LG washing machine Model # wm2077cw
Washing machine flashes LE after I started the load, Just after It worked fine on two previous lite loads.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
LE is a locked motor error. If this happens often then 95% of the time this is just a bad hall sensor (motor position sensor). A technician should be able to ohm out the hall sensor to make sure. The part is relatively inexpensive and easy to replace.
This can also happen if the motor is overheating slightly from being overfilled (too many clothes) or if you do one load after the other and do not allow at least 10-15 minutes between loads for the motor to cool down. In this case the LE error will only happen occasionally.
Hope this helps, please rate my solution.
Posted on Jan 11, 2009
Lg front loading washer flasing LE and stops midcycle
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
Jun 16, 2012 | LG WM-2277HW Front Load Washer
ERROR CODE LE ON LG FRONT LOAD WASHER
LE is a locked motor error. Not to worry as 95% of the time it is just a bad hall sensor (the motor position sensor). For your model the part number is 6501KW2002A.
May 28, 2010 | Washing Machines
LG Tromm WM2077CW error code LE
No all you have to do is watch how much and what kind of soap you put in that washer...
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
Apr 15, 2010 | LG WM-2277HW Front Load Washer
LE code appeares on my LG front load washer
A majority of the time when the LE code appears.. the Hall sensor in the motor is bad. Replacing it. Part # 6501KW2002A from MCM electronics... can help. Good luck.
Nov 17, 2009 | LG Washing Machines
LE CODE AND A BURNING SMELL
The LE code represent a failed or locked motor. the replacement of the electrical motor will be needed in this situation.
Jul 19, 2009 | LG WM2077CW XL Front Load Stackable Washer...
LE error message - how to finish the wash cycle?
error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff.
If not, you need to call tech.
Thanks.
Jun 17, 2009 | Washing Machines
Start/pause switch works intermittently. How do I
i have found that the micro switch burns out on them and needs to be replaced. remove rear screws remove top cover , remove shield the unclip cables and front panel
Use a multi meter to test micro swicth on circuit board replace if faultsy
Mar 06, 2009 | LG WM2077CW XL Front Load Stackable Washer...
Wm2077cw
Your motor sensor has failed.  Try unplugging the unit and wait 5 minutes before plugging it back on.  If that fails, you will need a qualified LG technician to help you.
Jan 15, 2008 | LG WM-2077C Front Load Washer
Washing Machines Logo
227 people viewed this question
Top Washing Machines Experts
