Question about Sharp AR-5316 Advanced Digital Imager Copier
SHARP AR 5127 error f9-88 call for service - Sharp AR-5316 Advanced Digital Imager Copier
mickspaceNET
  • 115 Answers
SOURCE: error messsage cal for service E1-88 from sharp AR-5127
Unplug the Machine, remove the board you installed, re-seat the board,
make sure everything is connected, turn machine back on..
This is what the Manual says:
IMC PWB communication trouble (Timeout)
Check the connectors of the IMC PWB
and MCU PWB.
Check the grounding of the copier.
If you need further help let me know..
Posted on Oct 26, 2008
  • 37 Answers
SOURCE: AR-5127 Counter Reset
Try these steps
1.Press continously #key then Interrupt key then CA key then # key
2.If the display turns off it means that you are inside the simulation but if not do again step 1.
3.Press 81 then press enter then press 1 then enter
Hope that this will help to reset .
Posted on Mar 03, 2009
M2Tech1
  • 313 Answers
SOURCE: ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Posted on Jun 12, 2009
  • 118 Answers
SOURCE: U2-40 error on Sharp AR 5127 copier
try this pres the ff: # >interrupt> C >Interrupt
input 16 then follow instruction
this is related when you install not original toner or not compatible one
Posted on Jul 21, 2009
  • 257 Answers
SOURCE: Solution for SHARP AR 5127 error U2-40 call for service
This means that the cartridge's sensor is miscommunicating with the copier memory thus the code U2 -40. You should clean the inner sensor connector and the toner sensor of the spilled toner by low blower. Perform this code ;# , interrupt , C, Interrupt keys in that order and press 16 then Print key and the code will be cleared.
Posted on Feb 12, 2010
Feb 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
Error code sharp 5127
go to percision roller in phx arizona you can get all sharp service manuels i have alos seen them on ebay?
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
it is a heater code. The thermostat has blown and resetting the code could cause a fire, but it probably won't do anything, the part will need to be replaced
Jan 16, 2009 | Toshiba e-Studio162D Copier
Sharp AR-5127, the error code U2-40
U2-40 is a board error, F1-15 is finisher lift motor error.
To reset: #, interrupt, clear, interrupt. (screen should say service mode), enter 16, print, are you sure? , yes.
For the finisher error, follow above procudure, entering 14 instead of 16. if error returns, disconnect the finisher
Nov 26, 2008 | Office Equipment & Supplies
Error messsage cal for service E1-88 from sharp AR-5127
and MCU PWB.
Oct 26, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
98 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
