Question about Warrior 797146022002
Installing usb mouse on windows 98 without 98 install disks.
Trying to get a Belkin three button usb mouse to work on my older ibm notebook running windows 98. Windows reports no driver installed for the mouse. I have downloaded several driver files but windows will not read them, just keeps asking for the cd installation disk which I do not have. I bought this laptop used with system installed. The three files it requests are hidclass.sys, hidparse.sys and hidusb.sys. I provided these on floppy but it says "no usable info found" or something to that nature. Am I missing a install file or something that should be on the floppy as well so windows will read those drivers ?? thankyou dm
  • 1 more comment
  • Don McAllister Jun 11, 2007
    Problem solved. Just needed a couple of more files that made up the driver package.
    Works just fine.
    Thanks for all help.
  • culloden Nov 26, 2007
    how do i onstall usb mouse on windows98 without install disks?
  • Sne2506 May 21, 2008
    Want to install USB mouse in WIN 98. Have the WIN 98 disks, but not working. Can I have the solution?
3 Suggested Answers
SOURCE:
  • 1481 Answers
SOURCE: usb device not detected mouse
try a new mouse or try the current mosue with another PC that will give u a fare idea of what's wrong...if the mosue is ok then it should work in another PC else, u nned to get a a new mouse...
another option is to buy a new PS2 mouse that can go into the external keyboard/mouse point behind the laptop, that way if there is an issue with ur USB port it will be known...
Posted on Dec 17, 2009
Shayna
  • 64 Answers
SOURCE: Trouble installing driver in Windows 98 without original install disks
I would look for the whole driver package from http://www.driverguide.com If you have the files downloaded why are they on the floppy? You can point the installation to any location, including the hard drive of the laptop. Driver guide does require a (free) membership to download, but it's a great site.
Posted on Jun 08, 2007
Belkin wireless mouse won't connect on power up of PC
A Belkin Mini Wireless Optical Mouse frees you from the restriction imposed by the limit of the wire that your mouse uses to connect to your computer. The Belkin model works up to three feet away from the receiver and operates on a 27 MHz frequency. It's smaller than a regular mouse, making it easy to add it to a laptop case or desk drawer without losing much space in the process. Before you can use the Belkin Mini Wireless Optical mouse, you must install it. The receiver and the mouse should sync automatically; if they don't, you must perform the sync manually.
1 Press the bottom release tab on the top cover of the mouse. Insert the batteries included in the package and replace the cover.
2 Turn on your computer. Plug the Belkin USB receiver into a USB port on your computer. The drivers will install automatically.
3 Press the sync button on top of the USB receiver and then press the sync button on the bottom of the mouse to connect the two devices.
Warning
  • close Before you can install the Belkin mouse, remove drivers for other wireless mouse types on your computer.
Jul 17, 2017 | Belkin Mini Wireless Optical Mouse...
My IBM Think Pad 240x hard disk damage; i brought a hard disk, please give me instruction how i install Windows2000 or Win XP, I have a USB CD rom but not supporting.
First I suggest you install Windows XP but you need the Windows installation CD and the product installation code.
Second, the USB ports and therefore the CD ROM drive will not work until Windows XP has been installed, unless the BIOS supports the USB ports and you can make the USB port/CD ROM as the first boot device.
After installing Windows you need to install the ThinkPad's device drivers.
The same model ThinkPadcan have different types of network, video and audio drivers and unless youknow exactly which one is installed in your ThinkPad, you need to download allthe drivers and install each driver until you find the right driver. When you download thedrivers, write down the device driver and it's file name so you have a recordof which driver you are installing and which directory the unzipped files arelocated on your hard drive. Go to the IBM/Lenovo WEBsite - support/download page and download the latest Windows XP or Vista devicedrivers for your model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true You can download thevarious drivers and then you click on and run the various driver files, theywill then unzip and expand into a sub folder on C:\drivers Then install thevarious drivers from this folder (run the set-up file).
Nov 12, 2010 | IBM ThinkPad 240X Notebook
A printer error has occurred. See your documentation
What are the system requirements for using this printer? A: PC Compatible Requirements
- An IBM (r) compatible PC with at least a 486/66 MHz (for Windows 98) or Pentium (r) 133 MHz (for Windows 2000) processor (Pentium or higher processor recommended)
- Microsoft (r) Windows 98 or Windows 2000
- At least 16MB (for Windows 98) or 32MB (for Windows 2000) of RAM (32MB for Windows 98 or 64MB for Windows 2000 recommended)
- 50MB of free hard disk space (100MB or more recommended)
- VGA or better display adapter and monitor
- CD-ROM or DVD drive for installing the printer software
- USB connection: a computer running Windows 98 or Windows 2000, with a Windows-compliant USB port and a shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction. Apple Macintosh Requirements
- An Apple (r) iMac (tm) series or Power Macintosh (r) G3 or G4 with USB port
- For iMac: Mac (r) OS 8.5 or later (Mac OS 8.5.1 or later recommended)
- For Power Macintosh G3 or later: Mac OS 8.5.1 or later If your iMac is running OS 8.1, you need to upgrade your operating system before installing your printer software. To find out which operating system your iMac is running, select About This Computer from the Apple menu. If you're running OS 8.5 or 8.5.1 on your iMac, Apple recommends that you install iMac Update 1.1. Download the update for your system from Apple at http://asu.info.apple.com. Contact Apple if you have problems installing an update.
- 16MB of available RAM (more recommended)
- 50MB of free hard disk space (100MB recommended)
- VGA display or better
- A shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction.
Oct 27, 2010 | Epson Stylus RX580 InkJet Photo Printer
IBM thinkpad problem. Mousepad isnt working. Mouse wont move, we have no mouse that we could plug in, help!
re-installing the mouse/trackpoint driver then restarting the laptop usually soles this issue.
if you are running windows XP or 2000 then the driver can be found here for free download-
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4KMUYL
if you're running a different version of windows let me know.
//javaftper
Jul 30, 2010 | IBM ThinkPad A31 Notebook
I cannot get my mouse to work on my IBM laptop thinkPad. Any ideas???
If its a usb mouse then I would try looking around online for a driver for it and downloading and installing this driver.
If its not a usb mouse make sure the computer is turned off when you plug it in.
Jun 02, 2010 | IBM ThinkPad A31 Notebook
Installing windows on acer notebook help
you cannot usually switch installed operating systems from computer to computer like that and still expect windows to boot, but with windows 98 it *might* work.
to install windows 98 on the usb drive, insert and boot from the windows 98 disk like you were to install it on that computer , and then, it should, before it formats any drives, give you a choice of what drive to format.
Oct 09, 2009 | Acer TravelMate 340T Notebook
How do i install a mouse on windows98 without original startyup disks
For installing a generic mouse you need not to use any startup disk.
1. Make shutdown your pc.
2. Connect your mouse.
3. Boot your pc.
A message will be display by window that new hardware found, (if your mouse hardware is differ from previous mouse), and window will install the required driver for your mouse.
Thanks
Iqbal
Mar 10, 2008 | Belkin MiniScroller Mouse
Jun 08, 2007 | Belkin MiniScroller Mouse
Warrior 797146022002 Logo
5,718 people viewed this question
Top Warrior Computers & Internet Experts
Alun Cox
k24674
Are you a Warrior Computer and Internet Expert? Answer questions, earn points and help others
