Question about Nespresso Coffee Makers & Espresso Machines
Delonghi Nespresso Lattissima Plus EN520 won't work after descaling
4 Suggested Answers
SOURCE: coffee tastes very acidic
Hi kdimof,
I realize you posted this problem over a year ago, but I was curious to see if you were ever able to resolve this problem, or find the exact cause.
I have the same issue you describe. I descaled my Lattissima for the first time using the Nespresso descaling solution. And now, two months later, I cannot remove the chemical smell/taste of the descaling solution. I've run numerous descaling cycles with just water (as per Nespresso's customer service advice), with no success. I was forced to accept a refurbished machine (even though my Lattissima was only 3 months old). The refurbished machine is currently on the way. We'll see if I have the same issue when I descale this one.
Thanks, Redfran
Posted on Sep 27, 2010
espressonist
  • 1711 Answers
SOURCE: My delonghi lattissima is not piercing the
First you need to check the capsule container. Make sure that there are not any coffee remains both the liquid of dry coffee since will blocked the capsule to sit in proper place and thus to be press correctly. If you find anything you need to clean them very well with a warm wet sponge (remove machine from plug).
The second possibility is that one part of the lever and capsule container have brake either a plastic part or a metal rod or a spring moved out of place. In this case you need a new capsule container which you can find in this link.
Here is also you machine parts diagram.
Posted on Jul 31, 2011
  • 115 Answers
SOURCE: Hi, I have a DeLonghi
Hi. sounds like an ECU problem. Take to a repairer. Dazza REPAIRER
Posted on Sep 24, 2011
Nespresso lattissima plus not frothing milk very well
Pled do cleaning well and descale if this didn't work you have to cheak seals and the boiler but rescaling may resolve your problem
Oct 04, 2016 | Nespresso Coffee Makers & Espresso...
Delonghi
For De\'Longhi En520.W Nespresso Lattissima Plus Coffee Maker Team De-Brewerz.com says:
1. Your coffee maker might suffer from water pump, water sensor or PC board failure. Claim the warranty if recently purchased. If you are in India then contact us @ www.De-Brewerz.com
Now you can order all De Brewerz Stuffs online in India @ www.fabkaart.com
Aug 29, 2014 | De'Longhi En520.W Nespresso Lattissima...
Delonghi problems
Try filling both water and the milk container with the correct decalcifying solution - just slit the 500 ml that results from the 1:1 mixture and - without the coffee capsule - press the cappucino button. Instead of cappucino you will get the decalcifying solution running through the entire system including the connector for the milk container (unlike the recommended decalcification method where you use the extra nozzle). Good luck - worked for my machine which only produced steam but no milkfoam...
Aug 02, 2014 | De'Longhi En520.W Nespresso Lattissima...
Delonghi problems
Try pressing all 4 buttons on top of the machine simultaneously after turning on the machine for a few seconds. That resets all volumes to the original factory settings.
Cappuccino and latte macchiato buttons blinking
The unit is heating the steam - the lights should switch to contant once the right temperature is reached. Make sure to always descale the machine if the cappuccino button light turns orange.
Mar 29, 2014 | De'Longhi Nespresso Lattissima Plus...
Water button orange light appear even after descaling
I had the same problem too.
Do repeat the descaling with water only. After the descaling the Lattissima shuts down. Just wait some time after shutdown before restarting the Lattissima again. The orange light will be turned off.
Hope this helps you too!
May 01, 2010 | Nespresso Lattissima 660.R
Coffee tastes very acidic
Hi kdimof,
Thanks, Redfran
May 14, 2009 | Nespresso Lattissima 660.R
Coffee Makers & Espresso Machines Logo
993 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
