I have a Hampton Bay celing fan (model 52DC10H4L) fan and can not remove the holder from the ceiling. No visible screws, etc. Any suggestions?
rayname
  • 70 Answers
SOURCE: I have a Hampton Bay
if the batteries are new in the remote and no one changed the dip switch settings in the fan or on the remote if available then it is possible you do not have power at the fan is a breaker tripped if not then it is possible the sensor unit or remote has gone bad this usually can be purchased at the hardware store you will need some electrical knowledge to install let me know if this helps
Posted on Jan 06, 2009
bobotfel
  • 236 Answers
SOURCE: Remote operation of ceiling fan NOT working.
Try to check the remote control by using camera or cell camera, just use it as your eyes to see if the remote control emits signal. Just point your remote control to the camera and "on" then check if the remote control emits light, if no emitted lights means defective remote but if emit lights then the receiver is defective . Try also to locate if there are any reset or rst button on the remote control and press it then test.
Posted on Jan 10, 2009
SOURCE: I'm selling a Hampton Bay
As long as you have the remote and the receiver that go in the top it will work
Posted on Jan 21, 2009
SOURCE: need to change glass globe in hampton bay fan
I had the exact same problem. To solve it, I had a friend hold the area of the fan that the globe screws into. I wore rubber dish gloves to get a good grip and pushed up slightly on the globe as I turned counter-clockwise. My friend held the other part and turned clockwise a little as well. It took a lot of pressure for it to finally come loose and then we just turned it about another 90 degrees and the globe slips right out of the groove.
I couldn't believe how hard this was to do.
Posted on Feb 14, 2009
I have a Hampton Bay ceiling fan model AC 552 s/n 000934 I need to know how to take it down, there is no visible screws to loosen for disassembly. Can you guide me to a schematic showing disassembly
Sometimes the trim ring rotates 1/4 of a turn then comes down to expose screws. If you could send me a picture of it I can explain better
Nov 30, 2014 | Hampton Bay Dryers
Where is a Hampton bay repair center in Mich. I need a the part hangs the celing fan to the Elc box.
Hampton bay is owned by home depot and to the best of my knowledge there are no repair centers for hampton bay fans. That bracket can be purchased (or ordered) from home depot. You could try searching "king of fans" online, they manufacture hampton bay fans for home depot.
Aug 10, 2009 | Dryers
Cannot stop the ceiling fan from wobbling. Have
you still have a blade that is out of balance. mesure each blade from the bottom side end to the celing in one spot. Do this for each blade when you find the one that is closest to the celing then you have to place the wheight on the edge of that blade then spin it to make the right adjustment then seta stick on weight where the temp. weight is at
Jul 31, 2009 | Hampton Bay 73554 Antigua Ceiling Fan
I have the Hampton Bay 5-Light Track Lighting
Skill, patience, preseverance, and experience. You ned to cut and strip the wires so they "just fit" into the space provided leading to the connectyion screws. no room for stuffing , and no extra wiggle room for and bends or kinks .. You mightb try mounting the wires and then pushing the extra wire back up intio the ceiling junction box, thats what I do.
May 10, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
Hampton Bay Ceiling fan wobbling
The fan came with one or more clips and some small weights that easily stick to the blade. Now with the clip you put it in one of the blades, starting from the far end and coming inwards, little by little. Try putting the clip in the middle of the fan and turn on the fan and see if it continues wobbling, if it continues wobbling try moving it to left and right and every time turn on the fan and see what happens. When you find the correct spot, there you glue the small weight.
Apr 09, 2009 | Universal Remote Control Hampton Bay...
Need to change glass globe in hampton bay fan
Jan 23, 2009 | Hampton Bay 24002 Ceiling Fan
Have a Hampton Bay ceiling fan that doesn't work.
I'm pretty sure that home depot does sell remotes for that brand, although you may have to buy a new receiver to go with it. Otherwise try a lighting store near where you live. They seem to be able to order things like that.
Jan 09, 2009 | Hampton Bay 52 In. White Redington...
Hampton Bay remote for ceiling fan caused an electrical fire
We just installed this fan and within 1 day the electrical wires in the receiver burned and would have caught fire had it not been caught!!!
Jan 07, 2009 | Universal Remote Control Hampton Bay...
Problem with Hampton Bay 54 In. Flemish Pewter Ceiling Fan With Heater
did you check the circuit breaker to see if its tripped?im assuming the voltage rating of the wires your decribing are 110 volts and the fan likewise.the white wire could possibly be a neutral wire,meaning you should hook up the red and black wire.let me know
Jul 30, 2007 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Heating & Cooling Logo
161 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
