Question about Vizio L32 32 in. LCD HDTV
Green shadow or static lines(dots) all over screen
Checked cords- get it with dvd and cable..... This is a one year old 32 vizio - but really hardly used as it is in our vacation residence
    Sergeant:
  • 227 Answers
Problem sounds like ignition noise. Depending on the condition of applainces and electrical distribtion box (Fused/circuit breakers) on the premises. Could also be entering through outside source. The best way to find out if this actually causing your problem is to take a portable radio and tune around 550mhz on the AM band. If you hear a buzz or crackle tune radio to the loudest hum or buzz, then walk around aiming towards the more signal or louder it gets until you find the source. Hope this helps.
Posted on Jan 11, 2009
4 year old vizio 42 inch tv lcd. While watching tv, the screen started dimming. There is a 4 inch shadow all along left side of the screen and the 1 inch line shadow going down the middle of the screen.
Maybe a power supply or related issue but at 4 years of age the set has reached its life span----parts will be hard or impossible to find.
If you got four years I would retire it and recycle it and then replace it.
May 14, 2012 | Televison & Video
Vizio L32 stopped working.
I have seen this many times. The tv most likely has run its course. It could be the power supply or a lamp. Sounds more like a lamp, as you still have lights on your set. check around and get some prices on a lamp. you can have a local shop install it for you. or just replace the set.
May 03, 2010 | Vizio L32 32 in. LCD HDTV
Green interference on our screen.
We had full screen green interference. What solved the problem for me was disconnecting and reconnecting all the cables. One cable in particular was pulled very tightly and could have been torquing the connection inside the cable box. Anyway, releasing that tension and adding some slack resolved the issue.
Good luck.
Mar 15, 2009 | Vizio VW32L 32 in. LCD HDTV
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Vizio P2 42 in. HDTV-Ready Plasma
Search Google "Screen Burn-In."
Mainly Plasma screens are affected by it.
Sep 20, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Hitachi 42edt41green static
Dave you know your stuff man !!! You helped me fix my black line fix on my LCD / Plasma and then now you helped me get rid of my green dots on my screen !! You rock . thanks a Million
Aug 07, 2008 | ViewSonic N3251w 32 in. LCD HDTV
Vizio liquid crystal tv l32hdtv
Check the cable connections and/or replace the cables to the AV2 input.
If replacing the cable doesn't provide a solution, try running your DVD through the input. Since it works fine now, you would be checking the input AV2 by putting your working DVD. If the DVD plays with no problems, the input is fine.
Also try the VCR using coax into the TV instead of RCA into AV2. This will give you some idea about the condition of the VCR.
I suspect either the VCR or the cables.
Apr 22, 2008 | Vizio L32 32 in. LCD HDTV
Gateway laptop vertical dotted lines across the screen
Sounds like a problem with the LCD assembly or cable. You may want to reseat the LCD cable at the LCD end. It could be a loose internal connector in the LCD assembly.
Ron-
Dec 13, 2007 | Computers & Internet
Vizio L32 32 in. LCD HDTV Logo
874 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
