Question about Siemens Washing Machines
I cannot open my s12 44 washing machine
I cannot open the door of my front load washing mashing, but it keep on spinning.p
  • 1314 Answers
SOURCE: Front Load Washing machine won't spin, drain or rinse
if you have a shop vac this is time to vacuum the water of the tub and all the way down the drain hole for the next stage usally i tell customers to remove the drain hose from the stand pipe and vacuum the water out of the washer from the drain hose but because of the pillow this might not work in your case. Now remove the two screws on the front lower panel and pull the panel
in side you will see the drain pump if you did not have a shop vac go to the auto parts store and buy a pair of radiator hose clamps and clamp the hose line as close to the washer as possible.(but put down some towels as water always stays there) then pull the tub to pump hose by depressing the squeeze clamp(now while your at the auto parts id get a screw clamp to replace the spring clamp it makes putting the hose back on a lot easier)pull the hose off.Then pull the pump to drain hose off .Remove the two 5/16 in screws securing the pump to the washer base.Unplug the connector and remove the pump inspect the pump for foreign objects,broken or stripped impeller blades . if the impeller are stripped you will have to replace the pump then form the front of the washer take a piece of water hose with one end cut off and run it down the pump to drain end of the drain and reassemble the unit
Posted on Jan 18, 2008
SOURCE: GE Adora Front Load Washing Machine Problem
I had a similar problem...with the added issue of the door not locking at all. I cleaned the filter and all is well. However, it took me hours to find the 3 screws everyone was talking about The screws are at the very bottom of the washer, under the lip, facing front. If your machine sits on a pedestal drawer like mine, they are located between the machine and the pedestal. I hope these pics save someone a little time...
Posted on Aug 27, 2008
huuum
  • 750 Answers
SOURCE: Getting HF error, on Whirlpool Front load washer
Dear jodyheidi,
Welcome to fixya.com
I'm Huuum and happy to assist you,
Try this first and if it fails to remedy the problem then call service as you wanted!
Huuum At your service!
With an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
let me know how it works out.
How old is the appliance?
Let me know how you progress!
Bless You, Huuum
Please remember to leave a rating when you are finished!
Thank You
Posted on Sep 23, 2008
SOURCE: euro tech front load washing machine
YOU CANNOT RESET ERROR CODES ON APPLIANCES BY MERELY UNPLUGGING THEM FOR 5 MINUTES. MOST MANUFACTURERS RECOMMEND AT LEAST 30 MINUTES IF YOU GOING TO ATTEMPT TO TRY TO RESET A COMPUTERIZED CONTROL BOARD. STOP POSTING THIS INFORMATION INCORRECTLY.
Posted on Sep 30, 2008
SOURCE: FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
My front load washing machine agitate but won't spin
If your machine is rather old or used quite frequently, you should check out the motor brushes. Go to youtube for details on washing machines brushes.
Mar 06, 2015 | Washing Machines
Agitates but won't spin in rinse
The dor switch is not closing. Open the door and there will be a littel rectangular spot above the drum use a pencil or something like and mash it down if it starts the piece on the door that's suppose to push it down i s probably broke
Jun 21, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
How to operate the washing machines front load washer brandt bf850
  • Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
  • Fill the detergent receptacle on the front of the washing machine, making sure not to fill it past the indicated line. Always use a liquid detergent that is designed for front-loading washing machines.
  • Add bleach or fabric softener, if needed. Most front-loading washing machines have a section for fabric softener inside the detergent receptacle. Check the instructions on the bleach to find out when it should be added to the washing machine.
  • Close the front door of the washing machine and make sure it locks into place. The machine usually will not turn on unless the door is securely locked.
  • Check the owner's manual to find out how to select the different options and wash cycles. As a general rule, use warm or cold water for most types of colored clothing. Hot water should only be used when washing white cotton items.
  • Start the front-loading washing machine and let it run through the entire wash, rinse and spin cycles before opening the door to unload the clothing.
  • Please rate this solution. Regards.
    Nov 04, 2010 | Brandt WFH1176 Front Load Washer
    Afrer washing it stops spining and all the lights start flashing the door will open but the washing is still soaking wet
    Problems with a washing machine not spinning or not draining are often inter related..
    If you are having a problem with your top load washer then check out this tip...
    Washing Machine does not Pump or Spin
    If you are having problems with your front load washing machine then checkout this tip...
    Front Load Washing machine not draining and or not spinning
    heatman101
    Aug 28, 2010 | Hotpoint Washing Machines
    FRIGIDAIRE AFFINITY LTF600 FSO PUMP KEEP,S RUNNING AND WONT SPIN
    I fixed mine by replacing the door lock they are about 50.oo
    The door lock has two locks, one is instant when you push start the other is a time lock, so you cant open the door for a little if you stopped it during the spin cycle. The problem is what they call the WAX switch or heater. When power is applied to this WAX lock it takes 30 to 60 sec. to lock and to unlock when power is removed.
    The machine will not spin, if this lock is not working correctly.
    You cant bypass it by jumping the power from one side of the shitch to the other. The board moniters the power draw and when the switch closes the lock contacts. You can how ever open up the lock very easy and bend the contacts closer to get you by for the weekend. unplug washer, remove the two screws on the back of the top panel behind the washer, remove top, open front door and remove the two screws that hold the lock, reach in an pull up the lock, remove wires, now open up lock and bend the piont contacts in side or install new switch.
    Aug 07, 2010 | Washing Machines
    Please help! My samsung 7kg J845 front loader keeps flashing UE on the error code (spin cycle) and I can't open the door. Sarah
    Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
    Oct 22, 2009 | Samsung WF337AA Front Load Washer
    Bosch washing machine won't drain and the door won't open.
    Sounds like you have a blocked pump.To empty the machine manually lower the drain hose into a bowl or bucket.Once emptied the door should open.On most modern machines there will be a filter behind the kick plate at bottom front of machine, Check this for any foreign objects then try a spin before putting on again.If problem persists come for further options.
    Nov 22, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
    Stopped operating in the spin cycle
    With a heavy blanket you probably have an out-of-balance condition which doesn't let the machine spin out and drain. This would keep the door lock from opening. Try hitting the Stop button twice. This should cancel the cycle and let the door lock open after a little while. Then either redistribute the load or add some items and run a Spin and Drain cycle.
    Mar 05, 2008 | Kenmore Elite 45986 Front Load Washer
    FRI/FWT449GFS Front load washer manuf in 1999
    The interlock is going, Ifr you want to repair Unplug machine. open door and remove just the front part of the door seal, theres probably a metal band around it. where the door catch closes you will see two screws, remove these keeping you other hand around the back, behind screws holding the plastic interlock, there will be three wires attached to this or a plug remove these, remembring where they go, and take the interlock to the local shop. they cost no more than 20 pound
    Nov 16, 2007 | Frigidaire ATF6000ES Front Load Washer
    Washing Machines Logo
    110 people viewed this question
    Top Siemens Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
