Question about Sony Audio Players & Recorders
HI I HAVE SONY MHC-RV900D found corrosion on the board, how to repair, to replace how much it will cost?
It is not working, the display is gone
4 Suggested Answers
  • 4234 Answers
SOURCE: MHC-RV5
The repair manual can be purchased from Sony. What is the specific problem. Perhaps a manual is not needed.
Dan
Posted on May 20, 2008
SOURCE: HI I HAVE SONY MHC-RV900D
My Sony MHC RV900D plays video uninterrupted but the sound on a DVD or CD starts then plays for a minute or so then no sound for anything from 5mins to a few hours, then sound returns and so forth. ANy ideas please?
Posted on Sep 09, 2010
welcomejee
  • 10594 Answers
SOURCE: Sony mini hi-fi component speaker does not play.
I need little more info about sound problem, are you not getting sound in dvd playback or it happens in all inputs like FM or tapes etc?
Did you tried audio cd playback to check sound in all speakers?
Thanks.
Posted on Dec 05, 2010
Sony MHC-GX250 RCA jack panel
Unless the jacks have physically broken, replacing them is not the solution to the problem. Generally if both channels are dead, then you will find that a pre-amp IC has failed. This can be found by simply following where the jacks enter the PC board then following the circuit till they go into an IC.
Jul 04, 2013 | Audio Players & Recorders
Sir my MHC-RV900D is disply shows push power protection again and again.plz solve my problem. thank u
There is most likely a short in the amplifier that will need to be repaired before the unit will power on normally.
Mar 12, 2013 | Sony MHC-GX40 CD Shelf System
My sony mhc-rv777d is not working when i on my sony within 4or 5 sec it off automatically so i need a solution
MHC-RV777D shuts off itself because of protection mode that is activated to avoid further damage due to defective amplifier output IC in unit.
You need to check/ replace output amplifier IC to solve this issue, if you are not familiar with electronics stuff repair then local repair shop will do this job for you.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Nov 03, 2010 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
MHC-EX100AV: Tuner display doesn't work: but the tuner itself works great, just that I can't see anything on the display. I am sure easy to solve but have no clue where to start
change the lightbulb behind the display and it works again. sony repair charges 45 euro for it. you can also put a led and a resistor behind it.
Sep 19, 2010 | Sony MHC-RX100AV Shelf System
HI I HAVE SONY MHC-RV900D WHEN I SWITCH IT ON IT SHOWS PROTECT PUSH POWER. HOW CAN I PLAY MY SYSTEM AGAIN.??
Welcome to FixYa
Do Following...
  • Turn off the System-Turn it off for a while
  • Then turn it back on.
  • Still Problem, Turn Off system and Check the Speaker Code
  • RESET the system .
  • Remove all the connections, leave it for 24hours and then connect it up again
To Reset
  • Unplug Power Code
  • Plug it back again
  • Press Stop , Enter and Power button at Same time
  • Press Power Button to Turn on it
For more Here is the Guide for your Product Click here
Still have Problem The protective device on the amplifier has been activated because of short circuit. (“PROTECT” and “PUSH POWER” flash alternately.) Turn off the unit, eliminate the short-circuit problem and turn on the power again.
Hope you Got a Conclusion..Thanks for Contacting FixYa...
Jun 15, 2010 | Sony MHC-GX40 CD Shelf System
Dvd not playing.c 31 00 occur
The only thing you can do is get a CD DVD player cleaner with liquid. Found at any store these days, then run it a couple times. If it plays, Problem solved, if not, it must be repaired. They will put a new transport in the unit. Usually runs 100-150 to replace. Weigh the cost to fix vs. the cost to replace and the age of the unit before you get it repaired. Hope this helps
Jun 01, 2009 | Sony MHC-RV888D Shelf System
Sony MHC GNZ8D Region unlock
Need to unlock the MHC-GNZ8D. Please help.-
Jan 06, 2008 | Audio Players & Recorders
18 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
