Question about Car Audio & Video
How do i hook up my crossovers to my focal krc 165 speakers
2 Suggested Answers
604Autosound
  • 162 Answers
SOURCE: I need to know what
When putting in a good set up speakers like those, I always recommend:
Making mounting rings/plated for them
Sound Deadening Material to help seal the door up for better bass from the mids
Gasketing Foam to help decouple surfaces that may vibrate against each other
Duct tape
Good quality speaker wire.
Posted on Feb 04, 2011
How do I replace a blown fuse on the Solo 6 be?
Unscrew the woofer, gently pull it out, follow the wires to the crossover, replace the fuse, reverse the process.
Jun 18, 2011 | Focal Solo6 Be 2 way Near field Shielded...
Tryin to hook up a mtx electronic crossover rt-01a. i dont know how to hook it up
Your basic crossover is going to have a power (+) and ground (-). Your power wire goes to the battery, and your ground goes to the frame. You will need to hook up your RCA or speaker wires to the input side. Then hook the other two RCA connections to your amp.
Apr 13, 2011 | MTX Car Audio & Video
I need to know what I will need when installing Focal 165 A1 6 3/4 speakers in the doors of my 2003 Nissan Altima. (speakers adapter rings ect.?)
Duct tape
Jan 09, 2011 | Focal Access 165 A1 Car Component System
Problem with focal k2 power and focal fiberglass speakers in car
It could be the setup of the speakers, but I would install a crossover equalizer for your situations. A crossover equalizer is supposed to automatically filter the necessary frequencies to the correct speakers. I have used no name and brand name XverEQs and they both worked the same for me. Along with this response I am assuming you also have Mids and Highs to go along with the woofers.
Nov 08, 2009 | Focal -America FAA33A Car Speaker
I have a kenwood krc-3005 radio I do not have a wire diagram can you help
Yellow (+) Constant 12 Volts
Red (+) Switched 12 Volts
Black (~) Ground
Blue w/white stripe (+) Remote Out(used to turn
on the amplifiers)
Orange w/white stripe (+) Dimmer IN(used to dim
the display of the unit)
NOTE. if you dont want to hook up this wire it doesnt matter)
SPEAKERS OUTPUTS
White(+) Left Front
White w/black (~) Left Front
Gray (+) Right Front
Gray w/black (~) Right Front
Green (+) Left Rear
Green w/black(~) Left Rear
Purple (+) Right Rear
Purple w/black (~) Right Rear
Jan 04, 2009 | Kenwood KRC-207S
I have a xenyx 2442fx mixer and ep2500 power amp hooked up to 2 1800x subwoofers and 2 1520 pro speakers. i am using a peavey xr 684f powered mixer to power my monitors. i would like to add another power...
You would need a 2 or 3 way crossover, depending on whether or not you biamp your tops. Simply go out of your main outs on the mixer into the input of the crossover. Go from the low output of your crossover to your low power amp input (subs), and the high output of the crossover to the high power amp input (tops). Then go from your outputs of your amps into the speakers themselves.
Jan 04, 2009 | Behringer B1520 Pro Eurolive 15" 2-Way...
I have a 400 watt speaker and the board in not working and the the speakers and everything else is working good but i think that it the board inside the speaker.
the board that you are talking about is the crossover, does any of the speaker work the woofer or tweeter or midrange drivers? If the woofer does not work then take out the woofer and take the wires that attach to the speaker on the back and hook them directly to the speaker that you took out if it plays you need to replace the crossover in the speaker, this should be easy, just call the company that makes the speaker and order a new crossover, you can do this also with the speaker if there is no sound when you hook it up direct.
Aug 19, 2008 | Audio Players & Recorders
Kenwood krc 479r
If there was no spark and wires hooked up wrong in the first place, your player should work if you find the PWR lead and the Remote lead and ground. Then speaker wires +) and (-
Sep 25, 2007 | Kenwood KRC-479R Cassette Player
Car Audio & Video Logo
26 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
