Question about Empire DV-215 Direct Vent Natural Gas Heater
Pilot will not lite
Pilotwill not light, has a new nipple and is getting gas.
  • Empire Master
  • 2,840 Answers
Is the spark right on the pilot , is the spark strong can you see it jumping across tp the pilot try cleaning spark electrode , there could be air in the gas line
Posted on Jan 12, 2009
Why does burners and pilot forced off after burners are engaged
We get asked this question many times.
If you light your pilot light, hold in the button and then when you release it and the pilot light goes out, generally you need a new thermocouple. Gas repairs can only be undertaken by a qualified gas technician so you can't do this job yourself.
The thermocouple is a safety device that recognises that the pilot has a good flame and is enough to ignite the main burners. The thermocouple open that valve to the burner.
In limited circumstances the thermocouple doesn't need replacing, either the shield that aims the flame to the thermocouple has become dislodged, or the pilot jet is a little blocked by debris. Either way, having the appliance serviced by a qualified gas fitter is the way to go. I am sure you will have seen news stories about explosions caused by gas leaks and faulty appliances.
Jan 18, 2016 | Procom Heating & Cooling
Not light
check to make sure that the poilet lite flame is touching the tip or top of the thermocouple.
the pilot lite needs to heat up the thermocouple so that the thermocouple opens the gas to the main gas log. a cold thermocouple shuts off the gas to the main gas log or gas burner and a hot thermocouple opens the gas to the main burner.
the pilot lite flame must be touching the thermocouple to heat it up.
pilot lite orface needs to be clear to let the pilot flame gas through with enough pressure so that the little flame can reach & touch the thermocouple. Pilot lite gas feed tube must be clear to let gas through. Use compressed air or a fine sewing needle, or even carb cleaner to clear out orface hole and gas feed line to pilot lite.
important!! WARNING:
if you use carb cleaner,make sure all the carb cleaner is dry,soaked up with paper towell or kleanex tissue and blowed out with compressed air , because carb cleaner can burn just like gasoline; so any carb cleaner must be compleatly gone before you attempt to lite the pilot lite.
May 20, 2013 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pilot lite won't stay lit
Thermostat flame sensor. Do you see a little rod next to the pilot? That is what tells the main gas valve that the pilot is lit and it is safe to give gas. Easy swap, and you can usually just pick up a generic one.
Apr 14, 2013 | Heating & Cooling
It runs out of fuel
sound like pilot lite is not getting thermocouple hot.
check that pilot lite flame is extending out to and touching thermocouple. If not, clean out pilot lite orface and pilot lite gas feed pipe all the way back to the main gas valve if necessary.
If pilot lite flame is touching thermocouple, then replace thermocouple
Jan 22, 2013 | Mr. Heater Big Buddy Heater
Jandy lite 2 pilot wont light
dirty pilot tubing or weak pilot generator
Dec 04, 2012 | Jandy Lite 2 Natural Gas Pilot Light...
Why does pilot light turns on gas burner only to have it go out about 10 seconds later? 30 to 40 sec later repeats,without lighting. What is problem? once in awhile, it will light..not often. The burner...
Hello
Sounds like the thermocouple is going bad.The thermocouple is a thin tube that runs from the pilot lite to the gas valve.
What it does is it sences the heat from the pilot lite and keeps the gas valve open to allow the pilot to stay on.
This can be easily repaird by shutting off power and gas to your heater and removeing the thermocouple from the gas valve,then unclip or unscrew it from the pilot lite area.
Any plumbing supply store or home depot or lowes should have these.
Once you get a new one,install to gas valve and pilot lite area then turn on power and gas to heater and follow pilot lighting procedure,you may need to hold gas on for 60 seconds.
Here is a picture of the thermocouple so you know what to look for.
http://thermocatalytic.com/Thermocouple.JPG
http://homerepairgeek.com/wp-content/uploads/2010/12/furnace-thermocouple.jpg
Feb 10, 2011 | Honeywell Programmable Thermostat Heater
Can't get pilot light to stay lite in oven
make sure the thermocouple is positioned above pilot light this part needs to be heated up by the pilot light to keep gas going to the pilot light. if the thermocouple is positioned above pilot light and it doesn't stay light, replace thermocouple.
Apr 04, 2010 | Stoves Premier 600GRa Gas Single Oven
Looking to buy pvc pipes to fit Jandy pool heater in and out flow pipes live in slough uk
jandy in and out pipes are 2" schedule 80 cpcv and should beavailable at any plumbing supply house. buy on 16" nipple and cut in half.Thread into headers then pvc cement the unthreaded end to tie into pump/filter system
Aug 21, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Can't re-light the pilot light
THIS HEATER DO NOT HAVE A PILOT YOU MUST HAVE A DIFFERENT MODEL. DO YOU GAS? TURN KNOB TO PILOT PRESS. LIGTH PILOT WAIT FOR 60 SEC AND RELEASE IF STAY ON TURN KNOB TO ON. IF TURN OFF PILOT MUST BE REPLACE
Jun 20, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Laars lite 2 pool heater burner not lite
If the pilot flame is not strong enough, it will not tell the gas valve to open, or if the gas valve is not getting the signal to open, it won't. Check all wire connections at the thermostat and gas valve. Check ground wires. Clean the pilot light and flame rod.
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Empire DV-215 Direct Vent Natural Gas Heater Logo
110 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
rudyjoe
Level 1 Expert
vance jones
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
