Question about Panasonic NN-S540BF Microwave Oven
Stop working I have a NN S540BF Panasonic microwave oven that just stop working. I don't see a reset button, and the outlet and my circuit breaker are both fine. Please advise
  • desai11 Jan 12, 2009
    How do I remove the cover and where is the fuse located?
  • Anonymous Mar 23, 2014
    outlet works, no circuits tripped, one moment working fine, next completely dead
    New Friend:
  • 111 Answers
IS IT POWER UP.
please rmoove the cover and check the fuse also.
is it work?????
nuwan
Posted on Jan 12, 2009
  • nuwan chinthaka
    nuwan chinthaka Jan 13, 2009
    PLEASE INSPECT THE BACK COVER CAIRFULLY
    and you will find the few screews back or down side.
    main fuse is clipped to printed circuit board genarally.
    also you have to check thermostats also.find the multimeter as wel for this purpus.
    nuwan
Where is the fuse on Panasonic NN-S252
You may have to remove the cover on the microwave to find a fuse. It may not be either in a fuse holder or soldered into a the circuit board. be sure it is not plug up when you check.
if you find it be sure and replace with the fuse with same current rating.
Aug 01, 2014 | Panasonic NN-S252WF Microwave Oven
Panasonic genius 1200w
You may have a failed keypad or moisture or grease on the keypad innards or on the control circuit board itself.
You can find a video here that shows you how to remove the grille & controller in about 5 minutes if it's an over the range model.
You can order Panasonic parts from Encompass here http://tinyurl.com/7qy85y or you can call them toll-free at 866-779-5835.
May 02, 2013 | Panasonic NN-H764 Microwave Oven
My microwave shut off after microwaving two popcorns. what do i do? Did i break it?
unplug the microwave and plug something else into that outlet to be sure you have power there. If there is no power you will have to reset the circuit breaker or change the fuse in the electrical panel for the dwelling.
If the outlet is good most likely the internal fuse in the microwave will have to be replaced.
Oct 10, 2009 | Panasonic NN-S540 Microwave Oven
Buttons not responding on nn-s235
My microwave nn- s235 have the same problem only stop botton waork but no child is displayed in the display
Jun 14, 2009 | Panasonic Microwave Ovens
Has no power
If your microwave oven doesn't seem to work at all, check these: Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
thanks
Mar 18, 2009 | Panasonic NN-SN657SMicrowave Oven
No power to Panasonic NN-S252 microwave oven
follow the incoming mains lead into the microwave their is a small pcb with a fuse their check this first
Nov 14, 2008 | Panasonic NN-S254BF Microwave Oven
Panasonic model nn-s540bf starts but only runs 5 seconds then stops.
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
In most cases, this is a problem with the controller, or inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Microwave Ovens
No cook mode
check control circuit, and check highvoltage section, and all the door lock switches, and sensors, chaeck over all circuit..
Oct 07, 2007 | Panasonic NN-S540BF Microwave Oven
Panasonic NN-S540BF Microwave Oven Logo
945 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
