Question about Cell Phones
Sony Xperia Sola Not charging while connected with PC
Not Charging while connected with the PC
SOURCE: my sony xperia wont charge I connected it with the
change the usb ic
Posted on Dec 24, 2010
SOURCE: my sony ericson xperia 10
hi my sony erricson x10 is charging through my usb but not my wall socket, bought a new charger and tried a different socket but still have the same problem?
Posted on Mar 13, 2011
n00h
  • 624 Answers
SOURCE: Hi One month back I bought
Hello and welcome to FixYa!
This may happen, don't worry. There may be different reasons behind this. First things first. Do this; Use your phone, and drain the battery to 0%. The phone will switch off at 1 or 2% turn it back on and use it, it will again turn itself off, then again turn it on until no charge is left. After achieving this state, charge it as normal and see if it goes to 100%.
If again not, then put the battery out for an hour and put it back on then try to charge it to 100%.
If in case the problem is still there, then I'll recommend you to update your phones Firmware, to do this you need to have the USB data cable of your phone, if you have it kindly download this application, install it and follow the instructions.
NOTE: Make a backup of all your data and contacts before an update.
If after all this struggle you find yourself again back there, time to get a new battery or use it as much you can.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
Posted on May 10, 2011
walesarumi
  • 6993 Answers
SOURCE: charging prblem sony ericson xperia x10 red light
do you know anyone that uses a Sony Erricson Xperia X10 phone? If yes, borrow the battery and test it with your phone. If your phone turns on with the borrowed battery, then this confirms that it's a charging problem.
Read my tip on the below link, to diagnose and solve the problem.
Click here: http://www1.fixya.com/support/r8742993-phone_charge
If the contents in the above link doesn't help, please let me know for further assistance.
Regards.
Walesarumi
Posted on Sep 29, 2011
walesarumi
  • 6993 Answers
SOURCE: sony ericsson xperia x10 charging problem
Regards.
Walesarumi
My sony ericsson xperia mini pro wont turn on
First, check if the charging port is properly and snugly connected. Then, check your batteries. Maybe your batteries aren't charging properly. If the battery is self-replacable, try cleaning the golden battery connectors inside first. Or, your battery may need to be replaced
Feb 02, 2014 | Sony Ericsson Xperia mini pro (SK17/SK17i)...
Sony xperia screen number lock is not working how can i change that
Go to 'Settings'.
Select 'Security'.
Select your preferred screen lock, which I believe is PIN / Password?
Nov 22, 2013 | Sony Mobile Phone XPERIA Sola MT27i White
MTP device USB driver
i have a problem to see my file on the sony sola phone when I coonect it with a usb cable
Feb 23, 2013 | Sony Ericsson Sony Xperia Sola Red, 8gb,...
Sony experia mt27i hangs
download firmware&drivers fastboot& flashboot
download flashtool for xperia
In program choose unlock bootloader
last flash your firmware
(fastboot vol up+power blue ligth)
(flashboot vol down+power green ligth)
Jan 17, 2013 | Sony Mobile Phone XPERIA Sola MT27i White
Sony xperia x10 went dead wont charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Nov 12, 2012 | Sony Ericsson XPERIA X10 Cell Phone
Ip address for sony xperia sola
You can check the Ip-address of your sony xperia sola mobile phone at
Ip-details.com and know the details.
Oct 06, 2012 | Sony Mobile 1262-4171 Xperia Sola Mt27i...
Unlock code
First Option:
Second Option:
Aug 31, 2012 | Sony Ericsson XPERIA X1 Smartphone
My XPERIA X8 is charging properly with a Charger but it does not charge with a USB Cable 2.0 when i connect it with the PC, it shows orange light but it does'nt charge at all... it started happening after...
I have the X10 and it charges but very slowly.
Make sure that you DON'T mount your sd card when you connect your phone.
If you just leave it you should see your battery icon scrolling up through the colours as though it is charging.
That means it is charging. As I say though...It's very slow!.
Try unplugging from the computer and from phone then plug them in again. Sometimes this works for me. :)
Updating shouldn't have a detrimental affect on hardware so I shouldn't think the problem is terminal.
Mar 01, 2011 | Sony Ericsson Xperia X8 Charging USB 2.0...
Xperia x1 won't charge. The charging symbol will appear on the screen for a short period of time (perhaps 2 or 3 minutes) before disappearing a showing the full battery symbol. This shouldn't appear...
First try to replace the battery, a drained or low voltage battery won't charge up.
For infos on how to fix the Sony Ericsson Xperia X1 Not charging:
http://mobilephonerepairguides.blogspot.com/2011/01/sony-ericsson-xperia-x1-not-charging.html
Aug 31, 2010 | Sony Ericsson XPERIA X1 Smartphone
Cell Phones Logo
266 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
