Question about Refrigerators
GE TFX20Z Water Filter location?
Where is the water filter located so we can replace the filter?
SOURCE: Replaced GE SmartWater filter in my GE refrig and water wil l not flow thru it,why?
We replaced the water line to the refriderature. It was plugged by a coroded copper sleve.
Posted on Apr 29, 2008
Krazytech
  • 725 Answers
SOURCE: Water Filter location
the filter is in the toe grille under the freezer door ...it is a filter pn#4396508 you should be able to get it at Home Depot/Lowes
Posted on Sep 06, 2008
  • 13 Answers
SOURCE: Monogram water flow problem
common low flow is a kinked line or a bad water valve, the solioid valve has a filter that may be dirty. then go from there
Posted on May 03, 2009
localwonder
  • 6784 Answers
SOURCE: can't locate the water filter. water has a bad taste
The base grille water filter is located below the freezer
compartment door. Depending on your model, you may have a filter that is installed behind the base grille or a filter that is installed through the base grille.
Posted on May 23, 2009
  • 363 Answers
SOURCE: location of water filter on lg fridge freezer
OPEN DOORS LOOK IN UPPER RIGHT AND UPPER LEFT
Posted on Jul 22, 2009
I have a Kenmore side-by-side ultrafresh refrigerator model # 5255210, serial# SM0649567. I cannot find the water filter. Where is the water filter located on this refrigerator ?
Owning 1 of these refrigerators will require you to replace the water filter from time to time, in order to keep the water fresh and the refrigerator running efficiently. Kenmore refrigerators are made by Amana, Frigidaire, GE, LG, and Whirlpool, so it is important to find out which manufacturer made your Kenmore refrigerator, in order to make sure you order the right part. Kenmore refrigerators use filters that are located in the bottom, front panel of the refrigerator. Details can be found on WiKi how to change a water filter on a Kenmore Refrigerator.
May 24, 2016 | Kenmore Refrigerators
Does GE frig model # GSS25JETA have a water filter?
I don't see a filter listed in the parts breakdown for that model. If you had one, in would located in the fresh food section, top right rear corner. GE does have an external filter that can be installed in the 1/4 inch water line. and should last 6 months to a year depending on how much water you use and how bad you water actually is. GE part number is GXRTDR.
Mar 04, 2015 | GE Refrigerators
Why my refrigerator is leaking water from the top where the water filter is located?
Shut off water supply valve. Relieve water pressure by dispensing water. Unscrew water filter. Examine to see if the gasket is damaged or if filter was loose and just needed tightening. Or simply replace water filter with the correct water filter that your GE refrigerator calls for.
Jul 19, 2014 | GE Refrigerators
Where is the water filter for the ice maker located on a GE tfx24zr side by side refridgerator located
Filters situated in the interior liner of the refrigerator compartment of GE-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Remove the old filter by grasping it and slowly making a one quarter turn to the left.
  2. Pull down gently on the filter to remove it from the mounting bracket assembly. Be careful to not tip the filter, as water may spill out of it.
  3. Discard used filter.
Water by Culligan filter cartridges need to have a water filter adapter installed. This is a one time installment, and once you have this adapter installed, it stays in the refrigerator for all future filter replacements. If your refrigerator already has this adapter in place, do not remove it to replace the filter.
Smart Water filter cartridges do not require the use of the water filter adapter. If for some reason your refrigerator has an adapter in place already, you will have to remove it before installing a Smart Water filter cartridge. The adapter is removed in the same manner as the filter itself: with a gentle quarter turn to the left.
Remove the new filter from its packaging. Apply the appropriate month sticker to the filter to remind yourself to change it again in six months' time.
Fill the filter with water from the tap, and then line the arrow on the filter up with the arrow on the cartridge holder inside your refrigerator.
The filter automatically pulls itself into position as you turn the filter to the right and lock it in place. Be careful to not over tighten the filter into position.
Run water through your dispenser for about three minutes to clear the system. Keep in mind that a newly installed water filter could initially cause water to spurt from the dispenser.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Hope this was helpful to you. Thank you for using fixya.
Jan 26, 2011 | GE Refrigerators
My water preasure in door is terrible takes forever to fill glass
Either replace the water filter or replace the water valve ( located behind the refrig where the wall water line connects to ) or , install the water filter bypass piece which came with the refrig . ( This will tell you if the filter needs replaced ) .
Sep 08, 2010 | GE GSS20IEP Side by Side Refrigerator
Water dispenser
My filter is located on the inside of the refrigerator in the top right corner. It twists off and is easy to replace.
Jan 21, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I was changing my filter in the ge filtration system, and it says to turn off the water and press the red button. Then it says to unscrew the filter take the old one out and clean the filtrstion system...
The red button is a pressure relieve valve. If the system is leaking from the valve, try pushing the valve up from the underside of the cap where the valve is located. If this does not work the housing needs to be replaced. You do not have to replace this with a name brand like GE. All you need to do is make sure the housing that you are purchasing is the same size.
Example of Replacement Filter Housing: http://www.freshwatersystems.com/c-107-filter-housings.aspx
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Apr 27, 2009 | General Electric GE SmartWater Household...
Jun 11, 2008 | GE Monogram ZISS480DRSS Stainless Steel
WATER FILTER
All of the cabinets I have worked on have had external water filters, so unless yours is really special you will normally find the water filter located behind the fridge freezer in the incoming water supply line (typically 4 - 6 inches long 2 inches diameter). Some cabinets now have a timer to indicate a long duration, none that i have come across monitor water quality. Hope this helps.
Mar 09, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
