Question about Philips DVP5140 DVD Player
Philips DVP5140 Fix Here!
I fixed my Philips DVD player today.
The screen would pause saying "Loading" then eventually said "No Disc"
Do this:
1- Bring it out of Standby (power it up)
2- Open the Disc Tray
3- On remote press SETUP
4- Right arrow over to the Preference Page
5- Down arrow to bottom of the menu where it says Default (word Default will turn yellow)
6- Right arrow over to RESET (word RESET will turn yellow)
7- Press OK
8- Try to load a DVD
  • Anonymous Feb 06, 2009
    Hello, My Dvd player can play Mp3s as well as VCds but DVds have stopped working since 15-20 days now, It never came up with any problem for more than a year. I have tried the Lens cleaner and also I have tried Set up >Prefrence >Default >RESET even this hasn't worked. If any suggestions pls post or right to me on hemant_rana@tiscali.co.uk
  • barlotti Apr 18, 2009
    Used to unlock code to region 0, and did the reset thing... Not working yet.
  • 476 Answers
SOURCE: Philips DVP5140
The only way to completely power off is to remove from the mains outlet.
Posted on Feb 22, 2008
SOURCE: My dvd model is philips dvp 3005 and it is in standby mode
my dvd player did the same problem. and i solved this just with a screw driver:) if your dvd player s guaranty finished!! switch off the player and open the screws which r 2 on sides and 3 behind the dvd. open the cover and take off the two group of cables on the chipset which are on the mechanical part side! (mechanical side: dvd driver) than plug the cables again to their socket. its done! close all and go on ! i hope this will solve your problem as mine...
Posted on Feb 18, 2009
  • 6 Answers
SOURCE: DVD PLAYER DISC TRAY DOES NOT OPEN
tap it gently from the side while pressing the button......or with a knife try to open it gently...while pressing the button....after it,s open..clean the side n the belt..
Posted on Jun 26, 2009
hayster
  • 103 Answers
SOURCE: Philips DVP5140 region-free DVD player: NO DISC
You could try cleaning the laser using a laser cleaning disk. Most of the time when it cant read a disk its just because the laser is dirty. If that doesn't work it could just be a faulty laser
Posted on Sep 22, 2009
  • 56 Answers
SOURCE: Disc tray does not open...
completely reset the player, unplug the AC
cord from the AC outlet for 5-10 seconds
Posted on Mar 21, 2010
Is there an easy fix when the dvd keeps spinning and screen says loading but does not play?
You have to clean the dirt off the laser lens inside as it cant see the codes on the disc.Use a cleaning disc first or it will have to come apart to clean.
Dec 06, 2013 | RCA 9" Lcd Portable Widescreen Dvd Player...
Philips DVD Player DVP5140
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
8. Press the "Play" button on the remote
Aug 12, 2008 | Philips DVP5140 DVD Player
The button to open/close my Philips DVD player Model DVP5140/37 is not functioning, and the remote does not have an open/close button. How do I fix this??
Here are some troubleshooting steps to get you started to resolve the issue.
First, Try to unplug the unit for 10 seconds from the power source. Wait 10 seconds after unplugging and reconnect. Try to open/close and see if the tray opens. This may resolve the issue as this is what Philips Technical Support says to do in this situation on their website.
Also, you should be able to eject with the remote. To eject or open the disc tray with the remote, you need to hold the STOP button on the remote for 5 seconds.
Hope this helps! If not, I was told to give a direct phone call to Philips Customer Care Center from 12pm-8pm EST Monday-Saturday. Their phone number is 1-866-323-9916. Have the device/unit ready when you call with the Serial Number handy.
Warm regards,
Craig
Mar 20, 2011 | Philips DVP5140/37 DVD Player
My philips dvd player is not detecting any cd or dvd, it is saying no disc after a long wait. Any idea in this, please help.
well try to purchase a dvd lens cleaner and insert it into the player for cleaning. After that process has been executed you can now insert your choice of disc for play..
Jul 23, 2010 | Philips DVP5140 DVD Player
Disc shows loading then error on all dvd disc
Put a cd in the dvd player if it is marked that it plays cds... if it plays the cd your dvd laser is shot... cheaper to get a new unit. if it doesn't play a cd try cleaning the laser. and last but not the last thing try unplugging it for a short time then plug it back in... if nothing works get the one tool that fixs most everything...... take it to office depot and they can recycle the stuff inside and help keep the earth green...then onto wally world.
Nov 26, 2009 | Philips DVP5140 DVD Player
Sep 21, 2009 | Philips DVP5140 DVD Player
Dvd is not reading
After loading a dvd screen prompts "loading" then "no disc." Even with a brand new disc.
Qaung
Dec 08, 2008 | Philips DVP5140 DVD Player
1. Turn on the unit
5. Enter 138931
DVP5140 only reads DVDs
The DVD player have two lenses.;cd and dvd lense,the cd lense needs a little adjusment so can read again..
Jun 19, 2008 | Philips DVP5140 DVD Player
Half the screen is blue
Reset. If fails, call Philips to see if you are still in warranty
Dec 16, 2007 | Philips DVP5140 DVD Player
Philips DVP5140 DVD Player Logo
249 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
