Question about Vizio 47" M470VT Razor LED LCD HDTV, 1080p, Black
I have a vizio razor led m470vt. power light flashes dim to bright. no screen but have 120v into board. replaced power board but did not fix????
Doesnt power up. vizio logo just flashes dim to bright. replaced power board, still does same thing???
I have this same problem with my Vizio. Model E601i-A3
60" LED, believe. Maybe 64"
Anyway, the solution is much simpler than these other answers make it sound. 1) Unplug tv from wall.
2) Unplug all external devices (all HDMI ports, any cable hookups, any rgb/vga connections, and any speakers attached.)
3) Unplug USB drives/attachments.
4) Plug TV back into outlet.
It should power up just fine. Then you can go ahead and reattach all your devices WITH THE TV SCREEN ON, reattach your USB sticks and you should be good to go.
Every time the TV is moved or is unplugged for any period of time, follow these procedures. The real culprit is the USB drives - the TV, like many laptops I've had, can't boot up with them attached. Thankfully once the TV learns what they are they no longer have to be removed.
Posted on Nov 13, 2014
  • Zane Paul
    Zane Paul Nov 13, 2014
    Top Expert:
  • Vizio Master
  • 14,553 Answers
Consider taking to a shop and getting an estimate.
Posted on Dec 04, 2012
SOURCE: i plug the tv in and there is no power
Go to MENU at the Tv turn on the logo light option on.
Posted on May 08, 2010
  • 4 Answers
SOURCE: Vizio m550nv led lcd tv. Problem began a couple
I had same problem. Unplug set for 10minutes then plug it in and let it go thru it's startup routine.
Posted on Jan 27, 2011
SOURCE: Vizio P42HDTV Power on Diagnosis
Please check the U29 8 pin little surface mount mosfet it has this letters > FDS4935 > > In this part inputs 13.2 volts which is ok for the near 12 vdc but it > outputs 1.250 vdc i am 100% sure that this is all the problem > > check it out, and tell me if you´re agree with me > > On this output pin it feeds the audio Ic, the 7809 and the tuner side board > which needs de 12vdc too and its getting only the 5vdc part > > what do ya think?? > > Richard
Posted on Apr 13, 2008
SOURCE: vizio model #L37
kNOBLE
VIZIO
L32
LCD
DEAD WITH AN AMBER LIGHT
Do Not Order A New Board For This Vizio Model. You Can Fix This Problem For Pennys. Problem: Will Not Power Up Amber Led Only. Hint: No Reset To Operate Micro (Brain Dead) I'Ve Seen (3) Various Fixs Below, One Uses A Diode, Other Uses A 10k Resistor, Try Either. All 3 Will Work, Diode Works Best For Me This Same Reset Ic Goes Bad On Other Visio Lcd & Plasma Tv'S. #1) You Remove Smd U26 On The Video Processing Board And (Add) Put A 10k Resistor Across Pins 2&3. U26 Is Near The The Tact Switch. #2) Remove U26 And Solder A 10k Tru 100k Resistor Across Pin 2&3. Start With A 10 K First. #3) Remove Reset Ic Near Tac Switch Replace With 1n4148 Diode (Nte519). Vizio Tech Support: (Valid - I Tried It) 1-888-849-4623 Opt 4 Technical Support: 888-849-4623 Try Extension 1669 (David). Hugo Carrera Parts Department 877-668-8462 Ext 1814 Vizio Inc. 320a Kalmus Drive Costa Mesa, Ca 92626 E-Mail:Hugo.Carrera@Vinc.Com
Posted on May 03, 2008
  • 12 Answers
SOURCE: My vizio 32" flat screen keeps shutting off by
sound like the main board is starting to fail
Posted on Mar 07, 2011
Screen is black but I can hear sound.
Most likely the power supply board needs to be replaced. It could also be the backlighting. A few TV's have a separate power board just for backlighting, but not many.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Sep 20, 2016 | Vizio E601I-A3 60-inch Class Razor LED...
Vizio e371va screen NOT TURNING ON
Sorry to hear that...now a days it,s cheaper to replace then to fix...I had that problem on my first HD TV..a element brand...No hope....trash it went
Aug 13, 2016 | Vizio E371va 37-inch Full Hd 1080p 120 Hz...
How do I fix a LG flat screen TV?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
Feb 01, 2016 | LG Televison & Video
How do I fix problem with Vizio m550vse LED TV? Flashlight test reveals picture and no back lights are visible.
Nov 20, 2015 | Vizio 55" Class LED 1080p 120Hz HDTV,2.49"...
Tv is dim through the middle
Oct 13, 2015 | Vizio E-Series E420i-A1 42" LED TV...
What may be causing a vizio E601la3E led TV to lose back lights after 5 minutes
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 19, 2015 | Vizio Televison & Video
I have a vizio 42 inch model VO420E serial# LUKECAK1409419. when i turn it on i get a black screen but i have audio. it does this in every input. what can i do to fix this problem?
Most likely you have a backlight problem. To verify this, dim the lights in the room. Take a bright flashlight, turn on the set, and shine it on the screen. If you see a faint picture, you have a backlight fault. Your backlight inverter may be built into your power supply board. If this is the case, you will have to replace the inverter/power supply board
Sep 01, 2013 | Vizio Televison & Video
The TV has a section of it that is dimmed out and darker in brightness. Is this the Main Board that needs replaced?
Check the CCFL lamps used in the backlight section. These camps can cause this type of fault, as they are very like the flourocent tube lights that we use to illuminate our room. As it goes older, the ends of them will get burned, and the intensity will go low. Like ways is to the CCFL lamps to LCD tVs tool CCFL is the abbrivation of [Cold Cathode Flourocent Lamp]
Jul 12, 2012 | Vizio 55" M550NV Razor LED LCD HDTV, 1080p
I type slow, I have a Vizio M261VP LCD TV, I purchased it not working. I purchased a new power supply. A light comes on and flashes in lower right hand corner. I t does not flash on and off it flashes...
Good day sir chris!!!!
Welcome in fixya and I'm happy to work with you...
OK lets proceed to your TV problem..
The possible problem is not the power supply...There some shorted parts on inverter board,T-con board or main board so that the power will not initialize due to that shorted problem..
I teach you how to find which board is shorted or cause of that fault..
Just follow this procedure below.
  1. Open the back cover
  2. Look at the inverter board..it is slim board that have small transformer on it.
  3. unplug the inverter board first.Then try to power it on...
  4. If the LED on front of TV will not flashes from bright to dim it means you have shorted inverter board try to replace it..
  5. If the flashes remain..go to next step..Power off tv then reconnect inverter board,after that unplug T-con board..Then power on.
  6. If the LED on front of TV will not flashes from bright to dim it means you have shorted T-con board try to replace it..
  7. If all those procedure done but still problem persisted the only problem is main board..Replacing main board will fix the problem..
NOTE: When unplugging and replacing of all board make it sure to memorize all connection or its better if you take a picture on it for future reference..
Hope this solution will be helpful..Any rate will much appreciated..
Thanks for using fixya..have a nice day!!
Mar 04, 2012 | Vizio M261VP 26" LCD TV
Vizio 47" M470VT Razor LED LCD HDTV, 1080p, Black Logo
496 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
