Hi would really love a answer i have a baumatic bwm50 top loader washing machine it is not draining i am pretty sure that the filter is blocked. Where is the filter located?
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
What does e33 mean on a baumatic washing machine
not saying this is whats wrong with it i just found this on the internet............hi, you need to empty the filter, ours does the same all too often. The filter is located bottom right of the machine at floor level, which is rather daft for an integrated applicance; we have to remove a whole length of plinth to empty ours. Be warned, a lot of gunge and water will come out so have towels at the ready, especially if you have a laminated floor. Turn the white slot with a a 10p piece......and empty. Not the most pleasant of jobs, but effective. Good luck!
Dec 11, 2016 | Baumatic Washing Machines
I have a baumatic 1206 which will not drain. All suggestions are to clean the filter, but I cannot find a filter. There is no detachable panel at the front bottom of my machine
IS THERE A DETACHABLE PANEL AT TOP? IS THERE A CREVICE NEAT THE TOP? IF NOT U MAY HAVE TO REMOVE THE WHOLE CABINET? IS IT TOP LOAD OR FRONT LOAD? HERE ARE SOME PICS THAT MAY HELP
May 25, 2015 | Baumatic Washing Machines
My fisher and paykel top loader washng machine is bloked and will not Rinse, drain and spin. Mainly Drain as im pretty sure its blocked from fluff etc nybody can plese tel me how to unblock it? Thanks
The drain water pump is the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
Apr 10, 2015 | Fisher and Paykel Washing Machines
MY WASHER WILL NOT DRAIN WATER AFTER THE WASH CYCLE OR THE RINSE CYCLE IT CLICKS AND SOUNDS LIKE IT IS GOING TO START THE RINSE CYCLE.KENMORE TOP LOADER MODEL NUMBER13212200
Sorry but I do not know your particular machine and I usually only answer front load problems BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, I think even on top loaders it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
I hope these guidance notes help with your top loader.
John C
Feb 18, 2011 | Washing Machines
Washer won't drain. Pretty sure it's clogged but not sure how to check for this.
Hi, You don't mention whether this is a top loader or front loader. On the top loader you need to get to the drain pump. Front of washer may come off or the lid comes off and then the front. Some of them had clips under the console. Once you are at the pump, take a shop vac and empty the water. Both hoses inlet and outlet will have to be removed and cleaned. BEFORE YOU DO ANYTHING ON THIS, UNPLUG THE MACHINE!!! If its a front loader the kickplate has to come off or the whole front, and same procedure as above. Hope this helps.
Jan 18, 2011 | Washing Machines
Washing machine does not drain
You probably have a blocked filter on the drain pump. If it is a front loader the service panel will be on the front at the bottom of the unit on the left or right. Open this panel up and remove the filter and check for blockages. Have a baking tray handy to collect any water as you drain it out. Once you have removed the filter have a look in the hole and you will see the drain pump. make sure it turns freely and there are no other foreign particles in there before you put the filter back.
Hope this helps.
Mar 21, 2010 | Washing Machines
The machine won't spin , machine will wash but won't do the final drain and won't spin at all :(
It is probably due to a blocked pump filter.
You need to locate and clean the filter.
Jan 17, 2010 | Baumatic Washing Machines
Hi there, my friends Bosch WAE24162GB washing machine wont drain the water out, im pretty sure its just a blockage but cant for love nor money get the filter out!! is there a trick to it- it turns a...
The error indicates that the machine has taken too long to drain the water. Do the following.
  1. Switch off the machine and disconnect the mains power.
  2. Remove the access panel on the lower right front of the machine.
  3. Remove the filter by twisting anti clockwise and pulling forward and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Oct 20, 2009 | Bosch Washing Machines
Hi, I have a Baumatic Washing Machine (not sure of the model) and cannot find the filter. The machine gives off an awful smell which I am trying to fix
you should find the filter but that is not what is causing the smell. common causes of smell are:
using liquid detergent - this smells like drains if used for a long period and leaves a horrid sludge in the tub. put on a boil wash with no clothers and use powder detergent
plumbed in under the sink and there is also a waste disposal unit. these pong!
no water barrier between the drain of the washer and the house drains
Jul 10, 2008 | Baumatic Washing Machines
Washing machine
The filter on your pump is probably clogged with lint and other stuff. Lift washer up a bit. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. Drain off excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water or a wet vac. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Nov 27, 2007 | Whirlpool GHW9150 Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
