Question about Bosch Dishwashers
Bosch aqua tech dishwasher showing error code F. Water tap is on.
Machine will not run. Shows F on display. Water tap is on.
  • 641 Answers
SOURCE: error code AO1
Error message A01 means -Acqua stop operated due to a leak or overfill. Check if there is still water in the machine after it stop pumping. In case you still have water - your problem is with the pump or with a blockage drain line. If there is no water in the machin, it might be a water level sensor issue - stuck physically in the high level position or become defective. Try to reduced the water presure and leveled it up by the water entrance tap to the machine, it might solve your problem. Goog luck !!
Posted on Jun 27, 2006
  • 54 Answers
SOURCE: AEG 50760 Dishwasher shows Error Code 30
there is water in the base of the macine. lean it over to the side to get all of the water out then try again.
Posted on Feb 14, 2008
SolutionGuy
  • 331 Answers
SOURCE: bosch dishwasher motor keeps running no water
Hola Lewis!
This is such an easy repair, you'll be shocked and surprised! The reason this is happening is that the computer or timer has detected a "flood" condition and has permanently energized the drain pump to clear the "flood".
What you'll need to fix it...
1.) Shop-Vac (for vacuuming water) with a crevice tool (like one of these)
2.) T20 Torx bit with a driver. Torx sizing here. (You can get a set at Home Depot or Lowes)
All you gotta do now is get down on the floor and remove the kick panel. Then remove the screws holding the water valve and lift it up out of its' plastic holding. Now your shop-vac w/ crevice tool can be used. Stick the crevice tool in there (about 10") and vacuum up all the water that's been trapped in the basin. (you may need a flashlight to see what's going on back in there...) After the water is gone, your DW will work fine.
Here's how it works... About 10" behind the inlet valve is a "float" made of styrofoam. When water gets into the basin, the float rises and eventually trips a "flood condition" switch. This switch shuts the unit down and will only allow the drain pump to operate. So what you want to do is get the water out of the basin.
There may be a reason for the basin flooding, though. Suds (caused by too much (or the wrong) detergent), an actual water leak from the valve, etc... So after you get the water out of there and the unit is working again, you may want to monitor it (like, only run it when someone is home) for a while just to make sure that a real flood does not occur.
Hope this helps.
SG
Posted on Mar 23, 2009
  • 21 Answers
SOURCE: Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Posted on Jul 25, 2009
SOURCE: Error code E:24
bosch logixx error code: e24?
Posted on Sep 20, 2009
How do I get to make it stop and work .Dishwasher is not shutting down it says E 15 Water tap flashing , and red Aqua stop light .
inlet valve is the aqua stop long hose to tap has a solenoid at tap end that is likely your fault
Sep 29, 2016 | Bosch Dishwashers
Bosch Dishwasher fault E 15 explain
Bosch Dishwasher Error Code E15
Fault Condition:No water in dishwasher or not sensing water.
Repair or Check: Tilt dishwasher back and the error code should disappear. While you tilt it press off button to clear. Stand it back to normal turn back on and dishwasher should run normally.
Parts Required:Tilting machine
Hi i found this answer on this link, scroll down the page and it's the 3rd error code (in red) Hope it helps...
https://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Mar 16, 2016 | Bosch Dishwashers
Dishwasher starts to fill, then displays watertap error.
Not enough information to answer. Need manufacturer and model number before we can help.
Oct 30, 2015 | Bosch Dishwashers
Bosch silence plus 50 dba has error code h01
The statement below can be found at: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html,
The SHU4326 and 4326 models use "Regular Wash" and "Rinse Hold" to begin the test while the other three series in this section use "Scrub Wash" and "Delicate/Econo," but all use the same set of fault codes, shown not as lights but as numbers on the Cycle Countdown display. Here, 1 is an aqua sensor fault, 2 is a heating fault, 4 is a filling fault, 8 is an NTC fault and 0 means that everything is working as it ought. During an actual wash, when you aren't testing, the Cycle Countdown display may show the letter "F," which also signifies a filling fault.
Read more: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html#ixzz33JutQVQR
Apr 05, 2014 | Bosch Evolution 300 DLX SHE43P26UC Full...
The control panel on my dishwasher is showing a tap and E15
Mine's a bosch, same problem but started with E25 due to broken glass in the pump impeller, after struggling to remove it and then testing, it eventually moved to E15 as rightly so, no water was entering the machine due to the E25 code. The advice above is good, but take the device out first and tip the machine. This cured my faults without the need for a service call or spare parts.
Mar 27, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
How do you "undo" the aqua stop?
create an inverted trap in ther dishwasher drain line so the water cant back feed
Jul 09, 2008 | Bosch 24 in. SGS43C02 Classixx Built-in...
Bosch dishwasher shu4322 has code 1 aqua sensor what is the sensor do and where is it located
Most of the dishwasher has a Thermal hold period in which the machine will not advance to the next cycle until the water temperature reaches a specific degree. it is possible that your aqwa sensor/or heater is bad OR as in most of the cases, the Timer relay that is responsible in turning the heater on is stuck open, in this case you need a new timer. So,Check Timer/Aqua sensor/Heater
Nov 21, 2006 | Bosch 24 in. SHU66C05 Stainless Steel...
Error code AO1
Jun 27, 2006 | Indesit 24 in. DE73 Evolution...
Bosch
Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
Dishwashers Logo
88 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
