Question about RCA 257003 Remote Control
My remote control will not channel up/down
You can turn it off/on and volume but you have to manually put the numbers in
Did you get water on it cuse some time that will happen if you get it wat i'v done it before and i took it aport and dryed it and work fine after that
Posted on Jan 11, 2009
Remote won't change volume, channel numbers don't work
IF its the original remote for the device, the circuit board is just dirty and is not getting good contact. If its a universal then the codes may not be 100% compatible with the device or the remote isn't 100% compatible either.
Jan 23, 2014 | Emerson Used Original NH200UD Remote...
Sony trinitron kv32-s15 remote willnot change channels, but, will change on/off and volume.Also, manula channel up/down willnot work
Try to change channels by manually entering the numbers on your remote. If this works then you need to reprogram your channels.
Aug 21, 2010 | Zenith ZN110 Remote Control
I have a philips universal remote code-CL043 and need the codes for philips dvd player
I just move and lost my code sheet for my phillips universal control is there some where i can get some codes,i have a emmerson television thanks.
Mar 16, 2010 | Philips Televison & Video
Bravia KDL40W2000 Remote and manual controls no longer work
check to be sure your remote is sending IR signal, with
a smart phone camera hold remote IR eye in front of camera and click any buttons on remote, you should see
a light coming from IR eye. If no light emitting, remote needs to be replaced.
Oct 29, 2017 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I'm looking for the manual for a Mitsubishi VCR HSU447 with the remote control RM75502 so I can program my TV to it. Thanks
1.- Turn off your TV
2.- On the remote control, set the VCR/TV slide switch to TV position.
3.- While holding in SP/EP button, press the code button listed below that corresponds to the brand of your TV
4.- Press TV POWER on the remote control. Once your TV has turned on, your remote is set up to operate your brand
TV.
Brand of TV Brand Code Button
Mitsubishi 1,2,3
Fisher 0
G.E. VOLUME UP
Goldstar 2,9
Hitachi 8
JVC MUTE
Magnavox 4
NEC 2,9
Panasonic CHANNEL UP, CHANNEL DOWN
Pioneer 6
Philips 4
Proscan VOLUME UP
Quasar CHANNEL DOWN
RCA VOLUME UP
Sanyo 0
Sharp 3,5
Sony VOLUME DOWN
Toshiba 7
Zenith INPUT
I finnaly found my VCR Manual, and I'm glad to share this info with you, because I was looking for the manual all
over the web and FOUND NOTHING!. Bye!
Mar 15, 2009 | Mitsubishi Televison & Video
Code for Palsonic 6830TG TV
if the volume down ts working then that means the remote is working if the volume + does not work and the channel + then they need to be cleaned with isopropyl alcohol using a cotton swab, that means you will have to open up the remote control
May 27, 2008 | One For All URC 7740 Remote Control
Child lock on tv
All you have to do is turn the TV on and turn to a channel that doesn't prompt the V-chip password (even if it's snowy) and hold down the volume (down -) button on the main unit while holding down the number "0" on the remote control. It might take a few tries, and you might need to change the TV channel for some reason but if done correctly, either the TV will turn off, or the menu screen will pop up and ask if you want to set the vchip password, either way you should be able to watch your TV now! :)
May 24, 2008 | Televison & Video
Multiple issues with tv
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Feb 21, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Iriver e 10
how to use the remote control.
1. go down to settings
2. remote control
3. find your tv brand (mines in ect(more brands))
4. point at tv (when on)
5. Scroll down list of numbers (#00; #01; ect)
6.go down to the bottom and if your tv dosn't turn off your tv isnt supported.
7. If it is supported click on the number your tv was
8. go back to the main menu
9. put it on hold (switch on side)
10. your done!
controls are:
up - channel up
down - channel down
left - volume down
right - volume up
power - off/on
smart key - mute
vol up - volume up
vol dwn - volume down
Jan 19, 2008 | iRiver E10 Digital Media Player
I have a 50P8342 with simular problem
My tv was doing some of the same type things I touch one of the manual buttons ont tv and the channel would change or the volume would go up or down. I changed the control board behind the manual buttons on the face of the tv and now it works fine with or without the remote. the part no. is 313501707611 go to sears web site type in this number and order it. this part will come up as 60P8342 but thats ok becouse the 50P8342 and the 60P8342 use the same part number I know I have both models and changed them both using the same part and part number.
Nov 19, 2006 | Philips 60P8341 60" Rear Projection...
RCA 257003 Remote Control Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
