worked for me was "Normal" try that one first, but it may be differnet depending on the printer.
if your LPT port is using it's own driver (not using BIOS to run) you cant change the settings using the BIOS. see if you can change it useing the settings for the dirver. if not try updating the driver. if that doesn't work, and nothing else works, reinstall Windows, that should fix the problem as a last resort.
good luck.
Posted on Jul 23, 2009
SOURCE: I need epson tm-u220pd driver for windows xp
OK here you go.
http://www.howtodrivers.com/model535852.html
Posted on Feb 02, 2010
informatica
  • 1114 Answers
SOURCE: Epson TM-U220PD
Necesitas colocarse para los productos de la ?POS? en el Web page siguiente: https://www.epson-pos.com/cgi-bin/sdssm/main/td_login.jsp?sel_lang=es
Posted on Jul 29, 2007
Nitrotrike
  • 589 Answers
SOURCE: Epson TM-T88#P thermal printer driver for windoze vista
You can use windows 2000 drivers on Vista for this printer, according to this article:
http://www.prophetline.com/node/141
Posted on Jan 14, 2008
SOURCE: Epson TM U210D Driver for Windows Vista
driver epson tmu 210 d windows vista
Posted on Dec 05, 2008
Epson UB-U03II not working
I had huge issues with my TM-U220. It does not play well with a Centronix-to-USB cable or with Windows 64-bit. I played for AGES to try and get it all to work.
I installed the USB device driver[1] I was able to print the Test Page proving that the connection between Windows and the printer sort of worked, but when I tried printing anything from Unicenta POS, it always failed.
I finally bought a new Centronix-to-USB and a new parallel port card, used Windows 32-bit, and problem solved.
They key is to uninstall everything, including searching through the Registry to delete everything.
[1] https://pos.epson.com/developers/techresdetails.htm?ProductPK=545
May 30, 2014 | Epson TM-U220 Matrix Printer
I cant find any drivers for this product for windows 7
Use this link to download the Windows driver for this product, this is a universal driver for Epson POS printers should include support for multiple interfaces.
http://bit.ly/HBHPMc
Jul 12, 2012 | Epson TM T88II Label Printer
I need driver for Epson TM-U220PB (Windows 7 64 bit)
https://download.epson-biz.com/modules/pos/index.php?page=prod&pcat=5&pid=42 is the location for the drivers for the TM-U220 printers.
May 27, 2011 | Epson TM-U220PB Matrix Printer
I have a TM-T88IIIP model MI29C and windows 7 operating system. Do you have a download available for this?? Thank you Carol
Here's the driver link for the Epson TM-T88IIP Receipt Printer: http://www.posmicro.com/RECPRINTERS/EPSON/Epson-TM-T88II.htm
This link will take you to the download page for the manual as well. This driver is supposed to be for Windows XP but should work for Windows 7 32 bit OS. Give it a try - if it doesn't work or won't install, then post back to this solution and I will help you further. It is likely that a Windows 7 driver doesn't exist, but unless you have the 64 bit version of Windows 7 this driver should work one way or another.
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
May 03, 2011 | Computers & Internet
I NEED THE DRIVER FOR EPSON TMT88IV
Check the link below and go to the lowest portion of the page:
http://www.bluepos.com/bluepos/Boards/?document_srl=318
Look for EPSON TM-T88IV Driver (APD_402EWM.exe) and click on it.
Hope this helps.
Aug 28, 2009 | Epson POS TMT88IV Thermal Receipt Printer
Can't find driver for Epson TM-H6000 for Vista 64-bit OS
hi.
hi i have a same problem as u have. but for now i am using generic driver using generic text drive only. and pls dont forget to keep ur port as com1 plus change ur bit to 19200 otherwise that also will not work.
Feb 27, 2009 | Epson H6000II Thermal Printer
Problem setting up TM-U220
print the self-test, push the feed botton while powering on...
you can see there the serial interface...
baud rate, data bits, parity, stop bit etc...
then go to the printer and faxes,
right click the epson driver and click properties...
go to the ports window...
click on the epson tm u220 reciept.
click configure port...
adjust the baud rate as same as in the self test...
it works...
May 22, 2008 | Epson TM-U220 Matrix Printer
Jan 14, 2008 | Epson TM-T88III Thermal Printer
Epson TM-T88III Thermal Printer Logo
2,018 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
