Question about Konica Minolta bizhub Office Equipment & Supplies
Bizhub 43 fusing unit reset
Need a solution to reset the fusing unit.
  • 214 Answers
SOURCE: request
if fusing unit life is over you must change it. other spearparts you can order from konicaminolta service.
Posted on May 11, 2008
  • 24 Answers
SOURCE: what fuse to use to reset the fusing unit on a bizhub c352
If you are in the UK you can buy the fuser fuse from RS components it is part number : 541-3221 http://uk.rs-online.com/web/search/searchBrowseAction.html?method=searchProducts&searchTerm=541-3221
Posted on Jun 25, 2009
Bizhubman
  • 108 Answers
SOURCE: how to reset the transfer unit (fuse?), do you
Hope this helps. Make sure you remove the waste tank prior to taking out the transfer belt. Belt is removed by two screws inside right door and sliding the unit out.
Posted on May 17, 2010
xeerie
  • 347 Answers
search in youtube you will get there, what you want,
Posted on Jun 19, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: I have a konica Minolta bizhub C250 and the screen
I can only tell you they are definately resettable as I do it all the time.
The fuser "fuse" is located in the connector wiring. Once you get the fuser out just look in the area where the large connector is. It is a very small fuse similar to a resistor, green, and is encased in shrink wrap.
The Transfer belt fuse is behind a small black cover. If you pull the transfer belt unit out of the machine about 6 inches, it is located on the front right corner. In other words standing in front of the copier with the belt unit partially out it is on the corner closest to you. You have to remove a screw, a c-clip, a small metal plate and the small black cover is held on with a very small phillips screw.
He is the parts availablitity and part number info.
Fuses are available at http://www.digikey.com/
Transfer Belts
Replace glass fuse 80ma , counter resets automatically.
Item # 507-1218-ND
Fuser Units
Fuse is wrapped in shrink wrap. Cut it out and splice in a 1/16 ma fuse.
Item # F2307-ND
Good Luck and Thank You for using Fixya.
Posted on Oct 08, 2010
Konica minolta bizhub c253
what is the question?
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Aug 21, 2014 | Konica Minolta Minolta Bizhub C253 Copier
Bizhub 164 service call no c3451 please help me
Fusing warm up problem.To reset press Utility Stop00Stop01 ,enter in the service mode select Trouble reset.If do not work you have need to remove and repair the fusing unit.
Jul 13, 2014 | Konica Minolta bizhub 200 Printer
Bizhub 43 asking for paper
does that include the by pass tray??? being filled some one is sending a print job that uses the bypass tray
Jan 05, 2014 | Konica Minolta Office Equipment & Supplies
Ihave konica minolta bizhub 43 i replaced anew fuser unit but its still showing consumable error replace fuser unit how can i solve this
Enter in the service mode: press Utility key-Metercount-(Details if exist)-Stop -0 0 -Stop -0 1 select a special parts life or in the counter mode consumable and reset the fusing unit counter.
Feb 04, 2013 | Konica Minolta Office Equipment & Supplies
How to reset the transfer unit (fuse?), do you
Mar 29, 2010 | Konica Minolta bizhub C250 All-In-One...
Where can I get instructions on how to replace the transfer unit of my Bizhub C252?
Please visit the site http://www.resetkit.eu
There you can find how to reset your fusing unit and transfer kit unit for almost all Konica Minolta MFP's and printers, Bizhub C252 included.
You don't need to replace it, you can just reset it and save a lot of money.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
Oct 22, 2009 | Konica Minolta bizhub C250 All-In-One...
How do you reset the life of the transfer unit on the Bizhub C250
Yes,
Remove Trasfert belt unit.
On the left handled remove one screw ( spring fixer) and remove right srew (over the belt / bar whit finger fixee).
Remove, on the left spring stoppage and metal handled.
Remove black little srew and take to hand fuse contact.
Change fuse (behind) with new identical fuse and reassembly.
It may be reset trasfert belt counter.
Sorry for my not good english.
Bye.
Feb 14, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Request
May 05, 2008 | Konica Minolta bizhub C250 All-In-One...
153 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
