Question about Home
Roca toilet cistern float sticking
Float sticks up after flushing
  • 34 Answers
SOURCE: Slow Flushing mechanism
Check the angle stop at the wall ( valve) if it more then a few years old the rubber inside sticks try turning it off and on a few times. Well first just make sure its open all the way to start. If both of those do not work It might have a screen at the opening of the preeure mechanism...check that the was no line trash caught in it from turning the water on and off. If none of these things work let me know and we can get more technical in find out whats wrong...heck you could have just gotten a bad one. The Plumbing company I worked for when I lived in houston had the contract with them to do there warranty work and boy did we do a lot of it .
Posted on Feb 04, 2009
co7196
  • 3433 Answers
SOURCE: American Standard Champion toilet keeps running
Readjust the float. the longer it is the more leverage the fill water will have on it. good luck. The fill valve does come apart and cleaned if there is debri in it. Turn the water off first:)
Posted on Jun 20, 2009
SOURCE: my toilet cistern is continually hissing
Hi I have exactly the same problem, in fact it could have been me writing this - 3 toliets fine, main bathroom hisses. The Geberit flushing ciphen on the left (the smaller one) has been replaced and there is still a problem. If you look carefully,the water level needs to come up over the lip of an opening on the Geberit part and this causes the valve mechanism to shut off and stop the hissing. It is fine for about 40 minutes and then the hissing starts again if you don't flush it. The reason is that the water level has gone down but there is no obvious signs of where the water is going. It could be that the central flush mechanism is leaking slightly. I am going to replace this part next. If I were you I'd see if you are getting any water leakage into the pan when toilet not in use to see if the water level in the cistern is going down James T
Posted on Oct 31, 2009
  • 19 Answers
SOURCE: toilet handle stick on flush and water runs and
Turn water off and get a handle repair kit, very easy repair
Posted on Mar 02, 2010
  • 1026 Answers
SOURCE: how do i fix a cistern that is continually leaking
most modern toilets do not have an overflow pipe to outside instead they overflow into the bowl itself so have to adjust level so it does not overflow into return
Posted on Apr 02, 2010
Float will not go down after flush and will not go up to turn water off
The float assembly needs changed its sticking. God-Bless!
Oct 01, 2015 | Home
How do i get more water in the toilet bowl?
On some toilets the float level is adjustable inside the tank. If there is an arm with a large ball attached then bend the arm up slightly. If it has a small plastic float then some of these can be screwed up or down on the tube supporting the float. The higher the float the more water that will transfer to the bowl. If your house is built in the 1980's or newer then you should have all plastic pipe and I would switch out to a low flush toilet. If your house is old (pre 1960) then you have cast iron or clay pipe and you may want to keep your 3 gallon flush as long as you can. If you are in the between zone then you need to check and see what kind of pipe was used. A smooth wall pipe requires less water to flush. If you go with a new toilet go for a mid grade one. The cheep ones have poor castings on the inside and it causes friction that results in a miss flush more often. I like the Delta with 3 bolts on the tank in the $150 to $200 price range. If all else fails a new flush valve will come with instructions and they do go bad after a while so now may be a good time to replace it. Flowmaster has been pretty good to me and you can pick one up for about $20. There are ones that are supposed to shut the water off if the flapper sticks but they take a bit more experience to figure out how to set them and you will find yourself flushing the toilet and nothing is happening because the float switch has the water shut off.
Oct 22, 2014 | Home
My DAB pressure pump does not work correctly wont always start when required
There child be a float with the pump to let it know when to start. I would check to make sure the float is not sticking and replace if it is.
good luck
Apr 17, 2014 | Home
My dewalt dpd3300 ,why is it getting gas in the oil
This happens when the gas needle valve in the carburator sticks open. With it open, gas continues to flow into the carburator then into the cylinder and finally down into the crankcase. It can be caused by dirt in the needle valve's seat, a stuck needle or float. Most of the time you can remove the float bowl and flush out any dirt. If there's a lot you should consider flushing the gas tank and check your gas can for dirt. If the washer has been sitting for a long time the problem could be varnish is gumming up the carb works. Carb cleaner works well to flush that out. If the float, needle or seat is damaged you'll have to rebuild or replace the carb.
Jan 22, 2013 | Dewalt DPD3300 Commercial Pressure Washer
Float sticks and gas floods motor
the needle is sticking on the caburetor float thus letting the fuel siphon from the tank into the cylinder block. Have the carburetor rebuilt and drail and flush the engine with automatic transmission fluid before putting in nem oil. Should cure your problem.
Oct 30, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Geberit Impulse 260 Dual Flush Valve problem
need to adjust the float [water level shut off] lower or the water valve needs repair sometimes the valves stick and tapping the unit free's it up
Mar 01, 2010 | Home
The front left carb is leaking gas, a lot and at low speed it seems to be loading up one of the carbs. Feels like I'm running on 3 cylinders until I get up some speed. What do you think and how should I go...
Has the bike sat for long preiods ??
sounds like the float is sticking..
Try and get some carb cleaner into the tub..
If that does not work you might need to get the carb cleaned and/or rebuilt..
If doing that - would be a good idea to do all 4...
Jul 08, 2009 | 1981 Honda GL 1100 Innerstate Gold Wing
Jun 15, 2009 | American Standard Home
Home Logo
73 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
