Canon ir3300 sorter jams - Office Equipment & Supplies
5 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: CanonIR 5570 Copier reboots then jams at sorter
Sounds like the sorter connection between the two is poor or disconnecting, check the cable from sorter and power lead to the sorter are secure.
Check switch that machine uses to know when sorter is engaged is closing proberly/not bent
Check sorter indicator lights (if any) after reboot,
Try running lead to it from elsewhere in case there is too much drain or something weird with power supply where you are
Posted on Jan 12, 2008
Cogz
  • 1326 Answers
SOURCE: Jammed paper at the Sorter Unit
Do you get a paper jam or is the finsher not showing that is empty? You may have a broken bin or a miss alined bin or you have a lazy sensor flag. The copier should give you a idea where the paper jam is... May need more info. on this one..
Posted on Jun 07, 2008
checkitright
  • 1362 Answers
SOURCE: Canon NP 6025 Sorter error
if you tell us what the problem or error code is ??????????????????????
Posted on Sep 10, 2008
  • 92 Answers
SOURCE: Sharp SF 2030 check sorter problem
follow the small holes on the sorter trays to the bottom and top there you will find the sensors that tell the copier that ther is paper in the trays make sure that they are clean and ther is no obstruction
Posted on Jun 29, 2009
Canon ir3300 showing paper jam in 2nd tray but thre is no paper jam in it
  1. Locate and dust your paper sensor eyes
  2. make sure paper size adjuster for tray 2 is locked at proper position.
  3. Examine pick up roller from tray 2, clean or replace as necessary.
Mar 12, 2015 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
How do I disconnect finisher for Canon IR3300. Can I get a picture of the specific part?
Disconnecting the sorter if you have the external finisher is easy. Just follow the cable from the finisher/sorter to the copier and unplug it. However, if you have the internal type sorter, the disassembly to remove / disconnect it is quite involved/difficult. You'll certainly need a tech, if that's the case.
Sep 02, 2014 | Office Equipment & Supplies
i m using canon ir3300 , showing paper jam at left side , but i checked there is no any paper, although there is showing jam. what to do.
Jul 17, 2012 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Trouble getting ''copy'' from copier to sorter. gets stuck in btwn
Clean the exit parts rollers,lever and the sorter roller and bins.
Nov 23, 2009 | Office Equipment & Supplies
The Staple Sorter feeder has stopped working. The copier works fine but it becomes jammed when it reaches the staple sorter. Remove the sorter and the pages come out.
if you have blower,air blown the whole sorter unit it could be there is a sensor that was dirty or contaminated by dust. hope this will help
Jul 08, 2009 | Canon NP 6035 Copier
Error code E522. How to fix this?
You have an issue with your staple finisher, probably need to inspect the stapler unit itself to make sure nothing is jammed in it and it moves freely. If you can't clear the error then most likely the unit is defective.
Hope this helps,
TankMurdock
Apr 24, 2009 | Canon NP 6551 Black and White Copier
Jun 06, 2008 | Canon NP 6050 Copier
E531
Check your stapler. If you removed a jam from the sorter you may have accidentally moved the stapler so it is not sitting at a 45 degree angle when you open the front door of the sorter. There's a little lever you can push to swivel the stapler, however don't try to force it. You may have to pry up the plastic lock that is under the stapler with a small screwdriver. Sometimes the stapler assy has to partially removed (slid to the front) of the sorter to be able to see what you're doing.
May 14, 2008 | Canon NP 6551 Black and White Copier
Jan 12, 2008 | Office Equipment & Supplies
21 people viewed this question
jasbo
jasbo
