Question about Vizio Televison & Video
2007 vizio l42 hdtv power light is green but no picture
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
dsacco86
  • 1077 Answers
SOURCE: vizio L42, wont turn on
Usually when this happens, the TV is in Protection Mode. When the TV detects something has gone wrong inside, the TV will prevent itself from turning ON.
Try leaving the TV unplugged for 30 -45 minutes so the TV can discharge and reset itself. If this doesn't fix the problem, most likely it's a power supply board related issue. At that point, you may want to get a price quote from a local TV repair shop. The cost of fixing the TV may exceed the price of a brand new TV.
Posted on Aug 07, 2009
SOURCE: Vizio 50 inch plasma tv has no picture and no
check the Y-sus and Z-sus board
Posted on Nov 02, 2009
1joester2
  • 74 Answers
SOURCE: I have a Vizio hdtv 32
I would guess the power supply went bad. The Vizio parts store sells the replacement for $82. Cheap fix for a decent TV.
Replacing it only requires a moderate mechanical skill. Removing the screws from the case is the hardest part. Remember to unplug the TV before you attempt this repair, or contact a local repair shop. They may only charge a small fee to install it for you.
Posted on Dec 19, 2009
Testimonial: "Thanks I thought that might be the problem.... Do you have a web address for the vizio parts store?"
budmrtn
  • 11361 Answers
SOURCE: WE BOUGHT A VIZIO GV42L
The power supply may have failed, or it is in the safety shutdown mode due to short circuits in the power supply or in the backlight inverter board, you can try disconnecting the power cables to the backlight inverter board to see if you can get the TV to come on with sound but will not have picture.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 21, 2010
My vizio 50 in tv powers on and green light comes on but it dose not display picture
This is a command fault. The Inverter is the most command reason.
flattvparts.co.uk
01329 825 403 - Monday to Friday 09:30 - 17:00
Dec 19, 2012 | Vizio P50HDTV20A 50 in. Plasma HDTV
LG 32LC56 back light on no picture
hello..
That problem is usually cause of bad t-con board..
just replace it to fix the issue..
Aug 25, 2012 | Vizio L32 32 in. LCD HDTV
Vizio p50hdtv10a led light blinks 10 times when powered off
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 16, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Power Light comes on but no picture or sound.
for your VP50, it could just be simple as a power supply but it could also means more. Do you have the amber LED light when off and green when on? if so, try the main board first. If that doesn't resolve the problem, then change the sustainer boards.
May 28, 2009 | Vizio L32 32 in. LCD HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have a 42 inch vizio plasma t.v. and I have power but no sound or picture, I've unplugged it all night and still doesn't work! It's
For the 42" plasma, you need to change your sustainer boards or your main board to fix the problem. If your TV is still under warranty, call 877-MY-VIZIO and they will have a technician go to your home and fix the problem for free.
For the L42 HDTV, you need to change the inverter boards or the main board. If your TV is still under warranty, call 877-MY-VIZIO and they will have a technician go to your home and fix the problem for free.
Jan 26, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
