Question about Car Audio & Video
How many rms and peak watts does a jbl gt1200d 12 inch subwoofer have.
2 Suggested Answers
theman71177
  • 6 Answers
SOURCE: Subwoofer and amplifier wattage problem
No it will sound good if you can put an amplifier with 500 watts rms it will sound better
Posted on Jan 30, 2010
I just purchased the dual xinbp210 and don't know what size amp i need?
  • Enclosed subwoofer with dual 12-inch speakers; measures 27.5 x 14 x 15 inches
  • illumiNITE technology constantly illuminates the speakers with blue LED lights when in use
  • Handles 600 watts RMS power, 1100 watts peak power
  • Carpeted enclosure, plexi subwoofer viewing window
  • Dual 12-inch Low-Q optimized dri
Mar 26, 2015 | Cars & Trucks
Wireing diagrams for a pair of 12" jbl gt1200D grandtouring subwoofers JBL Grand Touring Series GTO1200D 12" subwoofer with dual 4-ohm voice coils
Check crutch fields website for sub wiring it's really straight forward depending on the desired impedance.
Oct 09, 2014 | Car Audio & Video
What's the max rms on my solo baric L5 12 inch and
600 watt rms 1200 peak you want bout 2x the power so go with a 2400 watt mono and turn it bout 3/4 of the way up and it should sound great
Dec 15, 2012 | Car Audio & Video
What type of amp do I need for apair of rfdj1 12" dj 600w band speakers?
The 600 watt rating is FAKE like most of our advertising and will be either 600 watts PEAK or 600 watts PROGRAM. If it is Peak, use an amplifier with no more than 100 watts a side RMS... If it is program rating use an amp with no more than 150 watts a side RMS but that is pushing it for speaker safety. Also pay attention to the spec of the amp as to what it will output at the impedance of the speakers. I read the spec on the speakers... they are rated 150 watts RMS, NOT 600 watts... Use an amp rated at 150 watts RMS MAXIMUM at 4 ohms per side. Also don't turn up the bass excessively or you be buying new speakers. Twelve inch speakers would be adequate for a 20 by 20 room at SAFE listening levels. If you want driving bass, you need to get an 18 inch subwoofer.
Jul 14, 2011 | Rockford Fosgate Rfdj1 12" 2-way Passive...
My stereo in 1997 chevy caviler is turning off and on when turned up to a high volume. I have a sony xplod 52 watt by 4 channel radio. With two 6x9 sony xplod 50 watt rms and 300 watt peak power in the...
Most likely cause is heat. The clearances behind the radio are often not sufficient to provde the proper air coolling that the higher power radios need. The heat sinks on the rear of the radio require a certain amount of air flow to dissipate the heat generated under high load conditions. If you add summer heat to the equation, you can have the radio going into thermal cutout to protect it circuity.
May 27, 2011 | 1997 Chevrolet Cavalier
Can i have box dimentions for my 12" xplod sub
  • Warranty Terms - Parts 1 year limited
  • Warranty Terms - Labor 1 year limited
  • Product Height 12"
  • Product Width 12"
  • Product Weight 7.8 lbs.
  • Product Depth 6-1/2"
  • Subwoofer Size 12"
  • Resistance (Ohms) 4 ohms
  • Bottom Mount Depth (inches) 10"
  • Woofer Composition Mica-reinforced woven glass fiber composite
  • Woofer Surround Rubber
  • Peak Power handling 1300W
  • RMS Power Range (Watts) 380
  • Cutout Diameter or Length (inches) 12"
  • Sensitivity 84dB
  • Frequency Response 30Hz - 1kHz
  • found at:::---- http://www.bestbuy.com/site/Sony+-+Xplod+12%22+Single-Voice-Coil+4-Ohm+Subwoofer/9202481.p?id=1218057724056&skuId=9202481
Jun 04, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Jan 27, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Finding the best amplifier
Hello sharky75,
That 1600 watt peak power figure for your subwoofer can't tell you what amp you need. You need to know the maximum RMS power the sub can handle. And you need to know the impedance (ohms) of the voice coil(s). JBL GT5 series subs have an RMS rating of 275 watts. The GTO series handles 300 watts. The Power series handles 400 watts. The GTi series handles 700 watts. Some are single voice coil, so the impedance is fixed. Others are dual voice coil allowing you to wire them for different impedance loads.
For maximum performance your amp should be able to provide at or near the same number of watts RMS into the lowest impedance at which the sub can be configured. For example, if your sub is the Power Series Model number P1224, it has dual 4ohm voice coils and can be wired to present either a 2ohm load (parallel) or an 8ohm load (series). You want to wire the voice coils in parallel for the 2ohm load and select an amp that outputs up to 400 watts RMS into 2ohms. The Orion Cobalt CO8001 is just such an amp. If you have one of the GTi Series subs, a better amp would be the JVC Arsenal KS-AR75 which outputs 700 watts into 2ohms.
Hope this helps.
Jul 31, 2009 | JBL Power P1022 Subwoofer - 10" Dual 2...
Woofer,s outer ring is ripped.
To fix this problem, you will need to contact Velodyne.
They may be able to replace the surround or recone this driver.
Because this system has the "servo" control, you need to have the accelerometer conected to the amplifier. With out it, the amplifier will not operate.
Jan 03, 2009 | Velodyne VRP-1200 Subwoofer
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
